Void Linux
Re: Void Linux
I tried to set up a printer under Void (For example an HP/Samsung laser printer)
  1. Code: Select all
    sudo xbps-install -S void-repo-nonfree cups-filters gutenprint system-config-printer cups-pk-helper hplip foomatic-db foomatic-db-nonfree brother-brlaser avahi nss-mdns cups
  2. Code: Select all
    sudo ln -s /etc/sv/cupsd /var/service
  3. Code: Select all
    sudo ln -s /etc/sv/avahi-daemon /var/service
  4. Code: Select all
    sudo sv status cupsd
  5. Code: Select all
    sudo sv status avahi-daemon
  6. Code: Select all
    Reboot
  7. Menu System - Administration - Print Settings
  8. Button "Unlock" (Password)
  9. Button "Add"
  10. Select Device - Devices - Network Printer - Samsung ML-2525W
  11. Select Connection "LPD network printer via DNS-SD"
  12. Choose driver "Generic" - "PCL 5e - Generic PCL 5e Printer - CUPS+Gutenprint v5.3.4 Simplified [en] (recommended)"
Device URI: dnssd://Samsung%20ML-2525W%20(SEC001599878270)._printer._tcp.local/
The official HP/Samsung laser printer driver is only for for ARM, i386, and for x86_64 available. But ... the generic PCL 5e printer supports my HP/Samsung laser printer. :-)
Unfortunately it doesn't print (Filters failed). It works on MintPPC with the same settings.
Re: Void Linux
Hi
I reinstalled VOID today and am having trouble starting apache.
I think that it is because httpd did not run either.
Someone who can guide me further in VOID
Thanks in advance
Re: Void Linux
musa wrote: Sun Jun 19, 2022 12:34 pm Hi
Thanks in advance
Hi Musa,
Please try:
sudo ln -s /etc/sv/apache /var/service/apache
sudo sv start apache
BTW, I have found great instructions for installing LAMP on Void Linux.
Link: How to install LAMP in Void Linux -- github.com
Have a nice day. :-)
Re: Void Linux
Hi Christian
Many thanks that guide was just what I was missing.
I had some issues with the phpmyadmin user but resolved it with this in a terminal.
mysql (enter)
MariaDB [(none)]> GRANT SELECT, INSERT, UPDATE, DELETE ON phpmyadmin. * TO 'pma' @ 'localhost' IDENTIFIED BY 'password'; (enter)
MariaDB [(none)]> CREATE USER myadmin; (enter) (where mayadmin is the phpmyadmin user and password the new password)
MariaDB [(none)]> GRANT ALL PRIVILEGES ON *. * TO 'myadmin' @ 'localhost' IDENTIFIED BY 'password' WITH GRANT OPTION; (enter)
MariaDB [(none)]> FLUSH PRIVILEGES; (enter)
MariaDB [(none)]> EXIT; (enter)
After this I could log in to phpmyadmin (http: // localhost / phpmyadmin)
Thanks for the help
Peter
Re: Void Linux
@Peter
Well done! :-)
Re: Void Linux
Hi
today I have customized my php.ini and then installed a copy of my joomla website in localhost. Everything works.
I have set up my hp premium c309g and it works too.
i found this version of Void to work really well.
Regards Peter
Re: Void Linux
musa wrote: Mon Jun 20, 2022 8:50 pm Hi
Regards Peter
Great! :-)
Re: Void Linux
Hi
I have compile and install Worker 4.10.1 today in Void.
Code is herhttp://www.boomerangsworld.de/cms/worker/download.html
Have a nice day
Peter
Re: Void Linux
musa wrote: Wed Jun 22, 2022 10:22 pm Hi
Have a nice day
Peter
Great! :-)
Re: Void Linux
Project status update for 2023
Last year I wrote about the plans for phasing out of big endian support in the project by the end of 2022. This is now being changed. Instead, I will cease maintenance of the project as a whole beginning January 2023.
That means if the project is to continue, somebody else will have to take over. They will need to provide their own build infrastructure as well as everything else, as the public repository hosting will be shutting down as well.
The main reason for dropping of the project is that I have been working on a new distro, Chimera Linux. The new project is fully supported on the POWER architecture (and others) and is currently in heavy development (but expected to stabilize during 2022). Users are encouraged to migrate to it once that happens.
I have been thinking about this a lot and came to the conclusion that there is no reason to keep up maintenance of both projects. Chimera is explicitly designed to address various shortcomings of Void while retaining most, if not all of Void’s good aspects. That means Chimera should make for a good successor of the project.
Additionally, big endian support may be coming back in Chimera, at very least for 64-bit POWER. The viability of 32-bit PowerPC support will be evaluated as well. However, this will only happen after the project has stabilized its tier 1 architectures (ppc64le, x86_64 and aarch64). We will be introducing RISC-V 64-bit support as well for those interested.
In the end, the only loss is support for the glibc C library, as Chimera is a musl-only distribution. However, since musl is first-class in the project, the overall level of polish should be a lot better than in Void, and for most users there should be no need for concern, especially on the POWER architecture where there are no proprietary NVIDIA drivers and other things that would be of concern. Containers, flatpak and other solutions should prove effective enough in addressing glibc application compatibility.
If you are interested, feel free to stop by in any of our main channels. There are links on the Chimera website. I will probably not update this page any more, but will keep it running for the foreseeable future (the repositories will shut down next year, however).
