Kernel 5.14
Re: Kernel 5.14
kilaueabart wrote: Fri Jul 09, 2021 7:29 pmPlease advise. Should I get a better graphics card, if possible?
If you want to watch Youtube videos in HD and playing games with 3D hardware acceleration then I would recommend you to use a Radeon HD6xxx, 5xxx, or 4xxx graphics card. Do you use OS4.1 or MorphOS on your X5000?
Re: Kernel 5.14
xeno74 wrote: Sat Jul 10, 2021 9:00 am If you want to watch Youtube videos in HD and playing games with 3D hardware acceleration then I would recommend you to use a Radeon HD6xxx, 5xxx, or 4xxx graphics card. Do you use OS4.1 or MorphOS on your X5000?
But the video decoding for MPEG format is very limited due to the 'levels' even with HD6/5/4xxx Radeons, as explained by Casey in this thread: viewtopic.php?p=50142#p50142. It is not possible to run even 720p (1280x720) MPEG video using hardware acceleration.
I have never been able to run Youtube videos with a HD5450 (which has the same 'levels' as the best 6xxx cards) at higher resolution than 720p/25fps in a X5000/20, and then the average cpu usage is around 90% (some 720p/25fps videos go even up to 100% and do not work properly; I do not know why they need more CPU power). For 1080p a X5000/40 is needed.
Re: Kernel 5.14
I don't play computer games. I don't watch enough Youtube on the X5000 to worry about HD. In Fienix I have to switch from InterWeb to Arctic Fox to get proper colors in YouTube.
Ironically, I bought this X5000 to use my Amiga on, but I spend most of my time on the internet nowadays, and the Amiga browsers are even worse than Interweb, so I rarely boot OS4 anymore.
Re: Kernel 5.14
I am away for a few weeks so no kernel testing for me till the 3 th of August.
Re: Kernel 5.14
Skateman wrote: Sat Jul 10, 2021 9:40 pm I am away for a few weeks so no kernel testing for me till the 3 th of August.
OK, good to know. :-)
Re: Kernel 5.14
kilaueabart wrote: Sat Jul 10, 2021 8:37 pm I don't play computer games. I don't watch enough Youtube on the X5000 to worry about HD. In Fienix I have to switch from InterWeb to Arctic Fox to get proper colors in YouTube.
Thanks for your answer. :-)
Re: Kernel 5.14
Re: Kernel 5.14
Well, looky there!
Re: Kernel 5.14
RC1 works here with MintPPC... But after one reboot the system obviously went into some sort of loop as t he CPU fan was hurling but only a black screen was shown. Had to quickly power off to get out of it...
Also, the problem with the onboard ethernet is still present (unplg/replug needed to get connection)! Isn't there really anyone trying to solve this issue...? I have tested two different Cyrus+ boards and two internet connections from different operators but the problem was present in all cases.
BTW, what does the 'Big GPU Drivers update' mean in practice? Should it be visible somehow in PPC environment?
Re: Kernel 5.14
kilaueabart wrote: Mon Jul 12, 2021 7:04 pm Well, looky there!
Roland wrote: Mon Jul 12, 2021 8:38 pm RC1 works here with MintPPC... But after one reboot the system obviously went into some sort of loop as t he CPU fan was hurling but only a black screen was shown. Had to quickly power off to get out of it..
Good, that it works. I haven't seen this loop issue yet.
Roland wrote: Mon Jul 12, 2021 8:38 pm Also, the problem with the onboard ethernet is still present (unplg/replug needed to get connection)! Isn't there really anyone trying to solve this issue...? I have tested two different Cyrus+ boards and two internet connections from different operators but the problem was present in all cases.
I don't use the onboard ethernet with Linux. I only use it with MorphOS. But I have the same issue with the onboard DPAA Ethernet with Linux. Skateman has luck and can use it without any problems. You can create another bug report if you like.
There were some updates for our old Radeon cards but the big GPU drivers updates were for modern graphics cards.
