Kernel 5.3
Re: Kernel 5.3
xeno74 wrote:Hi All,
I released a new device tree blob for the Tabor board today.
Download: Tabor_device_tree_blob_0.3.tar.gz
I released a device tree blob without fsl,eloplus-dma-channel support for testing today.
Download: tabor4.dtb
Re: Kernel 5.3
nbache wrote:
kilaueabart wrote:IOn Ubuntu I can easily use Hyperion Message Boards with Arctic Fox. Why do I always have to log in if I go there on Fienix? I always end up switching to New Moon, which knows who I am.
On the login page, there's a checkbox "login automatically each visit" or similar.
Did you forget to set that?
It saves the choice as a cookie locally in the browser, i.e. it has to be set for each browser in each system.
No, I have clicked on that square, got the check mark, then logged on dozens of times by now. Including the time before this, a few minutes ago. It never does any good.
Another slightly similar difference between Ubuntu and Fienix Arctic Fox. On Ubuntu, "Most Visited" fills up and makes a handy bookmarks susbstitute. It's always empty on Fienix.
Re: Kernel 5.3
kilaueabart wrote:Does this look right, have I done the module properly?
Yes it's correct! :-)
Except I shouldn't have removed the one for Kernel 5.2. I have noticed some problems since moving to 5.3 but I'm not sure I didn't have them before.
I no longer get a Bluetooth icon in the top right panel. I know I used get it to because I mentioned in another post that my (non-working) iBus icon was between it and the speaker icon.
Also nothing in that panel to set up Wi-Fi with. Only internet related thing is "Device Details for enP4096p4s4."
I doubt either of these matters relate to the kernel. It's just that I had not noticed them until after changing. So I am going to try to get 5.2 back in there and see.
Re: Kernel 5.3
kilaueabart wrote:No, I have clicked on that square, got the check mark, then logged on dozens of times by now. Including the time before this, a few minutes ago. It never does any good.
Hmm, sounds like the cookie isn't saved - maybe something in the browser settings is set to not accept/save cookies?
This almost sounds like you're running in "private mode" (or whatever it's called in that browser). Could be related.
caseycullen
Re: Kernel 5.3
Post by caseycullen »
I'll look into this but I'm going to move my answer to the Fienix thread since it's not related to the kernel.
-Casey
Re: Kernel 5.3
nbache wrote:Hmm, sounds like the cookie isn't saved - maybe something in the browser settings is set to not accept/save cookies?
By golly, Niels, that was it! I found an "Arctic Fox will: Never remember history" in Tools > Preferences > Privacy. A note below the setting said it would be like Privacy mode. I'm going to feel pretty stupid for a couple of hours. Fortunately my short term memory is on its way out. (But just maybe I'll think to look at Preferences if I have odd problems again.)
Re: Kernel 5.3
I mentioned about my Modules folder
kilaueabart wrote: Except I shouldn't have removed the one for Kernel 5.2. I have noticed some problems since moving to 5.3 but I'm not sure I didn't have them before.
Sure enough, I get the Bluetooth icon if I run Kernel 5.2 but no icon with 5.3.
Re: Kernel 5.3
Sorry my statement was incorrect. You copied the directory 5.3.0-rc6_A-EON_X5000 to /modules but the correct directory is /lib/modules/.
This is the reason that the Bluetooth icon isn't displayed. Please copy the directory 5.3.0-rc6_A-EON_X5000 to /lib/modules/.
Re: Kernel 5.3
xeno74 wrote:... You copied the directory 5.3.0-rc6_A-EON_X5000 to /modules but the correct directory is /lib/modules/.
I didn't think it looked right; glad I asked.
/lib/modules is now stuffed with 12 kernel modules. About time I cleaned most of them out.
Re: Kernel 5.3
Here is the RC8 of kernel 5.3 for the X5000, X1000, and A1222.
Download: linux-image-5.3-rc8-X1000_X5000_A1222.tar.gz
Screenshot of kernel 5.3-rc8 in a virtual e500v2 QEMU machine:
