Kernel 4.9 (Longterm)
Re: Kernel 4.9 (Longterm)
Sam460ex 4.9.30 kernel .
(Boot via U-boot shell from USB thumb drive or tftp server).
https://drive.google.com/open?id=0BxoZd ... zVvUmFkQTA
Sam460ex 4.9.31 kernel .
https://drive.google.com/open?id=0BxoZd ... URfdTBtWEE
javierdlr
Post by javierdlr »
Spectre660 wrote:Sam460ex 4.9.31 kernel .
https://drive.google.com/open?id=0BxoZd ... Hg1QmI5Nm8
Tried to dl, but it seems the link just points to 'sam460ex-4.12-2.config' file not the full archive.
Sorry .
Link corrected now .
Sam460ex 4.9.33 kernel .
https://drive.google.com/open?id=0BxoZd ... UZPcEhveXM
Spectre660 wrote:Sam460ex 4.9.33 kernel .
Thank you! :-)
Thank you.
Thank you! :-)
Sam460ex 4.9.34 kernel .
(Boot via U-boot shell from internal SD card,USB thumb drive or tftp server).
I have started to boot from the Sam460ex's internal SD card with a class 4 SD card .
SD Card or thumb drive partition must be ext2 or Ext3 format .
The default AmigaOS script to set the U-boot boot variable uses the 3rd partition of the SD card or USB thumb drive for loading the kernel and dtb file .
https://drive.google.com/open?id=0BxoZd ... jhGeUpGUjQ
Sam460ex 4.9.35 kernel .
https://drive.google.com/open?id=0BxoZd ... 0lPcDZTWEU
Reworked the 4.9.35 kernel.
Should be more responsive .
same link .
