Kernel 5.3
Re: Kernel 5.3
RC4 is running fine on the AmigaOne X5000
Big picture http://www.skateman.nl/wp-content/uploa ... 204330.png
Re: Kernel 5.3
Skateman wrote:RC4 is running fine on the AmigaOne X5000
Many thanks for testing the RC4 with your X5000. :-)
Re: Kernel 5.3
RC4 boots to Firepro and Logitech mouse works fine. I'll let Hans know.
Re: Kernel 5.3
acefnq wrote:Christian
Re: Kernel 5.3
I released the RC5 of kernel 5.3 for testing today.
  • Initial ramdisks for the X5000 and X1000. Instructions for creating an initial ramdisk: forum.hyperion-entertainment.com
Download: linux-image-5.3-rc5-X1000_X5000.tar.gz
Screenshot of ubuntu MATE 16.04.6 LTS PowerPC with the RC5 of kernel 5.3 and with SpiderWeb 2.1.0:
@SailorMH
Please test the kernel with your CF cards.
@Allan (Ace)
Please test the kernel with your ATI FirePro 2260. Could you please tell Hans that your Logitech USB wireless mouse works with the latest HID fixes? Link to the bug report: Bug 203619 - Logitech Wireless Receiver 046d:c52f : mouse not working
@Mechanic
Please test the kernel with your JMB363 card.
@Darren
Could you please submit your new pcmcia patch to the kernel developers?
Re: Kernel 5.3
RC5 is running fine on my AmigaOne X5000!
Big picture http://www.skateman.nl/wp-content/uploa ... 193319.png
Re: Kernel 5.3
Skateman wrote:RC5 is running fine on my AmigaOne X5000!
Thank you for testing the RC5! :-)
Re: Kernel 5.3
Here is the RC6 of kernel 5.3 for testing.
Download: linux-image-5.3-rc6-X1000_X5000_A1222.tar.gz
Screenshot of kernel 5.3-rc6 on the Tabor board:
@SailorMH
@Allan (Ace)
@Mechanic
@Darren
Re: Kernel 5.3
  • uImage 5.3-rc6 test kernel for the Tabor board (A-EON A1222). Please note: There are still some issues with the RAM size and power off doesn't work.
I added the kernel option CONFIG_HIGHMEM to the Tabor kernel config today. This solved the issue with the RAM size. I also successfully modified the code for the power off support. Power off works again now! :-)
Download: linux-image-5.3-rc6-2-A1222.tar.gz (including Tabor patch and kernel config)
Screenshot of kernel 5.3-rc6-2 on the Tabor board:
Please test the RC6 on the X1000, X5000 and A1222.
Re: Kernel 5.3
Kernel 5.3 RC6 is up and running on the AmigaOne X5000 :-)
Big picture http://www.skateman.nl/wp-content/uploa ... 214833.png
