Kernel 5.15
Re: Kernel 5.15
kilaueabart wrote: Wed Sep 29, 2021 8:47 pmFor many months when I have Shutdown/Reset Fienix, I have met with a 90 second wait for a Stop job running for User ID 1000, or something like that, roughly 19 times out of 20. Since I started booting with 5.15 RC2 that has happened only twice!
That didn't last. I'm back to regular A stop job is running for User Manager for UID 1000. Surely not due to a difference between RC2 and RC3?
Re: Kernel 5.15
After finally sorting my issues 15RC4 up and running fine.
Re: Kernel 5.15
acefnq wrote: Mon Oct 04, 2021 9:22 am Christian
Great! Thanks a lot for testing!
Re: Kernel 5.15
I successfully tested the RC4 on my X5000/40 with Fienix and in a virtual e5500 QEMU KVM HV machine with Void today.
Unfortunately the smp bug still exists if you use KVM HV. That means, "-smp 4" doesn't work so I use "-smp 3" instead.
Re: Kernel 5.15
System Monitor says RC4 is running on Fienix.
Re: Kernel 5.15
kilaueabart wrote: Tue Oct 05, 2021 7:07 pm System Monitor says RC4 is running on Fienix.
Thank you for testing! :-)
Re: Kernel 5.15
kilaueabart wrote: Sat Oct 02, 2021 7:55 pm
I'm back to RC2. RC3 and RC4 both subjected me to that 90 second Stop Job. RC2 almost always quits straightaway.
Re: Kernel 5.15
5.15 RC5 up and running no issues. Thanks.
