Kernel 5.5
Re: Kernel 5.5
The final kernel 5.5 is available for our AmigaOnes. Many thanks to all for helping me with testing, reporting, and fixing problems during the kernel 5.5 test time.
Download: linux-image-5.5-X1000_X5000.tar.gz
Re: Kernel 5.5
I released the stable kernel 5.5.3 today.
  • X5000 and X1000: "conntrack" connection tracking match support (CONFIG_NETFILTER_XT_MATCH_CONNTRACK) and Connection state matching (CONFIG_NETFILTER_XT_MATCH_STATE). Allows you to match packets based on their relationship to a tracked connection (ie. previous packets). These are great solutions for a desktop firewall. Examples:
    iptables -F
    iptables -t filter -A INPUT -j DROP
    iptables -t filter -I INPUT -m conntrack --ctstate ESTABLISHED,RELATED -j ACCEPT
    or
    iptables -F
    iptables -t filter -I INPUT -m state --state ESTABLISHED,RELATED -j ACCEPT
    Basically, all network connections are blocked from the outside except our system has established the connections.
  • X5000: Add OF_DMA_DEFAULT_COHERENT & select it on powerpc (We don't need the coherent_cache-v4 patch anymore)
  • Linux Git log
  • Phoronix articles, reviews and news stories covering Linux 5.5
Download: linux-image-5.5.3-X1000_X5000.tar.gz
Kernel 5.5.3 with iptables and Pure-FTPd:
Kernel 5.5.3 with iptables and Pure-FTPd in the NAT mode:
Re: Kernel 5.5
The stable kernel 5.5.4 is available.
  • X5000 and X1000: CONFIG_NETFILTER_XT_MATCH_LIMIT (Limit matching allows you to control the rate at which a rule can be matched: mainly useful in combination with the LOG target and to avoid some Denial of Service attacks).
    For example:
    iptables -A INPUT -m tcp -p tcp --dport 22 -m state
    --state NEW -m limit --limit 3/hour --limit-burst 3 -j ACCEPT
    iptables -A INPUT -m tcp -p tcp --dport 22 -j DROP
  • Linux Git log
Download: linux-image-5.5.4-X1000_X5000.tar.gz
Re: Kernel 5.5
I released the stable kernel 5.5.5 today.
  • X5000 and X1000: NETFILTER_XT_MATCH_MULTIPORT (Multiport matching allows you to match TCP or UDP packets based on a series of source or destination ports: normally a rule can only match a single range of ports.)
    For example for fail2ban (IPS, Intrusion Prevention System):
    -A INPUT -p tcp -m multiport --dports 22 -j fail2ban-ssh
    -A fail2ban-ssh -s 87.193.135.42/32 -j DROP
    -A fail2ban-ssh -s 79.193.45.193/32 -j DROP
    -A fail2ban-ssh -j RETURN
  • Linux Git log
Download: linux-image-5.5.5-X1000_X5000.tar.gz
Re: Kernel 5.5
I released the stable kernel 5.5.11 for the X5000 and X1000 today.
Download: linux-image-5.5.11-X1000_X5000.tar.gz
