Arctic Fox
I compiled Arctic Fox 40.0 with the following mozconfig for Linux PowerPC today.
.mozconfig for 32-bit userlands with 64-bit kernels:
# This Source Code Form is subject to the terms of the Mozilla Public
# License, v. 2.0. If a copy of the MPL was not distributed with this
# file, You can obtain one at http://mozilla.org/MPL/2.0/.
export CC="gcc -m32 -flax-vector-conversions -O3 -falign-loops=16 -falign-functions=16 -falign-labels=16 -falign-jumps=16"
export CXX="g++ -m32 -flax-vector-conversions -fpermissive -O3 -falign-loops=16 -falign-functions=16 -falign-labels=16 -falign-jumps=16"
export LDFLAGS="-latomic"
mk_add_options MOZ_OBJDIR=@TOPSRCDIR@/obj-ff-dbg
ac_add_options --enable-mozril-geoloc
ac_add_options --disable-parental-controls
ac_add_options --enable-release
ac_add_options --disable-eme
ac_add_options --enable-dbus
ac_add_options --disable-gio
ac_add_options --enable-strip
ac_add_options --enable-install-strip
ac_add_options --enable-application=browser
ac_add_options --with-branding=browser/branding/arcticfox
ac_add_options --disable-gstreamer
ac_add_options --target=powerpc-linux-gnu
ac_add_options --host=powerpc-linux-gnu
Download: arcticfox-40.0.linux-powerpc.tar.bz2
It works on Void PPC, MintPPC (Debian Sid), Fienix and also on an old Ubuntu 10.04.
I compiled Arctic Fox 40.0 for Linux PPC64 and then I successfully tested it on Debian PPC64 Bookworm/Sid.
Download: arcticfox-40.0.linux-powerpc64.tar.bz2
For Linux PPC 32-bit (Ubuntu 10.04 and higher): arcticfox-40.0.linux-powerpc.tar.bz2
Screenshot of Arctic Fox 40.0 on Debian PPC64 Bookworm/Sid:
Hi Christian.
I have tested Arctic_fox in Debian bookworms64 and Mint 32. Everything works as it should.
Thanks for all the great work you do for Linux ppc on the Amiga.
Have a nice day.
musa wrote: Sun Nov 27, 2022 2:25 pm Hi Christian.
Have a nice day.
Great, that the 32-bit and 64-bit version work on your Linux distributions. Thanks a lot for testing! :-)
I compiled Arctic Fox 40.0 for Linux PPC64 with AltiVec support and then I successfully tested it on Debian PPC64 Bookworm/Sid.
Download: arcticfox-40.0.linux-powerpc64-altivec.tar.bz2
For Linux PPC 32-bit without AltiVec (Ubuntu 10.04 and higher): arcticfox-40.0.linux-powerpc.tar.bz2
Screenshot of Arctic Fox 40.0 with AltiVec support on Debian PPC64 Bookworm/Sid:
Hi
Adelie ppc 32 bit with vmlinux-6.2_rc1
Have a nice day
Arctic Fox 40.1 has been released.
New: github.com
Download source code: v40.1.tar.gz
I compiled a non-altivec 32-bit version for Ubuntu 10.04 and higher. It also works on Void PPC, MintPPC (Debian Sid), Fienix etc.
Download: arcticfox-40.1.linux-powerpc.tar.bz2
Mario Locati wrote: Hi Christian! Happy new year! I noticed that you compiled the new version of arcticfox 40.1, I have prepared a miniguide on how to generate the deb file starting from the tar.gz that is created using "mach package", http://repo.powerprogress.org/temp/arct ... b_file.txt
how_to_generate_arcticfox_deb_file.txt:
get the template folder
> wget http://repo.powerprogress.org/temp/arcticfox/_arcticfox-template.zip
unzip the template folder
> unzip _arcticfox-template.zip
copy the template folder into a new folder that will be used to generate the deb file
> cp -R _arcticfox-template arcticfox-40.0
customize the control file (version, architecture, installed-size, maintener, description)
> nano arcticfox-40.0/DEBIAN/control
extract the content of the tar.gz into the folder "usr/share/arcticfox" so that the arcticfox main executable is placed in this folder
enter the parent folder containg the folder "arcticfox-40.0" and generate the deb file
> dpkg-deb --build arcticfox-40.0
rename the deb file using the following naming scheme
> ren arcticfox-40.0.deb arcticfox-40.0.linux-ppc64-with-altivec.deb
> ren arcticfox-40.0.deb arcticfox-40.0.linux-ppc64-no-altivec.deb
> ren arcticfox-40.0.deb arcticfox-40.0.linux-powerpc-with-altivec.deb
> ren arcticfox-40.0.deb arcticfox-40.0.linux-powerpc-no-altivec.deb
I compiled a PowerPC64/AltiVec version of Arctic Fox 40.1 today.
Download: arcticfox-40.1.linux-powerpc64-altivec.tar.bz2
