Kernel 5.8
Re: Kernel 5.8
Kernel 5.8 RC2 running fine on the AmigaOne X5000. Also the onboard Ethernet adapter is working great!
Big picture: http://www.skateman.nl/wp-content/uploa ... 213506.png
Re: Kernel 5.8
Skateman wrote: Mon Jun 22, 2020 9:38 pm Kernel 5.8 RC2 running fine on the AmigaOne X5000. Also the onboard Ethernet adapter is working great!
Re: Kernel 5.8
Alexander has replied because of our test results.
Alexander Gordeev wrote: Hi Christian,
Could you please check if the kernel passes CONFIG_TEST_BITMAP self-test?
Thanks!
I compiled a test kernel with the option "CONFIG_TEST_BITMAP=y" today. Could you please boot it and look for the bitmap tests with "dmesg | grep -i bitmap"?
Download: uImage-dpaa18
Re: Kernel 5.8
Bitmap test result from my X5000/40:
[    0.296563] test_bitmap: loaded.
[    0.296894] test_bitmap: parselist: 14: input is '0-2047:128/256' OK, Time: 540
[    0.296920] test_bitmap: parselist_user: 14: input is '0-2047:128/256' OK, Time: 680
[    0.299994] test_bitmap: all 1663 tests passed
Re: Kernel 5.8
Kernel 5.8 DPAA18 Breaks the onboard Ethernet adapter
Big picture http://www.skateman.nl/wp-content/uploa ... 221604.png
skateman@X5000LNX:~$ dmesg | grep -i bitmap
[    0.297756] test_bitmap: loaded.
[    0.298113] test_bitmap: parselist: 14: input is '0-2047:128/256' OK, Time: 562
[    0.298142] test_bitmap: parselist_user: 14: input is '0-2047:128/256' OK, Time: 761
[    0.301553] test_bitmap: all 1663 tests passed
Re: Kernel 5.8
Skateman wrote: Wed Jun 24, 2020 8:22 pm Kernel 5.8 DPAA18 Breaks the onboard Ethernet adapter
Thanks a lot for testing! I reported our test results to Alexander today.
Link to the test thread: FSL P5020/P5040: DPAA Ethernet issue with the latest Git kernel -- Linuxppc-dev mailing list
Re: Kernel 5.8
FYI because of the DPAA Ethernet issue:
Alexander Gordeev wrote: Thanks for the test! So it works as expected.
I would suggest to compare what is going on on the device probing
with and without the bisected commit.
There seems to be MAC and PHY mode initialization issue that might
resulted from the bitmap format change.
I put Madalin and Sascha on CC as they have done some works on
this part recently.
Thanks!
OK, we have to wait. I will patch the RC3 with our dpaa-v1 patch again.
Re: Kernel 5.8
I released the RC3 of kernel 5.8 for the X1000 and X5000 today.
Download: linux-image-5.8-rc3-X1000_X5000.tar.gz
Re: Kernel 5.8
Kernel 5.8 RC3 running fine on the AmigaOne X5000
Big picture http://www.skateman.nl/wp-content/uploa ... 224956.png
