Kernel 5.10
Re: Kernel 5.10
Downloaded RC4 yesterday, have been using several hours today.
Re: Kernel 5.10
kilaueabart wrote: Tue Nov 17, 2020 11:00 pm Downloaded RC4 yesterday, have been using several hours today.
Great! Thanks for testing! :-)
Re: Kernel 5.10
I released the RC5 of kernel 5.10 for the X1000 and X5000 today.
Download: linux-image-5.10-rc5-X1000_X5000.tar.gz
Screenshot of Fienix with the RC5 and with a virtual MintPPC with also the RC5 in a QEMU/KVM HV machine:
Re: Kernel 5.10
RC5 up and running with no issues. many thanks.
Re: Kernel 5.10
acefnq wrote: Sun Nov 29, 2020 7:58 am Christian
Hi Ace,
Thanks a lot for testing the RC5! :-)
daz
Re: Kernel 5.10
Post by daz »
Skateman wrote: Wed Nov 11, 2020 5:21 pm
xeno74 wrote: Wed Nov 11, 2020 11:14 am
Skateman wrote: Tue Nov 10, 2020 6:42 pm I think that you are still using an internal PCI ethernet adapter as well.
No, it isn’t an internal PCI ethernet adapter installed in my MorphOS compatible X5000 because MorphOS can use the onboard ethernet without any problems.
OK, so it has to be the Linux configuration.
Yes, so It would seem, I did ask some of you to try a slightly different kernel: see here: viewtopic.php?p=51504#p51504
Not had any reports yet..
Regards
Darren
Re: Kernel 5.10
daz wrote: Sun Nov 29, 2020 10:42 pm Yes, so It would seem, I did ask some of you to try a slightly different kernel: see here: viewtopic.php?p=51504#p51504
Regards
Darren
Hi Darren,
I tried your kernel today but without any success.
device (eth0): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'managed')
device (eth1): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'managed')
manager: NetworkManager state is now DISCONNECTED
Re: Kernel 5.10
daz wrote: Sun Nov 29, 2020 10:42 pm ... I did ask some of you to try a slightly different kernel: see here: viewtopic.php?p=51504#p51504
Sorry... I had already forgotten that when I finally get back to my X5000. But now I tested it, and there was no change... Onboard ethernet still needs the 'unplug-replug' trick to work.
Re: Kernel 5.10
xeno74 wrote: Mon Nov 30, 2020 1:59 pm Here is the RC6 of kernel 5.10 for testing.
Works ok with MintPPC. Onboard ethernet starts only after unplug-replug...
