Fienix 6.0.1
Re: Fienix 6.0.1
I was able to expand the file system with resize2fs to the new size of the disk image after qemu-img resize.
resize2fs fienix_6.0.1-noboot-r1.img
Re: Fienix 6.0.1
The latest version of QEMU with Fienix 6.0.1:
Re: Fienix 6.0.1
Fienix 6.0.1 in a virtual QEMU PowerPC machine connected via a virtual bridge to the network:
caseycullen
Re: Fienix 6.0.1
Post by caseycullen »
xeno74 wrote: Tue Mar 14, 2023 5:29 pm I was able to expand the file system with resize2fs to the new size of the disk image after qemu-img resize.
I updated the "noboot" image on March 8. With this image, I believe you should be able to dd it to a partition, then run "fsck -f -y /dev/partition", then "resize2fs /dev/partition" without the large space requirement.
-Casey
Re: Fienix 6.0.1
caseycullen wrote: Thu Mar 16, 2023 9:24 pm I updated the "noboot" image on March 8. With this image, I believe you should be able to dd it to a partition, then run "fsck -f -y /dev/partition", then "resize2fs /dev/partition" without the large space requirement.
-Casey
I think, it could work if I dd it to a large partition but in the superblock on the img itself, there is an entry with a bigger size than the disk image is so it can’t boot from the disk image directly.
Re: Fienix 6.0.1
xeno74 wrote: Fri Mar 17, 2023 6:44 am
-Casey
Screenshot:
Re: Fienix 6.0.1
sailorMH wrote: Mon May 15, 2023 9:14 pm Are there some tips how to speedup Fienix? I have to look for system services.
Glxgears with Fienix + Mate has cca 1200 FPS and Debian Sid + Mate cca 2200 FPS with the same card. Also my feeling is that fienix desktop is a liitle slower.
Link to the thread: Fienix 6.0.1 - X1000 thread
Do you have the same experiences?
Re: Fienix 6.0.1
xeno74 wrote: Tue May 16, 2023 8:40 am Link to the thread: Fienix 6.0.1 - X1000 thread
Nope... I tested with Fienix6, MintPPC, Ubuntu16 and Void, and got the same result (60 FPS) with all of them. The graphics card was a Radeon HD 6450.
Could the difference seen by sailor be related to altivec, as she has a X1000? Whether it is used or not on a certain distro...?
Re: Fienix 6.0.1
Roland wrote: Tue May 16, 2023 10:47 am
Roland,
Have you tested glxgears with vblank_mode=0?
vblank_mode=0 glxgears
Re: Fienix 6.0.1
xeno74 wrote: Tue May 16, 2023 11:34 am
With that option I get quite different results:
Fienix6   2000 FPS
MintPPC   2900 FPS
Ubuntu16  2100 FPS
Void      3300 FPS
