Kernel 5.3
Re: Kernel 5.3
Hi all,
I will check out the Linux git till the HID updates.
git checkout 4832a4dada1a2baefac76b70e4f3a78e71a7c35c
After that reverting the updates.
git revert 4832a4dada1a2baefac76b70e4f3a78e71a7c35c -m 1
Then compiling a new test kernel.
Re: Kernel 5.3
xeno74 wrote:Hi all,
Allan
I was able to remove the HID updates today.
Could you please test it?
Download: uImage-5.3-hid3
Re: Kernel 5.3
Hi all...
Kernel 5.3 RC2 is running fine on the X5000 Computer! :-)
Also attached a USB wireless Rii Mini usb mouse / Keyboard.
Big picture http://www.skateman.nl/wp-content/uploa ... 133430.png
Re: Kernel 5.3
Skateman wrote:Hi all...
Fantastic you're back! :-) Many thanks for testing! :-)
Re: Kernel 5.3
Hi Allan,
I was able to remove the HID updates two days ago. After that I compiled a new test kernel for the X5000. Could you please test it?
BTW, shall we close the graphics card bug report (Bug 109345 - drm-next-2018-12-14 -Linux PPC)? Your ATI/AMD FirePro 2260 works as a second graphics card with the following RV620's xorg.conf.
Section "Device"
            Identifier "ATI RV620 [FirePro 2260]"
            Driver      "radeon"
            BusID   "PCI:5@4096:0:0"
EndSection
And you have 3D hardware acceleration with this xorg.conf.
OpenGL vendor string: X.Org
OpenGL renderer string: AMD RV620 (DRM 2.50.0 / 5.3.0-rc1_A-EON_X5000)
OpenGL core profile version string: 3.2 (Core Profile) Mesa 19.0.0
OpenGL core profile shading language version string: 1.50
OpenGL core profile context flags: (none)
OpenGL core profile profile mask: core profile
OpenGL core profile extensions:
OpenGL version string: 3.0 Mesa 19.0.0
OpenGL shading language version string: 1.30
OpenGL context flags: (none)
OpenGL extensions:
OpenGL ES profile version string: OpenGL ES 2.0 Mesa 19.0.0
OpenGL ES profile shading language version string: OpenGL ES GLSL ES 1.0.16
OpenGL ES profile extensions:
Re: Kernel 5.3
Hi Christian
5.3-hid3 works fine with Logitech mouse. I will close the graphics bug and update the mouse bug.
allan
Re: Kernel 5.3
acefnq wrote:Hi Christian
allan
OK, we definitely know that the issue is somewhere in the latest HID updates.
Many thanks for testing and thanks a lot in advance for closing the graphics bug report and for updating the mouse bug report!
Re: Kernel 5.3
I released the RC3 of kernel 5.3 for testing today.
  • Initial ramdisks for the X5000 and X1000. Instructions for creating an initial ramdisk: forum.hyperion-entertainment.com
Downloads: linux-image-5.3-rc3-X1000_X5000.tar.gz
Screenshot of Ubuntu 10.04.4 LTS PowerPC with the RC3 of kernel 5.3 and with Arctic Fox 27.9.18a1:
@SailorMH
Please test the kernel with your CF cards.
@Allan (Ace)
Please test the kernel with your ATI FirePro 2260.
@Mechanic
Please test the kernel with your JMB363 card.
@Darren
Could you please submit your new pcmcia patch to the kernel developers?
Re: Kernel 5.3
Kernel 5.3 RC3 is running fine on the AmigaOne X5000 (or should i say the X5000 Computer..)
Big picture http://www.skateman.nl/wp-content/uploa ... 210808.png
Re: Kernel 5.3
