Kernel 4.5
Re: Kernel 4.5
zzd10h wrote:Hi,
I tested all the 4.4 kernels, here are my results on X1000/R7-250X :
4.4.4 rc2 = KO black screen after "Booting Linux via __start()..."
You mean 4.4-rc4, don't you?
Spectre660 wrote:
@Xeno74 & zzd10h
Seeing the same thing on my Sam460ex and Kernel 4.4 .
Having an isssue when adding Radeon TAHITI_vce.bin firmware to kernel.
When not compiled into 4.4.0rc kernels system boots but with error messages :
Direct firmware load for radeon/TAHITI_vce.bin failed with error -2
Can't load firmware "radeon/TAHITI_vce.bin
When I add the TAHITI_vce.bin firmware into the kernel it results in an oops:
Unable to handle kernel paging request for data at address 0xf000001c
Reported to the the dri-devel mailing list last month.
http://lists.freedesktop.org/archives/d ... 97706.html
Follow up
http://lists.freedesktop.org/archives/d ... 99217.html
Could you please test the firmware http://people.freedesktop.org/~agd5f/ra ... TI_vce.bin from 11 May 2015?
Re: Kernel 4.5
I have recently released the Alpha9 of kernel 4.5.
- Linux Git log
- New Nemo patch 4.5-3
FYI: There are two kernels with different integrated firmware packages
vmlinux-4.5-a9-firmware-amd-graphics_20151018-2 (new firmware package)
vmlinux-4.5-a9-firmware-nonfree_0.44 (old firmware package)
Download: vmlinux-4.5-alpha9-AmigaONE_X1000.tar.gz
R7 and R9 users: Please test vmlinux-4.5-a9-firmware-nonfree_0.44.
Re: Kernel 4.5
Post by zzd10h »
"R7 and R9 users: Please test vmlinux-4.5-a9-firmware-nonfree_0.44."
Sorry... Not better
http://zzd10h.amiga-ng.org/X1000/Linux/ ... Serial.txt
Therefore, still something wrong between 4.4.3 and 4.4.4 kernels.
Re: Kernel 4.5
zzd10h wrote:"R7 and R9 users: Please test vmlinux-4.5-a9-firmware-nonfree_0.44."
Sorry... Not better
Thanks for testing. I am compiling the Alpha10 with the new byte swap patch by Alex Deucher.
Spectre660 was able to boot with the byte swap patch.
Hi All
The patch from Alex Deucher fixes the problem on the Sam460ex.
Regards Julian
Re: Kernel 4.5
Here is the Alpha10. ;-)
New: New Nemo patch 4.5-4 with the byte swap code for Radeon firmwares by Alex Deucher
Download: vmlinux-4.5-alpha10-AmigaONE_X1000.tar.gz
ddni
Re: Kernel 4.5
Post by ddni »
Success booting with Alpha10!
Modules installed to libs/modules. What further testing do you need done?
Re: Kernel 4.5
Post by zzd10h »
@Xeno74
Well done, you finally did it !
mechanic
Re: Kernel 4.5
Post by mechanic »
I will give it test later today. I hope this means no more screwing around with radeon ucode and ...... and ...... and I'll go screw around with something else. :mrgreen:
mechanic
Re: Kernel 4.5
Post by mechanic »
@xeno74
Will you be applying the byte swap code to the 4.4 kernel and patch file?
Re: Kernel 4.5
mechanic wrote:@xeno74
Yes, I will do it next week.
ddni wrote:Success booting with Alpha10!
Fantastic! Thank you for testing. Maybe you could test the RC1 on Monday.
zzd10h wrote:@Xeno74
Many thanks for your patience!
