Kernel 5.2
Re: Kernel 5.2
acefnq wrote:Done -:)
Thanks a lot! :-)
Re: Kernel 5.2
The RC2 of kernel 5.2 is available for testing. :-)
  • X5000 and X1000: vgaarb patch for solving the issue with two graphics cards in an AmigaOne. Bug report: Bug 109345 - drm-next-2018-12-14 -Linux PPC
  • X5000: Additional test kernel (uImage-hid6) because of the issue with Logitech wireless USB mice. Bug report: Bug 203619 - Logitech Wireless USB Mouse Not Working PPC
  • X1000: Enabled the kernel config options CONFIG_PATA_PCMCIA, CONFIG_PCMCIA, and CONFIG_ELECTRA_CF for the pcmcia-v2 patch
Download: linux-image-5.2-rc2-X1000_X5000.tar.gz
Screenshot of openSUSE Tumbleweed 20190521 PPC64 kernel 5.2-rc2 from 2019 with the old S.u.S.E. Linux 5.0 x86 kernel 2.0.30 (QEMU) from 1997 together on an A-EON AmigaOne X1000:
@SailorMH
@Allan (Ace)
I added an additional kernel for you to the package (uImage-hid6). You can use your two graphics cards and your Logitech mouse with this kernel. Many thanks for your help with testing and reporting the issues to the kernel developers! :-)
Re: Kernel 5.2
Kernel 5.2 RC2 up and running on the AmigaOne X5000
Big picture http://www.skateman.nl/wp-content/uploa ... 191819.png
Re: Kernel 5.2
Skateman wrote:Kernel 5.2 RC2 up and running on the AmigaOne X5000
Thank you for testing the RC2! :-)
— Christian
Re: Kernel 5.2
I released the RC3 of kernel 5.2 for testing today. :-)
  • X1000: pcmcia-v2 patch for solving the issues with new CF cards connected to the onboard CompactFlash Card Slot
  • X5000: Additional test kernel (uImage-hid7) because of the issue with Logitech wireless USB mice. Bug report: Bug 203619 - Logitech Wireless USB Mouse Not Working PPC
Download: linux-image-5.2-rc3-X1000_X5000.tar.gz
@SailorMH
@Ace
Please test the default kernel (uImage-5.2) with your two installed graphics cards and the additional test kernel (uImage-hid7) with your Logitech wireless USB mouse.
Re: Kernel 5.2
Another download link for the RC3: linux-image-5.2-rc3-X1000_X5000.tar.gz
Re: Kernel 5.2
Kernel 5.2 RC3 is running fine on the AmigaOne X5000.
Big picture http://www.skateman.nl/wp-content/uploa ... 204609.png
Re: Kernel 5.2
Skateman wrote:Kernel 5.2 RC3 is running fine on the AmigaOne X5000.
Re: Kernel 5.2
Hans has released a patch for solving the issue with Logitech wireless USB mice.
[PATCH] HID: logitech-dj: Fix 064d:c52f receiver support — bugzilla.kernel.org
I will create a test kernel for Allan with this patch as soon as possible.
Re: Kernel 5.2
xeno74 wrote:Hi All,
Here is the RC3-2 with the patched Logitech receiver support.
Download: linux-image-5.2-rc3-2_X1000_X5000.tar.gz
Please test it with your Logitech wireless USB mice.
