Kernel 5.3
Re: Kernel 5.3
Skateman wrote:Kernel 5.3 RC6 is up and running on the AmigaOne X5000 :-)
Skateman,
Have a nice day!
Re: Kernel 5.3
There was an issue with rebooting the Tabor board. I successfully modified the code for the reboot support. Now you can reboot the Tabor board without any problems.
Download: linux-image-5.3-rc6-3-A1222.tar.gz (including a new Tabor patch and kernel config)
BTW, I successfully tested Fienix on the Tabor board yesterday.
Screenshot of Fienix on the Tabor board:
PLEASE PLEASE test the RC6 on the X1000, X5000 and A1222. It's very important, that you test the new kernels.
Re: Kernel 5.3
I would love to help you out with testing the kernels, but without the possibility to buy the Tabor hardware its a no go! I have tried to apply for some beta testing by sending a mail but never got any response. I have contacted Trevor who redirects me back to Matthew.......
Re: Kernel 5.3
RC6 up and running, Firepro and Logitech mouse working fine. Helped when I downloaded the correct archive! -:)
Re: Kernel 5.3
acefnq wrote:RC6 up and running, Firepro and Logitech mouse working fine. Helped when I downloaded the correct archive! -:)
Hi Ace,
Thanks a lot for testing the RC6! :-)
Re: Kernel 5.3
I haven't been keeping up. Finally got a 5.3, fienix only, so far.
Lack of practice plus creeping dementia made it a hard change. Tried Ubuntu first, but it kept telling me my SD card was neither a file nor a directory. Fienix much nicer, and the kernel is now where it belongs.
Something else I don't remember. Does this look right, have I done the module properly?
fienix@Fienix:~$ ls /
bin   dev  home  lost+found  mnt      proc  run   srv  tmp  var
boot  etc  lib	 media	     modules  root  sbin  sys  usr
fienix@Fienix:~$ ls /modules
5.3.0-rc6_A-EON_X5000
On Ubuntu I can easily use Hyperion Message Boards with Arctic Fox. Why do I always have to log in if I go there on Fienix? I always end up switching to New Moon, which knows who I am.
Re: Kernel 5.3
kilaueabart wrote:Does this look right, have I done the module properly?
Yes it's correct! :-)
Re: Kernel 5.3
kilaueabart wrote:IOn Ubuntu I can easily use Hyperion Message Boards with Arctic Fox. Why do I always have to log in if I go there on Fienix? I always end up switching to New Moon, which knows who I am.
On the login page, there's a checkbox "login automatically each visit" or similar.
Did you forget to set that?
It saves the choice as a cookie locally in the browser, i.e. it has to be set for each browser in each system.
Re: Kernel 5.3
I released a new device tree blob for the Tabor board today.
Download: Tabor_device_tree_blob_0.3.tar.gz
