Kernel 5.13
Kernel 5.13
The Linux 5.13 merge window is open. :-) Happy testing!
Download: linux-image-5.13-alpha1-X1000_X5000.tar.gz
Re: Kernel 5.13
I compiled the latest Git kernel today. Unfortunately this kernel doesn't boot on the X5000 and X1000 anymore. It boots in a virtual e5500 QEMU machine.
I bisected today.
  1. Code: Select all
    git bisect start
  2. Code: Select all
    git bisect good 9f4ad9e425a1d3b6a34617b8ea226d56a119a717
    (Good: Linux 5.12)
  3. Code: Select all
    git bisect bad 9d31d2338950293ec19d9b095fbaa9030899dcb4
    (Bad: Merge tag 'net-next-5.13' -- 2021-04-29 11:57:23)
  4. git bisect good
  5. git bisect bad
  6. git bisect bad
  7. git bisect bad
  8. git bisect bad
  9. git bisect bad
  10. git bisect bad
  11. git bisect bad
  12. git bisect bad
  13. git bisect bad
  14. git bisect good
  15. git bisect good
  16. git bisect bad
  17. git bisect bad
Result: 434fb1e7444a2efc3a4ebd950c7f771ebfcffa31 is the first bad commit.
Author: Gustavo A. R. Silva <gustavoars@kernel.org>
Date:   Wed Feb 10 17:49:27 2021 -0600
    drm/radeon/nislands_smc.h: Replace one-element array with flexible-array member in struct NISLANDS_SMC_SWSTATE
    There is a regular need in the kernel to provide a way to declare having
    a dynamically sized set of trailing elements in a structure. Kernel code
    should always use “flexible array members”[1] for these cases. The older
    style of one-element or zero-length arrays should no longer be used[2].
    Use flexible-array member in struct NISLANDS_SMC_SWSTATE, instead of
    one-element array.
    Also, this helps with the ongoing efforts to enable -Warray-bounds by
    fixing the following warnings:
    drivers/gpu/drm/radeon/ni_dpm.c: In function ‘ni_convert_power_state_to_smc’:
    drivers/gpu/drm/radeon/ni_dpm.c:2521:20: warning: array subscript 1 is above array bounds of ‘NISLANDS_SMC_HW_PERFORMANCE_LEVEL[1]’ {aka ‘struct NISLANDS_SMC_HW_PERFORMANCE_LEVEL[1]’} [-Warray-bounds]
     2521 |   smc_state->levels[i].dpm2.MaxPS =
    drivers/gpu/drm/radeon/ni_dpm.c:2523:20: warning: array subscript 1 is above array bounds of ‘NISLANDS_SMC_HW_PERFORMANCE_LEVEL[1]’ {aka ‘struct NISLANDS_SMC_HW_PERFORMANCE_LEVEL[1]’} [-Warray-bounds]
     2523 |   smc_state->levels[i].dpm2.NearTDPDec = NISLANDS_DPM2_NEAR_TDP_DEC;
    drivers/gpu/drm/radeon/ni_dpm.c:2524:20: warning: array subscript 1 is above array bounds of ‘NISLANDS_SMC_HW_PERFORMANCE_LEVEL[1]’ {aka ‘struct NISLANDS_SMC_HW_PERFORMANCE_LEVEL[1]’} [-Warray-bounds]
     2524 |   smc_state->levels[i].dpm2.AboveSafeInc = NISLANDS_DPM2_ABOVE_SAFE_INC;
    drivers/gpu/drm/radeon/ni_dpm.c:2525:20: warning: array subscript 1 is above array bounds of ‘NISLANDS_SMC_HW_PERFORMANCE_LEVEL[1]’ {aka ‘struct NISLANDS_SMC_HW_PERFORMANCE_LEVEL[1]’} [-Warray-bounds]
     2525 |   smc_state->levels[i].dpm2.BelowSafeInc = NISLANDS_DPM2_BELOW_SAFE_INC;
    drivers/gpu/drm/radeon/ni_dpm.c:2526:35: warning: array subscript 1 is above array bounds of ‘NISLANDS_SMC_HW_PERFORMANCE_LEVEL[1]’ {aka ‘struct NISLANDS_SMC_HW_PERFORMANCE_LEVEL[1]’} [-Warray-bounds]
     2526 |   smc_state->levels[i].stateFlags |=
     2527 |    ((i != (state->performance_level_count - 1)) && power_boost_limit) ?
     2528 |    PPSMC_STATEFLAG_POWERBOOST : 0;
    drivers/gpu/drm/radeon/ni_dpm.c:2442:20: warning: array subscript 1 is above array bounds of ‘NISLANDS_SMC_HW_PERFORMANCE_LEVEL[1]’ {aka ‘struct NISLANDS_SMC_HW_PERFORMANCE_LEVEL[1]’} [-Warray-bounds]
     2442 |   smc_state->levels[i + 1].aT = cpu_to_be32(a_t);
    [1] https://en.wikipedia.org/wiki/Flexible_array_member
    [2] https://www.kernel.org/doc/html/v5.9/process/deprecated.html#zero-length-and-one-element-arrays
    Link: https://github.com/KSPP/linux/issues/79
    Link: https://github.com/KSPP/linux/issues/109
    Build-tested-by: kernel test robot <lkp@intel.com>
    Link: https://lore.kernel.org/lkml/6023ed54.BfIY+9Uz81I6nq19%25lkp@intel.com/
    Signed-off-by: Gustavo A. R. Silva <gustavoars@kernel.org>
    Signed-off-by: Alex Deucher <alexander.deucher@amd.com>
:040000 040000 825941c1622038715917db88900263261697ff43 44e16f7b0c4f28a6ca1fb7cc71a6d6a7a9db668f M	drivers
git revert 434fb1e7444a2efc3a4ebd950c7f771ebfcffa31
Output:
[master 437344379819] Revert "drm/radeon/nislands_smc.h: Replace one-element array with flexible-array member in struct NISLANDS_SMC_SWSTATE"
 1 file changed, 5 insertions(+), 5 deletions(-)
After a new compiling, the kernel boots without any problems.
I created a patch for reverting the bad commit:
diff -rupN a/drivers/gpu/drm/radeon/nislands_smc.h b/drivers/gpu/drm/radeon/nislands_smc.h
--- a/drivers/gpu/drm/radeon/nislands_smc.h     2021-04-30 12:53:11.426435827 +0200
+++ b/drivers/gpu/drm/radeon/nislands_smc.h     2021-04-30 12:52:35.298525162 +0200
@@ -134,11 +134,11 @@ typedef struct NISLANDS_SMC_HW_PERFORMAN
-       uint8_t                             flags;
-       uint8_t                             levelCount;
-       uint8_t                             padding2;
-       uint8_t                             padding3;
-       NISLANDS_SMC_HW_PERFORMANCE_LEVEL   levels[];
+    uint8_t                             flags;
+    uint8_t                             levelCount;
+    uint8_t                             padding2;
+    uint8_t                             padding3;
+    NISLANDS_SMC_HW_PERFORMANCE_LEVEL   levels[1];
 typedef struct NISLANDS_SMC_SWSTATE NISLANDS_SMC_SWSTATE;
The kernel compiles and boots with this patch on my X1000 and X5000.
Re: Kernel 5.13
Re: Kernel 5.13
The same commit is also available for SI graphics cards.
Linux Git
Please also test the alpha2 with Radeon SI graphics cards. It could be, that your AmigaOne doesn't boot. I only patched the alpha2 for NI Radeons.
Re: Kernel 5.13
Here is the third alpha of kernel 5.13 with the first PowerPC updates 5.13-1 for testing.
Further news:
Issues:
Download: linux-image-5.13-alpha3-X1000_X5000.tar.gz
In addition, a nice background image for your desktop:
Please test the kernels because of the PowerPC updates.
Re: Kernel 5.13
xeno74 wrote: Fri Apr 30, 2021 12:22 pm Hi All,
Result of bisect: 434fb1e7444a2efc3a4ebd950c7f771ebfcffa31 is the first bad commit.
    one-element array.
Output:
-       uint8_t                             flags;
-       uint8_t                             padding2;
-       uint8_t                             padding3;
+    uint8_t                             flags;
+    uint8_t                             padding2;
+    uint8_t                             padding3;
Gustavo released a patch today.
From 4c16031cebe9b4d319974bf86af4f9823f911955 Mon Sep 17 00:00:00 2001
From: "Gustavo A. R. Silva" <gustavoars@kernel.org>
Date: Thu, 6 May 2021 18:28:39 -0500
Subject: drm/radeon/ni_dpm: Fix booting bug
Create new structure NISLANDS_SMC_SWSTATE_SINGLE, as initialState.levels
and ACPIState.levels are never actually used as flexible arrays. Those
arrays can be used as simple objects of type
NISLANDS_SMC_HW_PERFORMANCE_LEVEL, instead.
Currently, the code fails because flexible array _levels_ in
struct NISLANDS_SMC_SWSTATE doesn't allow for code that accesses
the first element of initialState.levels and ACPIState.levels
arrays:
1690         table->initialState.levels[0].mclk.vMPLL_AD_FUNC_CNTL =
1691                 cpu_to_be32(ni_pi->clock_registers.mpll_ad_func_cntl);
1903:   table->ACPIState.levels[0].mclk.vMPLL_AD_FUNC_CNTL = cpu_to_be32(mpll_ad_func_cntl);
1904:   table->ACPIState.levels[0].mclk.vMPLL_AD_FUNC_CNTL_2 = cpu_to_be32(mpll_ad_func_cntl_2);
because such element cannot be accessed without previously allocating
enough dynamic memory for it to exist (which never actually happens).
That's why struct NISLANDS_SMC_SWSTATE should only be used as type
for object driverState and new struct NISLANDS_SMC_SWSTATE_SINGLE is
created as type for objects initialState, ACPIState and ULVState.
Also, with the change from one-element array to flexible-array member
in commit 434fb1e7444a ("drm/radeon/nislands_smc.h: Replace one-element
array with flexible-array member in struct NISLANDS_SMC_SWSTATE"), the
size of dpmLevels in struct NISLANDS_SMC_STATETABLE should be fixed to
be NISLANDS_MAX_SMC_PERFORMANCE_LEVELS_PER_SWSTATE instead of
NISLANDS_MAX_SMC_PERFORMANCE_LEVELS_PER_SWSTATE - 1.
Bug: https://lore.kernel.org/dri-devel/3eedbe78-1fbd-4763-a7f3-ac5665e76a4a@xenosoft.de/
Fixes: 434fb1e7444a ("drm/radeon/nislands_smc.h: Replace one-element array with flexible-array member in struct NISLANDS_SMC_SWSTATE")
 drivers/gpu/drm/radeon/ni_dpm.c       | 144 +++++++++++++++++-----------------
 drivers/gpu/drm/radeon/nislands_smc.h |  34 +++++---
 2 files changed, 94 insertions(+), 84 deletions(-)
diff --git a/drivers/gpu/drm/radeon/ni_dpm.c b/drivers/gpu/drm/radeon/ni_dpm.c
index dd5ef64937230..769f666335ac4 100644
--- a/drivers/gpu/drm/radeon/ni_dpm.c
+++ b/drivers/gpu/drm/radeon/ni_dpm.c
@@ -1687,102 +1687,102 @@ static int ni_populate_smc_initial_state(struct radeon_device *rdev,
 	u32 reg;
 	int ret;
-	table->initialState.levels[0].mclk.vMPLL_AD_FUNC_CNTL =
+	table->initialState.level.mclk.vMPLL_AD_FUNC_CNTL =
-	table->initialState.levels[0].mclk.vMPLL_AD_FUNC_CNTL_2 =
+	table->initialState.level.mclk.vMPLL_AD_FUNC_CNTL_2 =
 		cpu_to_be32(ni_pi->clock_registers.mpll_ad_func_cntl_2);
-	table->initialState.levels[0].mclk.vMPLL_DQ_FUNC_CNTL =
+	table->initialState.level.mclk.vMPLL_DQ_FUNC_CNTL =
 		cpu_to_be32(ni_pi->clock_registers.mpll_dq_func_cntl);
-	table->initialState.levels[0].mclk.vMPLL_DQ_FUNC_CNTL_2 =
+	table->initialState.level.mclk.vMPLL_DQ_FUNC_CNTL_2 =
 		cpu_to_be32(ni_pi->clock_registers.mpll_dq_func_cntl_2);
-	table->initialState.levels[0].mclk.vMCLK_PWRMGT_CNTL =
+	table->initialState.level.mclk.vMCLK_PWRMGT_CNTL =
 		cpu_to_be32(ni_pi->clock_registers.mclk_pwrmgt_cntl);
-	table->initialState.levels[0].mclk.vDLL_CNTL =
+	table->initialState.level.mclk.vDLL_CNTL =
 		cpu_to_be32(ni_pi->clock_registers.dll_cntl);
-	table->initialState.levels[0].mclk.vMPLL_SS =
+	table->initialState.level.mclk.vMPLL_SS =
 		cpu_to_be32(ni_pi->clock_registers.mpll_ss1);
-	table->initialState.levels[0].mclk.vMPLL_SS2 =
+	table->initialState.level.mclk.vMPLL_SS2 =
 		cpu_to_be32(ni_pi->clock_registers.mpll_ss2);
-	table->initialState.levels[0].mclk.mclk_value =
+	table->initialState.level.mclk.mclk_value =
 		cpu_to_be32(initial_state->performance_levels[0].mclk);
-	table->initialState.levels[0].sclk.vCG_SPLL_FUNC_CNTL =
+	table->initialState.level.sclk.vCG_SPLL_FUNC_CNTL =
 		cpu_to_be32(ni_pi->clock_registers.cg_spll_func_cntl);
-	table->initialState.levels[0].sclk.vCG_SPLL_FUNC_CNTL_2 =
+	table->initialState.level.sclk.vCG_SPLL_FUNC_CNTL_2 =
 		cpu_to_be32(ni_pi->clock_registers.cg_spll_func_cntl_2);
-	table->initialState.levels[0].sclk.vCG_SPLL_FUNC_CNTL_3 =
+	table->initialState.level.sclk.vCG_SPLL_FUNC_CNTL_3 =
 		cpu_to_be32(ni_pi->clock_registers.cg_spll_func_cntl_3);
-	table->initialState.levels[0].sclk.vCG_SPLL_FUNC_CNTL_4 =
+	table->initialState.level.sclk.vCG_SPLL_FUNC_CNTL_4 =
 		cpu_to_be32(ni_pi->clock_registers.cg_spll_func_cntl_4);
-	table->initialState.levels[0].sclk.vCG_SPLL_SPREAD_SPECTRUM =
+	table->initialState.level.sclk.vCG_SPLL_SPREAD_SPECTRUM =
 		cpu_to_be32(ni_pi->clock_registers.cg_spll_spread_spectrum);
-	table->initialState.levels[0].sclk.vCG_SPLL_SPREAD_SPECTRUM_2 =
+	table->initialState.level.sclk.vCG_SPLL_SPREAD_SPECTRUM_2 =
 		cpu_to_be32(ni_pi->clock_registers.cg_spll_spread_spectrum_2);
-	table->initialState.levels[0].sclk.sclk_value =
+	table->initialState.level.sclk.sclk_value =
 		cpu_to_be32(initial_state->performance_levels[0].sclk);
-	table->initialState.levels[0].arbRefreshState =
+	table->initialState.level.arbRefreshState =
 		NISLANDS_INITIAL_STATE_ARB_INDEX;
-	table->initialState.levels[0].ACIndex = 0;
+	table->initialState.level.ACIndex = 0;
 	ret = ni_populate_voltage_value(rdev, &eg_pi->vddc_voltage_table,
 					initial_state->performance_levels[0].vddc,
-					&table->initialState.levels[0].vddc);
+					&table->initialState.level.vddc);
 	if (!ret) {
 		u16 std_vddc;
 		ret = ni_get_std_voltage_value(rdev,
-					       &table->initialState.levels[0].vddc,
+					       &table->initialState.level.vddc,
 					       &std_vddc);
 		if (!ret)
 			ni_populate_std_voltage_value(rdev, std_vddc,
-						      table->initialState.levels[0].vddc.index,
-						      &table->initialState.levels[0].std_vddc);
+						      table->initialState.level.vddc.index,
+						      &table->initialState.level.std_vddc);
 	if (eg_pi->vddci_control)
 					  &eg_pi->vddci_voltage_table,
 					  initial_state->performance_levels[0].vddci,
-					  &table->initialState.levels[0].vddci);
+					  &table->initialState.level.vddci);
-	ni_populate_initial_mvdd_value(rdev, &table->initialState.levels[0].mvdd);
+	ni_populate_initial_mvdd_value(rdev, &table->initialState.level.mvdd);
 	reg = CG_R(0xffff) | CG_L(0);
-	table->initialState.levels[0].aT = cpu_to_be32(reg);
+	table->initialState.level.aT = cpu_to_be32(reg);
-	table->initialState.levels[0].bSP = cpu_to_be32(pi->dsp);
+	table->initialState.level.bSP = cpu_to_be32(pi->dsp);
 	if (pi->boot_in_gen2)
-		table->initialState.levels[0].gen2PCIE = 1;
+		table->initialState.level.gen2PCIE = 1;
 	else
-		table->initialState.levels[0].gen2PCIE = 0;
+		table->initialState.level.gen2PCIE = 0;
 	if (pi->mem_gddr5) {
-		table->initialState.levels[0].strobeMode =
+		table->initialState.level.strobeMode =
 			cypress_get_strobe_mode_settings(rdev,
 		if (initial_state->performance_levels[0].mclk > pi->mclk_edc_enable_threshold)
-			table->initialState.levels[0].mcFlags = NISLANDS_SMC_MC_EDC_RD_FLAG | NISLANDS_SMC_MC_EDC_WR_FLAG;
+			table->initialState.level.mcFlags = NISLANDS_SMC_MC_EDC_RD_FLAG | NISLANDS_SMC_MC_EDC_WR_FLAG;
 		else
-			table->initialState.levels[0].mcFlags =  0;
+			table->initialState.level.mcFlags =  0;
 	table->initialState.levelCount = 1;
 	table->initialState.flags |= PPSMC_SWSTATE_FLAG_DC;
-	table->initialState.levels[0].dpm2.MaxPS = 0;
-	table->initialState.levels[0].dpm2.NearTDPDec = 0;
-	table->initialState.levels[0].dpm2.AboveSafeInc = 0;
-	table->initialState.levels[0].dpm2.BelowSafeInc = 0;
+	table->initialState.level.dpm2.MaxPS = 0;
+	table->initialState.level.dpm2.NearTDPDec = 0;
+	table->initialState.level.dpm2.AboveSafeInc = 0;
+	table->initialState.level.dpm2.BelowSafeInc = 0;
 	reg = MIN_POWER_MASK | MAX_POWER_MASK;
-	table->initialState.levels[0].SQPowerThrottle = cpu_to_be32(reg);
+	table->initialState.level.SQPowerThrottle = cpu_to_be32(reg);
 	reg = MAX_POWER_DELTA_MASK | STI_SIZE_MASK | LTI_RATIO_MASK;
-	table->initialState.levels[0].SQPowerThrottle_2 = cpu_to_be32(reg);
+	table->initialState.level.SQPowerThrottle_2 = cpu_to_be32(reg);
 	return 0;
@@ -1813,43 +1813,43 @@ static int ni_populate_smc_acpi_state(struct radeon_device *rdev,
 	if (pi->acpi_vddc) {
-						pi->acpi_vddc, &table->ACPIState.levels[0].vddc);
+						pi->acpi_vddc, &table->ACPIState.level.vddc);
 		if (!ret) {
 			u16 std_vddc;
-						       &table->ACPIState.levels[0].vddc, &std_vddc);
+						       &table->ACPIState.level.vddc, &std_vddc);
 			if (!ret)
-							      table->ACPIState.levels[0].vddc.index,
-							      &table->ACPIState.levels[0].std_vddc);
+							      table->ACPIState.level.vddc.index,
+							      &table->ACPIState.level.std_vddc);
 		if (pi->pcie_gen2) {
 			if (pi->acpi_pcie_gen2)
-				table->ACPIState.levels[0].gen2PCIE = 1;
+				table->ACPIState.level.gen2PCIE = 1;
 			else
-				table->ACPIState.levels[0].gen2PCIE = 0;
+				table->ACPIState.level.gen2PCIE = 0;
 		} else {
 	} else {
 						pi->min_vddc_in_table,
-						&table->ACPIState.levels[0].vddc);
+						&table->ACPIState.level.vddc);
 		if (!ret) {
 			u16 std_vddc;
 						       &std_vddc);
 			if (!ret)
 	if (eg_pi->acpi_vddci) {
@@ -1857,7 +1857,7 @@ static int ni_populate_smc_acpi_state(struct radeon_device *rdev,
 						  eg_pi->acpi_vddci,
-						  &table->ACPIState.levels[0].vddci);
+						  &table->ACPIState.level.vddci);
@@ -1900,37 +1900,37 @@ static int ni_populate_smc_acpi_state(struct radeon_device *rdev,
 	spll_func_cntl_2 &= ~SCLK_MUX_SEL_MASK;
 	spll_func_cntl_2 |= SCLK_MUX_SEL(4);
-	table->ACPIState.levels[0].mclk.vMPLL_AD_FUNC_CNTL = cpu_to_be32(mpll_ad_func_cntl);
-	table->ACPIState.levels[0].mclk.vMPLL_AD_FUNC_CNTL_2 = cpu_to_be32(mpll_ad_func_cntl_2);
-	table->ACPIState.levels[0].mclk.vMPLL_DQ_FUNC_CNTL = cpu_to_be32(mpll_dq_func_cntl);
-	table->ACPIState.levels[0].mclk.vMPLL_DQ_FUNC_CNTL_2 = cpu_to_be32(mpll_dq_func_cntl_2);
-	table->ACPIState.levels[0].mclk.vMCLK_PWRMGT_CNTL = cpu_to_be32(mclk_pwrmgt_cntl);
-	table->ACPIState.levels[0].mclk.vDLL_CNTL = cpu_to_be32(dll_cntl);
+	table->ACPIState.level.mclk.vMPLL_AD_FUNC_CNTL = cpu_to_be32(mpll_ad_func_cntl);
+	table->ACPIState.level.mclk.vMPLL_AD_FUNC_CNTL_2 = cpu_to_be32(mpll_ad_func_cntl_2);
+	table->ACPIState.level.mclk.vMPLL_DQ_FUNC_CNTL = cpu_to_be32(mpll_dq_func_cntl);
+	table->ACPIState.level.mclk.vMPLL_DQ_FUNC_CNTL_2 = cpu_to_be32(mpll_dq_func_cntl_2);
+	table->ACPIState.level.mclk.vMCLK_PWRMGT_CNTL = cpu_to_be32(mclk_pwrmgt_cntl);
+	table->ACPIState.level.mclk.vDLL_CNTL = cpu_to_be32(dll_cntl);
-	table->ACPIState.levels[0].mclk.mclk_value = 0;
+	table->ACPIState.level.mclk.mclk_value = 0;
-	table->ACPIState.levels[0].sclk.vCG_SPLL_FUNC_CNTL = cpu_to_be32(spll_func_cntl);
-	table->ACPIState.levels[0].sclk.vCG_SPLL_FUNC_CNTL_2 = cpu_to_be32(spll_func_cntl_2);
-	table->ACPIState.levels[0].sclk.vCG_SPLL_FUNC_CNTL_3 = cpu_to_be32(spll_func_cntl_3);
-	table->ACPIState.levels[0].sclk.vCG_SPLL_FUNC_CNTL_4 = cpu_to_be32(spll_func_cntl_4);
+	table->ACPIState.level.sclk.vCG_SPLL_FUNC_CNTL = cpu_to_be32(spll_func_cntl);
+	table->ACPIState.level.sclk.vCG_SPLL_FUNC_CNTL_2 = cpu_to_be32(spll_func_cntl_2);
+	table->ACPIState.level.sclk.vCG_SPLL_FUNC_CNTL_3 = cpu_to_be32(spll_func_cntl_3);
+	table->ACPIState.level.sclk.vCG_SPLL_FUNC_CNTL_4 = cpu_to_be32(spll_func_cntl_4);
-	table->ACPIState.levels[0].sclk.sclk_value = 0;
+	table->ACPIState.level.sclk.sclk_value = 0;
-	ni_populate_mvdd_value(rdev, 0, &table->ACPIState.levels[0].mvdd);
+	ni_populate_mvdd_value(rdev, 0, &table->ACPIState.level.mvdd);
 	if (eg_pi->dynamic_ac_timing)
-		table->ACPIState.levels[0].ACIndex = 1;
+		table->ACPIState.level.ACIndex = 1;
-	table->ACPIState.levels[0].dpm2.MaxPS = 0;
-	table->ACPIState.levels[0].dpm2.NearTDPDec = 0;
-	table->ACPIState.levels[0].dpm2.AboveSafeInc = 0;
-	table->ACPIState.levels[0].dpm2.BelowSafeInc = 0;
+	table->ACPIState.level.dpm2.MaxPS = 0;
+	table->ACPIState.level.dpm2.NearTDPDec = 0;
+	table->ACPIState.level.dpm2.AboveSafeInc = 0;
+	table->ACPIState.level.dpm2.BelowSafeInc = 0;
-	table->ACPIState.levels[0].SQPowerThrottle = cpu_to_be32(reg);
+	table->ACPIState.level.SQPowerThrottle = cpu_to_be32(reg);
-	table->ACPIState.levels[0].SQPowerThrottle_2 = cpu_to_be32(reg);
+	table->ACPIState.level.SQPowerThrottle_2 = cpu_to_be32(reg);
 	return 0;
@@ -1980,7 +1980,9 @@ static int ni_init_smc_table(struct radeon_device *rdev)
 	if (ret)
 		return ret;
-	table->driverState = table->initialState;
+	table->driverState.flags = table->initialState.flags;
+	table->driverState.levelCount = table->initialState.levelCount;
+	table->driverState.levels[0] = table->initialState.level;
 	table->ULVState = table->initialState;
diff --git a/drivers/gpu/drm/radeon/nislands_smc.h b/drivers/gpu/drm/radeon/nislands_smc.h
index 7395cb6b3cac6..42f3bab0f9ee6 100644
@@ -143,6 +143,14 @@ struct NISLANDS_SMC_SWSTATE
+struct NISLANDS_SMC_SWSTATE_SINGLE {
+	uint8_t                             flags;
+	uint8_t                             padding2;
+	uint8_t                             padding3;
+	NISLANDS_SMC_HW_PERFORMANCE_LEVEL   level;
 #define NISLANDS_SMC_VOLTAGEMASK_VDDC  0
 #define NISLANDS_SMC_VOLTAGEMASK_MVDD  1
 #define NISLANDS_SMC_VOLTAGEMASK_VDDCI 2
@@ -160,19 +168,19 @@ typedef struct NISLANDS_SMC_VOLTAGEMASKTABLE NISLANDS_SMC_VOLTAGEMASKTABLE;
-    uint8_t                             thermalProtectType;
-    uint8_t                             systemFlags;
-    uint8_t                             maxVDDCIndexInPPTable;
-    uint8_t                             extraFlags;
-    uint8_t                             highSMIO[NISLANDS_MAX_NO_VREG_STEPS];
-    uint32_t                            lowSMIO[NISLANDS_MAX_NO_VREG_STEPS];
-    NISLANDS_SMC_VOLTAGEMASKTABLE       voltageMaskTable;
-    PP_NIslands_DPM2Parameters          dpm2Params;
-    NISLANDS_SMC_SWSTATE                initialState;
-    NISLANDS_SMC_SWSTATE                ACPIState;
-    NISLANDS_SMC_SWSTATE                ULVState;
-    NISLANDS_SMC_SWSTATE                driverState;
-    NISLANDS_SMC_HW_PERFORMANCE_LEVEL   dpmLevels[NISLANDS_MAX_SMC_PERFORMANCE_LEVELS_PER_SWSTATE - 1];
+	uint8_t                             thermalProtectType;
+	uint8_t                             systemFlags;
+	uint8_t                             maxVDDCIndexInPPTable;
+	uint8_t                             extraFlags;
+	uint8_t                             highSMIO[NISLANDS_MAX_NO_VREG_STEPS];
+	uint32_t                            lowSMIO[NISLANDS_MAX_NO_VREG_STEPS];
+	NISLANDS_SMC_VOLTAGEMASKTABLE       voltageMaskTable;
+	PP_NIslands_DPM2Parameters          dpm2Params;
+	struct NISLANDS_SMC_SWSTATE_SINGLE  initialState;
+	struct NISLANDS_SMC_SWSTATE_SINGLE  ACPIState;
+	struct NISLANDS_SMC_SWSTATE_SINGLE  ULVState;
+	NISLANDS_SMC_SWSTATE                driverState;
+	NISLANDS_SMC_HW_PERFORMANCE_LEVEL   dpmLevels[NISLANDS_MAX_SMC_PERFORMANCE_LEVELS_PER_SWSTATE];
 typedef struct NISLANDS_SMC_STATETABLE NISLANDS_SMC_STATETABLE;
cgit 1.2.3-1.el7
Re: Kernel 5.13
The alpha5 of kernel 5.13 is available for testing.
Download: linux-image-5.13-alpha5-X1000_X5000.tar.gz
Hypex
Re: Kernel 5.13
Post by Hypex »
xeno74 wrote: Wed May 05, 2021 12:33 pm In addition, a nice background image for your desktop:
Nice, where is the AmigaOne going? :)
Re: Kernel 5.13
The kernel 5.13 has some unsolved issues and some not integrated patches. Currently it is not possible to release 5.13 kernels because of these issues. The kernel developers haven’t figured out where the problematic code is. We have bisected a lot but the Xorg issue overlaps with a boot issue. We can’t figure out the first bad commit for the Xorg issue if the kernel doesn’t boot in this time where the first bad commit is. Additionally the kernel doesn’t boot in a virtual e5500 QEMU machine anymore since the RC1 of kernel 5.13.
I will skip the kernel 5.13 test time until the RC1 of kernel 5.14.
I can‘t release these unreliable 5.13 kernels for the X1000 and X5000.
In the meantime I will release some stable 5.10 LTS kernels.
They are very stable and there weren’t any issues in the test time. The kernel 5.10 is very modern and offers the same features as the 5.11, 5.12, and 5.13 kernels and is more stable. If you have a new hardware and the kernel 5.10 doesn’t offer a driver for it then you can try the 5.11, 5.12, 5.13 kernels. Additionally I can try to backport the new driver.
