new cart
Re: new cart
Hi Peter
In your above post, you are missing the "[" before the closing "/code]" tag.
So the following text with your question is not seen unless you scroll down in the code box.
Re: new cart
nbache wrote: Sun Jan 24, 2021 12:43 pm Hi Peter
Many thanks Niels.
I do not know what happened there but thanks to you it is now fixed.
Have a nice day :)
Re: new cart
Hi Musa,
musa wrote: Sun Jan 24, 2021 11:25 am Hi Christian.
Thanks for your reply. I have managed to repair my 6870 graphics card and it seems to be running stable now. With Radeon 6870 in pci-e slot 1, my xorg.conf looks like this and gives 3d.
Great!
musa wrote: Sun Jan 24, 2021 11:25 am If I instead put with R7240 in pci-e slot 1 and the radio 6870 in pci-e slot 2, what should my xorg.conf look like? Lspci gives BusID "PCI: 3: 0: 0" is there anything else to change other than busid?
No, your settings are correct.
musa wrote: Sun Jan 24, 2021 11:25 am Both cards can be seen in Amigaos. Currently I only use 6870 and it runs fine but does not provide 3d in Amigaos.
Thank you in advance for your help
Peter
I am not an OS4 expert but I think you need another monitor file.
Re: new cart
@Musa: OS4 doc
Re: new cart
xeno74 wrote: Sun Jan 24, 2021 6:01 pm Hi Musa,
Hi Christian.
No this is only in linux I need help.
linux recognizes both cards with card 1 on busid: 1.0.0 or card 2 on busid 3.0.0
I start on the first card R7240 and start linux and then the xorg.conf must open card 2 6780 for output.
i'm not running with 2 cards right now but i'm trying again at a time.
thanks for the help
Peter
