Kernel 5.7
Re: Kernel 5.7
daz wrote: Sat May 30, 2020 9:18 pm I use a 5 port hub now, and that doesn't cause problems. Do you have a different router you could try? Or can you connect through a Hub device first?
Darren
I will buy a hub and test.
Re: Kernel 5.7
The final kernel 5.7 is available for our AmigaOnes. Many thanks to all for helping me with testing, reporting, and fixing problems during the kernel 5.7 test time.
Download: linux-image-5.7-X1000_X5000.tar.gz
Re: Kernel 5.7
daz wrote: Sat May 30, 2020 9:18 pm I used to have this when I first got my X5000. I'm told it's due to the ports your X5000 is connected to, apparently some 100Mbit ports don't fully comply and upset the DPAA. I use a 5 port hub now, and that doesn't cause problems. Do you have a different router you could try? Or can you connect through a Hub device first?
I have a Sagemcom modem with gigagabit ethernet ports, so the '100M' is not a valid explanation for this issue. Tested also with an A-Link WNAP router - no difference.
Re: Kernel 5.7
Final Kernel 5.7 up and running on the AmigaOne X5000
Big picture http://www.skateman.nl/wp-content/uploa ... -41-32.png
Thanks so much for all the hard work!
Re: Kernel 5.7
Kernel 5.7 up and running. Many thanks for your ongoing dedication and hard work.
Re: Kernel 5.7
Skateman wrote: Wed Jun 03, 2020 8:47 am Final Kernel 5.7 up and running on the AmigaOne X5000
Many thanks for testing the final kernel 5.7! :-)
acefnq wrote: Wed Jun 03, 2020 12:15 pm Christian
Re: Kernel 5.7
The KVM issue has been fixed in the stable kernel 5.7. :-)
This is a note to let you know that I've just added the patch titled
    powerpc/64s: Fix KVM interrupt using wrong save area
to the 5.7-stable tree which can be found at:
    http://www.kernel.org/git/?p=linux/kernel/git/stable/stable-queue.git;a=summary
The filename of the patch is:
     powerpc-64s-fix-kvm-interrupt-using-wrong-save-area.patch
and it can be found in the queue-5.7 subdirectory.
If you, or anyone else, feels it should not be added to the stable tree,
please let <stable@vger.kernel.org> know about it.
>From 0bdcfa182506526fbe4e088ff9ca86a31b81828d Mon Sep 17 00:00:00 2001
Date: Mon, 15 Jun 2020 16:12:47 +1000
Subject: powerpc/64s: Fix KVM interrupt using wrong save area
commit 0bdcfa182506526fbe4e088ff9ca86a31b81828d upstream.
The CTR register reload in the KVM interrupt path used the wrong save
area for SLB (and NMI) interrupts.
Fixes: 9600f261acaa ("powerpc/64s/exception: Move KVM test to common code")
Cc: stable@vger.kernel.org # v5.7+
Signed-off-by: Nicholas Piggin <npiggin@gmail.com>
Tested-by: Christian Zigotzky <chzigotzky@xenosoft.de>
Link: https://lore.kernel.org/r/20200615061247.1310763-1-npiggin@gmail.com
Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
 arch/powerpc/kernel/exceptions-64s.S |    4 ++--
 1 file changed, 2 insertions(+), 2 deletions(-)
--- a/arch/powerpc/kernel/exceptions-64s.S
+++ b/arch/powerpc/kernel/exceptions-64s.S
@@ -270,7 +270,7 @@ BEGIN_FTR_SECTION
 END_FTR_SECTION_IFSET(CPU_FTR_CFAR)
 	.endif
-	ld	r10,PACA_EXGEN+EX_CTR(r13)
+	ld	r10,IAREA+EX_CTR(r13)
 	mtctr	r10
 BEGIN_FTR_SECTION
 	ld	r10,IAREA+EX_PPR(r13)
@@ -298,7 +298,7 @@ END_FTR_SECTION_IFSET(CPU_FTR_HAS_PPR)
 	.if IKVM_SKIP
 89:	mtocrf	0x80,r9
 	mtctr	r10
 	ld	r9,IAREA+EX_R9(r13)
 	ld	r10,IAREA+EX_R10(r13)
Patches currently in stable-queue which might be from npiggin@gmail.com are
queue-5.7/powerpc-64s-kuap-add-missing-isync-to-kuap-restore-p.patch
queue-5.7/powerpc-64s-exceptions-machine-check-reconcile-irq-s.patch
queue-5.7/powerpc-64s-fix-kvm-interrupt-using-wrong-save-area.patch
queue-5.7/powerpc-book3s64-radix-tlb-determine-hugepage-flush-.patch
queue-5.7/powerpc-64s-exception-fix-machine-check-no-loss-idle.patch
queue-5.7/powerpc-pseries-ras-fix-fwnmi_valid-off-by-one.patch
Re: Kernel 5.7
I released the stable kernel 5.7.6 today.
Download: linux-image-5.7.6-X1000_X5000.tar.gz
The stable kernel 5.7.6 works with an ATi Radeon X1950 PRO Extreme:
Re: Kernel 5.7
xeno74 wrote: Sun May 31, 2020 4:27 am
Christian, did you already get and test a hub...? Did that solve the problem?
I have not yet found any solution to the 'uplug/replug' problem. I tested in Network settings all the different options of 'Link negotiation' (ignore/automatic/manual -> 10M/100M/1G full/halfduplex), but that did not help. Tested also different ethernet cables, no difference.
I just found a working SoundBlaster Live! board and would now like to free a PCI slot for it. Are there any PCIe ethernet boards which would work with PPC Linux? (USB-ethernet dongle does not sound a good solution as the USB ports of X5000 are only v. 2.0).
Re: Kernel 5.7
Roland wrote: Sat Jul 18, 2020 11:09 am Christian, did you already get and test a hub...? Did that solve the problem?
No, I haven’t test it with a hub yet.
