Kernel 5.10
Re: Kernel 5.10
The kernel 5.10.112 is available. - Further information -
Re: Kernel 5.10
Are the driver modules for these chip sets active in the latest 5.10 version: ASM 1042, ASM 1061 and ASM 1182?
I will soon get a combined Sata/USB board which uses those ASM chips.
Re: Kernel 5.10
Yes, they are active but I don’t know if these cards work.Roland wrote: Wed Jun 08, 2022 8:42 am Are the driver modules for these chip sets active in the latest 5.10 version: ASM 1042, ASM 1061 and ASM 1182?
Just for info:
ASM 1042: XHCI USB3
ASM 1061: AHCI SATA (IDE/AHCI mode) if you have some issues then try setenv bootargs “blacklist=pata_acpi …”.
ASM 1182: Bridge PCIe x1 Gen2 to 2 PCIe (Packet switch)
Maybe
CONFIG_HOTPLUG_PCI
CONFIG_HOTPLUG_PCI_S
Re: Kernel 5.10
Thanks for the info! I will report how it works...xeno74 wrote: Wed Jun 08, 2022 6:10 pm ASM 1042: XHCI USB3
Maybe
CONFIG_HOTPLUG_PCI
Re: Kernel 5.10
@xeno74
When testing the Sata controller with a 6G cabable SSD using 'Disks' tool, the read speed (200 MB/s) do not reach the results I got earlier with a separate Sata3 controller (400 MB/s) with the same disk. That would suggest the controller is now working only in Sata2 and not in Sata3 mode. Can you guess any reason for that, and a possible fix...?
I already tested the bootarg you suggested (blacklist=pata_acpi) but it did not have effect on the Sata speed.
I got now the card (https://www.delock.com/produkt/89389/merkmale.html?f=s), and at first glance both the Sata and USB controller are working with LInux/kernel 5.10.Roland wrote: Wed Jun 08, 2022 8:42 am Are the driver modules for these chip sets active in the latest 5.10 version: ASM 1042, ASM 1061 and ASM 1182?
Re: Kernel 5.10
Hi Roland,
Great that it works!
Unfortunately I don’t have any experiences with SATA and USB controller PCIe cards but I have found these instructions:
How to Change SATA Mode in Ubuntu
Re: Kernel 5.10
The problem seems not to be there as diagnostics tools suggest that both 'ahci' and SATA 3 are already in use:xeno74 wrote: Mon Jun 20, 2022 6:27 am Unfortunately I don’t have any experiences with SATA and USB controller PCIe cards but I have found these instructions:
1000:09:00.0 SATA controller: ASMedia Technology Inc. ASM1062 Serial ATA Controller (rev 01) (prog-if 01 [AHCI 1.0])
Subsystem: ASMedia Technology Inc. ASM1062 Serial ATA Controller
Flags: bus master, fast devsel, latency 0, IRQ 47
I/O ports at 3000 [size=8]
I/O ports at 3008 [size=4]
I/O ports at 3010 [size=8]
I/O ports at 3018 [size=4]
I/O ports at 3020 [size=32]
Memory at c20200000 (32-bit, non-prefetchable) [size=512]
Expansion ROM at c20210000 [virtual] [disabled] [size=64K]
Capabilities: [50] MSI: Enable+ Count=1/1 Maskable- 64bit-
Capabilities: [78] Power Management version 3
Capabilities: [80] Express Legacy Endpoint, MSI 00
Capabilities: [100] Virtual Channel
Kernel driver in use: ahci
dmesg | grep -i ahci
Device Model: Seagate BarraCuda 120 SSD ZA250CM10003
Serial Number: 7QT031S0
LU WWN Device Id: 5 000c50 0bb25d527
Firmware Version: STQSC012
User Capacity: 250,059,350,016 bytes [250 GB]
Sector Size: 512 bytes logical/physical
Rotation Rate: Solid State Device
Form Factor: 2.5 inches
Device is: Not in smartctl database [for details use: -P showall]
ATA Version is: ACS-3 (minor revision not indicated)
SATA Version is: SATA 3.1, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is: Mon Jun 20 16:32:31 2022 EEST
SMART support is: Available - device has SMART capability.
SMART support is: Enabled- Roland -
Re: Kernel 5.10
Thanks - it works ok!
Is it worth the effort to report bugs in 5.10, or is it better to do it only for the latest main version? Where should you do it nowadays? I have in mind a bug which forces to use the "mem=3500M" boot poarameter with certain expansion cards. I thought this kind of kernel issues were solved earlier for good...
