javierdlr
Post by javierdlr »
Shamron wrote:This might be a hilariously stupid question, but i've downloaded the .img file, but how do i extract it (or the likes) to a usb drive? simply copy it or?
Just check this thread: http://forum.hyperion-entertainment.biz ... =52&t=3368
Sam460 Kernels 4.6.3 and 4.4.14 (Boot only from U-boot shell from USB thumb drive or tftp server).
Bluetooth, Wireless dongle and Webcam tested with the 4.6.3 kernel .
https://www.dropbox.com/s/9sydksrk0epk0 ... ar.gz?dl=0
https://www.dropbox.com/s/ppdbht2xf9t00 ... ar.gz?dl=0
Spectre660 wrote:Sam460 Kernels 4.6.3 and 4.4.14 (Boot only from U-boot shell from USB thumb drive or tftp server).
Many thanks for compiling the new kernels! :-)
javierdlr
Post by javierdlr »
Just tested kernel 4.6.3 with tftpboot, and worked fine. THX
Sam460 Kernel 4.7.0 ( Boots only from U-boot shell from USB thumb drive or tftp server).
Includes the new sam460-2.dtb file for kernel 4.7 kernels and beyond.
The kernel also works with the old sam460ex.dtb file.
https://www.dropbox.com/s/1dcnlzfbnf2fc ... ar.gz?dl=0
javierdlr
Post by javierdlr »
Spectre660 wrote:Sam460 Kernel 4.7.0 ( Boots only from U-boot shell from USB thumb drive or tftp server).
Great job!!!!!
Tested using TFTP and no problem loading such kernel.
BTW (I already asked this long time ago) has such kernel 3d support for radeonHD6000 series cards?
an  1 01:00:18 Sam460ex kernel: [    3.800731] [drm] Loading TURKS Microcode
Jan  1 01:00:18 Sam460ex kernel: [    3.804797] [drm] Internal thermal controller with fan control
Jan  1 01:00:18 Sam460ex kernel: [    3.812098] [drm:radeon_pm_init] *ERROR* radeon: dpm initialization failed
Jan  1 01:00:18 Sam460ex kernel: [    3.819230] [drm] GART: num cpu pages 262144, num gpu pages 262144
Jan  1 01:00:18 Sam460ex kernel: [    3.855411] [drm] PCIE GART of 1024M enabled (table at 0x0000000000162000).
Jan  1 01:00:18 Sam460ex kernel: [    3.862678] radeon 0001:81:00.0: WB enabled
Jan  1 01:00:18 Sam460ex kernel: [    3.866920] radeon 0001:81:00.0: fence driver on ring 0 use gpu addr
0x0000000040000c00 and cpu addr 0xffc01c00
Jan  1 01:00:18 Sam460ex kernel: [    3.877052] radeon 0001:81:00.0: fence driver on ring 3 use gpu addr
0x0000000040000c0c and cpu addr 0xffc01c0c
Jan  1 01:00:18 Sam460ex kernel: [    3.903771] radeon 0001:81:00.0: fence driver on ring 5 use gpu addr
0x0000000000072118 and cpu addr 0xf9032118
Jan  1 01:00:18 Sam460ex kernel: [    3.913937] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
Jan  1 01:00:18 Sam460ex kernel: [    3.920578] [drm] Driver supports precise vblank timestamp query.
Jan  1 01:00:18 Sam460ex kernel: [    3.926701] radeon 0001:81:00.0: radeon: MSI limited to 32-bit
Jan  1 01:00:18 Sam460ex kernel: [    3.932580] ppc4xx_setup_msi_irqs: fail allocating msi interrupt
Jan  1 01:00:18 Sam460ex kernel: [    3.938684] [drm] radeon: irq initialized.
Jan  1 01:00:18 Sam460ex kernel: [    4.121623] [drm:r600_ring_test] *ERROR* radeon: ring 0 test failed
(scratch(0x8504)=0xCAFEDEAD)
Jan  1 01:00:18 Sam460ex kernel: [    4.130468] radeon 0001:81:00.0: disabling GPU acceleration
@javierdlr
Thanks for testing.
Sorry no 3d support.
once the drm:r600_ring_test error is encountered GPU acceleration is disabled.
It may have something to do with lack of cache coherency on the 460ex.
Only the top Linux DRM guys could look in to this properly but they really don't have the time.
Generally only if some problem due to new code turns up will it be looked at , once we bring the issue to their attention.
Both the powerpc and DRM guys have been supportive in these new issues.
Sam460 Kernel 4.7.2 ( Boots only from U-boot shell from USB thumb drive or tftp server).
https://www.dropbox.com/s/xx9a105yxhd6z ... ar.gz?dl=0
Sam460 Kernel 4.4.19 ( Boots only from U-boot shell from USB thumb drive or tftp server).
https://www.dropbox.com/s/k1p3tr9dta2vp ... ar.gz?dl=0
Sam460 Kernels 4.4.21 and 4.7.4 ( Boot only from U-boot shell from USB thumb drive or tftp server).
https://www.dropbox.com/s/sk7nveuowhg2n ... ar.gz?dl=0
https://www.dropbox.com/s/jicrgkwvpotjq ... ar.gz?dl=0
