Linux PowerPC Server Software
Re: Linux PowerPC Server Software
Trust relationship between a Samba AD domain and a FreeIPA domain:
Replication between a Samba AD-DC and a FreeIPA domain part2:
Trust relationship between a Samba AD domain and a FreeIPA domain part2:
Joining of a Samba client to an AD domain (net ads join):
xeno74 wrote: Fri Oct 15, 2021 12:19 pm Kerberos KDC on Void PPC:
A Kerberos keytab file contains the shared secret. The shared secret is required for a principal to request a ticket from the KDC or to decrypt a ticket that is presented by another principal.
MacOS X 10.5.8 Leopard connects via SMB1(NT1) to a Samba Server (simple smb.conf):
It works but this solution brings security issues because of SMB1. I was also able to connect Void PPC Linux via Telnet/Xinetd from MacOS X 10.5.8 Leopard but this connection brings also security issues because it isn't encrypted.
MacOS X 10.5.8 Leopard connects via SMB1(NT1) to a Samba Server (simple smb.conf) with username and password:
Kernel 6.1-rc4 with Samba 4.16.1 on Debian PPC64:
Kernel 6.1-rc5 with the new Samba 4.17.3:
xeno74 wrote: Fri Dec 04, 2020 3:02 pm
Roland wrote: Fri Dec 04, 2020 11:30 am Speaking of servers... What program should I install to Ubuntu, in order to be able to connect to it with 'RDesktop' from AmigaOS?
(https://www.dfstudios.co.uk/articles/am ... ops-amiga/)
Preferably something simple, not needing complicated configuration process...
Please try XRDP:
sudo apt-get install xrdp
sudo vi /etc/xrdp/startwm.sh
/etc/xrdp/startwm.sh:
#!/bin/sh
if [ -r /etc/default/locale ]; then
  . /etc/default/locale
  export LANG LANGUAGE
fi
#xrdp multiple users configuration
 xfce4-session
. /etc/X11/Xsession
A local login via a display manager doesn’t work if you are using XRDP at the same time.
XRDP doesn’t work if you already use the desktop.
You don’t need to edit the xrdp ini files. ip=127.0.0.1 is correct in the ini files.
