kilaueabart wrote: Mon Jan 17, 2022 9:07 pm Void likes 17a4 OK
Thanks for testing! :-)
The alpha5 of kernel 5.17 is available for testing.
Download: linux-image-5.17-alpha5-X1000_X5000.tar.gz
Note: XFS is great! You can grow the XFS filesystem without unmounting the hard disk/partition or virtual img after resizing the virtual img with "qemu-img resize" or after copying an img to a hard disk/partition. You can format a hard disk or img without creating any partitions.
Maybe Void doesn't like 5.17a5? I had a lot of trouble getting it started, so I'm using InterWeb. But I seem to have Eolie (which I really need!) working on Workspace 2 now.
kilaueabart wrote: Sun Jan 23, 2022 1:31 am Maybe Void doesn't like 5.17a5? I had a lot of trouble getting it started, so I'm using InterWeb. But I seem to have Eolie (which I really need!) working on Workspace 2 now.
Which trouble did you have? Thanks for testing.
— Christian
Kernel 5.17 Alpha 5 up and running on my AmigaOne X5000
Big picture : https://www.skateman.nl/wp-content/uplo ... 172027.png
Skateman wrote: Sun Jan 23, 2022 5:22 pm Kernel 5.17 Alpha 5 up and running on my AmigaOne X5000
xeno74 wrote: Sun Jan 23, 2022 8:54 am
The first time I ran void with a5, Eolie came up but would not load a web page (this one, or my email). And I couldn't move it on screen, or turn it off. So I rebooted, but it told me Eolie was still running, and took a long time for the machine to shut down and restart. Then at first Eolie refused to launch, so I went to InterWeb, but meanwhile I tried Eolie on a different workspace and this time, no problem!
Will see how it does with RC1 in a little while.
Kernel 5.17 RC1 up and running on my AmigaOne X5000
Big picture : https://www.skateman.nl/wp-content/uplo ... 192540.png
My new sanitized kernel works good,
Like an RC1 should.
