Kernel 4.19
Re: Kernel 4.19
Skateman wrote:On the X5000 my USB devices like keyboard and mouse are not working with the Alpha 10.
I will revert to the alpha 9 which is working ok!
ALPHA 9
Thank you for testing the alpha9 and alpha10. Have you seen any USB error messages?
— Christian
Re: Kernel 4.19
I checked the Git log between the alpha9 and alpha10 yesterday. There weren’t any USB updates. Tom tested the alpha10 on his X1000 today and he hasn’t any USB problems. I need some more information like error messages or something like that.
Re: Kernel 4.19
I checked the Cyrus kernel config because of USB.
USB3:
CONFIG_USB_XHCI_HCD=y
# CONFIG_USB_XHCI_DBGCAP is not set
CONFIG_USB_XHCI_PCI=y
CONFIG_USB_XHCI_PLATFORM=y
USB2:
CONFIG_USB_EHCI_HCD=y
CONFIG_USB_EHCI_ROOT_HUB_TT=y
CONFIG_USB_EHCI_TT_NEWSCHED=y
CONFIG_USB_EHCI_PCI=y
CONFIG_USB_EHCI_FSL=y
CONFIG_USB_EHCI_HCD_PPC_OF=y
USB1:
CONFIG_USB_OHCI_HCD=y
CONFIG_USB_OHCI_HCD_PPC_OF_BE=y
CONFIG_USB_OHCI_HCD_PPC_OF_LE=y
CONFIG_USB_OHCI_HCD_PPC_OF=y
CONFIG_USB_OHCI_HCD_PCI=y
USB1:
# CONFIG_USB_UHCI_HCD is not set
Strange, UHCI isn't enabled. It isn't enabled in the Nemo config as well. It also isn't enabled in the alpha9 Cyrus kernel config.
Re: Kernel 4.19
I created the alpha11 for testing today.
Download: vmlinux-4.19-alpha11-AmigaOne_X1000_X5000.tar.gz
Re: Kernel 4.19
Alpha 11 is having the same USB issues on my X5000. I will try to figure out what is happening. (which is hard without keyboard and mouse :-) )
I filmed the boot sequence https://photos.app.goo.gl/KLXy4DvJCvqvXGt48 from Alpha 10 and Alpha 11 with non working USB.
I filmed the regular boot sequence https://photos.app.goo.gl/wiabS1L9vaTX4UpW8 from al kernels before Alpha 10.
See the change in the first kernel boot part. (the two penquins) :-) on the first video compared to the second.
Looking at some logs. Alpha 6
Aug 20 19:26:30 X5000LNX kernel: [ 5.959190] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
Aug 20 19:26:30 X5000LNX kernel: [ 5.964669] ehci-pci: EHCI PCI platform driver
Aug 20 19:26:30 X5000LNX kernel: [ 5.970010] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
Aug 20 19:26:30 X5000LNX kernel: [ 5.975541] ohci-pci: OHCI PCI platform driver
Aug 20 19:26:30 X5000LNX kernel: [ 5.981559] ehci-fsl: Freescale EHCI Host controller driver
Aug 20 19:26:30 X5000LNX kernel: [ 5.987058] fsl-ehci fsl-ehci.0: Freescale On-Chip EHCI Host Controller
Aug 20 19:26:30 X5000LNX kernel: [ 5.992652] fsl-ehci fsl-ehci.0: new USB bus registered, assigned bus number 1
Aug 20 19:26:30 X5000LNX kernel: [ 6.007903] fsl-ehci fsl-ehci.0: irq 44, io mem 0xffe210000
Aug 20 19:26:30 X5000LNX kernel: [ 6.019434] fsl-ehci fsl-ehci.0: USB 2.0 started, EHCI 1.00
Aug 20 19:26:30 X5000LNX kernel: [ 6.024901] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
Aug 20 19:26:30 X5000LNX kernel: [ 6.030362] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Aug 20 19:26:30 X5000LNX kernel: [ 6.035783] usb usb1: Product: Freescale On-Chip EHCI Host Controller
Aug 20 19:26:30 X5000LNX kernel: [ 6.041179] usb usb1: Manufacturer: Linux 4.19-a6_A-EON_A1-X5000-g08b5fa8-dirty ehci_hcd
Aug 20 19:26:30 X5000LNX kernel: [ 6.046682] usb usb1: SerialNumber: fsl-ehci.0
Aug 20 19:26:30 X5000LNX kernel: [ 6.052374] hub 1-0:1.0: USB hub found
Aug 20 19:26:30 X5000LNX kernel: [ 6.057841] hub 1-0:1.0: 1 port detected
Aug 20 19:26:30 X5000LNX kernel: [ 6.063404] fsl-ehci fsl-ehci.1: Freescale On-Chip EHCI Host Controller
Aug 20 19:26:30 X5000LNX kernel: [ 6.068917] fsl-ehci fsl-ehci.1: new USB bus registered, assigned bus number 2
Aug 20 19:26:30 X5000LNX kernel: [ 6.083998] fsl-ehci fsl-ehci.1: irq 45, io mem 0xffe211000
Aug 20 19:26:30 X5000LNX kernel: [ 6.096434] fsl-ehci fsl-ehci.1: USB 2.0 started, EHCI 1.00
Aug 20 19:26:30 X5000LNX kernel: [ 6.101895] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
Aug 20 19:26:30 X5000LNX kernel: [ 6.107463] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Aug 20 19:26:30 X5000LNX kernel: [ 6.112991] usb usb2: Product: Freescale On-Chip EHCI Host Controller
Aug 20 19:26:30 X5000LNX kernel: [ 6.118507] usb usb2: Manufacturer: Linux 4.19-a6_A-EON_A1-X5000-g08b5fa8-dirty ehci_hcd
Aug 20 19:26:30 X5000LNX kernel: [ 6.124115] usb usb2: SerialNumber: fsl-ehci.1
Aug 20 19:26:30 X5000LNX kernel: [ 6.129832] hub 2-0:1.0: USB hub found
Aug 20 19:26:30 X5000LNX kernel: [ 6.135351] hub 2-0:1.0: 1 port detected
Aug 20 19:26:30 X5000LNX kernel: [ 6.141022] usbcore: registered new interface driver usblp
Aug 20 19:26:30 X5000LNX kernel: [ 6.146579] usbcore: registered new interface driver usb-storage
Aug 20 19:26:30 X5000LNX kernel: [ 6.152072] usbcore: registered new interface driver usbserial_generic
Aug 20 19:26:30 X5000LNX kernel: [ 6.155390] ata1: SATA link down (SStatus 0 SControl 300)
Aug 20 19:26:30 X5000LNX kernel: [ 6.157514] usbserial: USB Serial support registered for generic
Aug 20 19:26:30 X5000LNX kernel: [ 6.168687] usbcore: registered new interface driver ftdi_sio
Aug 20 19:26:30 X5000LNX kernel: [ 6.174361] usbserial: USB Serial support registered for FTDI USB Serial Device
Aug 20 19:26:30 X5000LNX kernel: [ 6.180603] mousedev: PS/2 mouse device common for all mice
Aug 20 19:26:30 X5000LNX kernel: [ 6.186563] i2c /dev entries driver
Aug 20 19:26:30 X5000LNX kernel: [ 6.192930] mpc-i2c ffe118100.i2c: timeout 1000000 us
Aug 20 19:26:30 X5000LNX kernel: [ 6.198866] mpc-i2c ffe119100.i2c: timeout 1000000 us
Aug 20 19:26:30 X5000LNX kernel: [ 6.206696] rtc-ds1307 9-006f: registered as rtc0
Aug 20 19:26:30 X5000LNX kernel: [ 6.212590] mpc-i2c ffe118000.i2c: timeout 1000000 us
Aug 20 19:26:30 X5000LNX kernel: [ 6.218412] mpc-i2c ffe119000.i2c: timeout 1000000 us
Aug 20 19:26:30 X5000LNX kernel: [ 6.224450] ptp_qoriq: device tree node missing required elements, try automatic configuration
Aug 20 19:26:30 X5000LNX kernel: [ 6.230063] ptp_qoriq: error reference clock value, or lower than 100MHz
Aug 20 19:26:30 X5000LNX kernel: [ 6.235607] ptp_qoriq: probe of ffe4fe000.ptp-timer failed with error -22
Aug 20 19:26:30 X5000LNX kernel: [ 6.241748] device-mapper: ioctl: 4.39.0-ioctl (2018-04-03) initialised: dm-devel@redhat.com
Aug 20 19:26:30 X5000LNX kernel: [ 6.247486] sdhci: Secure Digital Host Controller Interface driver
Aug 20 19:26:30 X5000LNX kernel: [ 6.252905] sdhci: Copyright(c) Pierre Ossman
Aug 20 19:26:30 X5000LNX kernel: [ 6.258264] sdhci-pltfm: SDHCI platform and OF driver helper
Aug 20 19:26:30 X5000LNX kernel: [ 6.288977] mmc0: SDHCI controller on ffe114000.sdhc [ffe114000.sdhc] using ADMA
Aug 20 19:26:30 X5000LNX kernel: [ 6.294643] ledtrig-cpu: registered to indicate activity on CPUs
Aug 20 19:26:30 X5000LNX kernel: [ 6.300115] hidraw: raw HID events driver (C) Jiri Kosina
Aug 20 19:26:30 X5000LNX kernel: [ 6.305901] usbcore: registered new interface driver usbhid
Aug 20 19:26:30 X5000LNX kernel: [ 6.311335] usbhid: USB HID core driver
Aug 20 19:26:30 X5000LNX kernel: [ 6.316851] Freescale hypervisor management driver
Aug 20 19:26:30 X5000LNX kernel: [ 6.322256] fsl-hv: no hypervisor found
Aug 20 19:26:30 X5000LNX kernel: [ 6.329280] snd_hda_intel 0000:01:00.1: Force to snoop mode by module option
Aug 20 19:26:30 X5000LNX kernel: [ 6.338919] input: HDA ATI HDMI HDMI/DP,pcm=3 as /devices/platform/ffe200000.pcie/pci0000:00/0000:00:00.0/0000:01:00.1/sound/card1/input0
Aug 20 19:26:30 X5000LNX kernel: [ 6.353440] ata4: Signature Update detected @ 503 msecs
Aug 20 19:26:30 X5000LNX kernel: [ 6.359080] ata3: Signature Update detected @ 508 msecs
Aug 20 19:26:30 X5000LNX kernel: [ 6.381245] usbcore: registered new interface driver snd-usb-audio
Aug 20 19:26:30 X5000LNX kernel: [ 6.386891] usbcore: registered new interface driver snd-ua101
Aug 20 19:26:30 X5000LNX kernel: [ 6.392439] usbcore: registered new interface driver snd-usb-usx2y
Aug 20 19:26:30 X5000LNX kernel: [ 6.395437] usb 1-1: new high-speed USB device number 2 using fsl-ehci
Aug 20 19:26:30 X5000LNX kernel: [ 6.397995] ipip: IPv4 and MPLS over IPv4 tunneling driver
Aug 20 19:26:30 X5000LNX kernel: [ 6.409115] IPv4 over IPsec tunneling driver
Aug 20 19:26:30 X5000LNX kernel: [ 6.414725] Initializing XFRM netlink socket
Aug 20 19:26:30 X5000LNX kernel: [ 6.420400] NET: Registered protocol family 10
Aug 20 19:26:30 X5000LNX kernel: [ 6.426383] Segment Routing with IPv6
Aug 20 19:26:30 X5000LNX kernel: [ 6.431792] mip6: Mobile IPv6
Aug 20 19:26:30 X5000LNX kernel: [ 6.437357] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
Aug 20 19:26:30 X5000LNX kernel: [ 6.443174] NET: Registered protocol family 17
Aug 20 19:26:30 X5000LNX kernel: [ 6.448507] NET: Registered protocol family 15
Aug 20 19:26:30 X5000LNX kernel: [ 6.453770] lec:lane_module_init: lec.c: initialized
Aug 20 19:26:30 X5000LNX kernel: [ 6.458993] mpoa:atm_mpoa_init: mpc.c: initialized
Aug 20 19:26:30 X5000LNX kernel: [ 6.459436] usb 2-1: new high-speed USB device number 2 using fsl-ehci
Aug 20 19:26:30 X5000LNX kernel: [ 6.464168] l2tp_core: L2TP core driver, V2.0
Aug 20 19:26:30 X5000LNX kernel: [ 6.485266] DCCP: Activated CCID 2 (TCP-like)
Aug 20 19:26:30 X5000LNX kernel: [ 6.490582] DCCP: Activated CCID 3 (TCP-Friendly Rate Control)
Aug 20 19:26:30 X5000LNX kernel: [ 6.496047] sctp: Hash tables configured (bind 256/256)
Aug 20 19:26:30 X5000LNX kernel: [ 6.501539] NET: Registered protocol family 21
Aug 20 19:26:30 X5000LNX kernel: [ 6.506807] Registered RDS/tcp transport
Aug 20 19:26:30 X5000LNX kernel: [ 6.511983] tipc: Activated (version 2.0.0)
Aug 20 19:26:30 X5000LNX kernel: [ 6.517120] NET: Registered protocol family 30
Aug 20 19:26:30 X5000LNX kernel: [ 6.521443] ata3: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
Aug 20 19:26:30 X5000LNX kernel: [ 6.522240] tipc: Started in single node mode
Aug 20 19:26:30 X5000LNX kernel: [ 6.527354] ata4: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
Aug 20 19:26:30 X5000LNX kernel: [ 6.532528] ata3.00: ATAPI: DRW-24D5MT, 1.00, max UDMA/133
Aug 20 19:26:30 X5000LNX kernel: [ 6.542886] Key type dns_resolver registered
Aug 20 19:26:30 X5000LNX kernel: [ 6.548032] ata3.00: configured for UDMA/133
Aug 20 19:26:30 X5000LNX kernel: [ 6.548109] ata4.00: ATA-9: SanDisk SDSSDA240G, Z33130RL, max UDMA/133
Aug 20 19:26:30 X5000LNX kernel: [ 6.558381] ata4.00: 468862128 sectors, multi 1: LBA48 NCQ (depth 16/32)
Aug 20 19:26:30 X5000LNX kernel: [ 6.558485] batman_adv: B.A.T.M.A.N. advanced 2018.2 (compatibility version 15) loaded
Aug 20 19:26:30 X5000LNX kernel: [ 6.563620] ata4.00: failed to get Identify Device Data, Emask 0x1
Aug 20 19:26:30 X5000LNX kernel: [ 6.569041] drmem: No dynamic reconfiguration memory found
Aug 20 19:26:30 X5000LNX kernel: [ 6.569452] usb 1-1: New USB device found, idVendor=0424, idProduct=2514, bcdDevice= b.b3
Aug 20 19:26:30 X5000LNX kernel: [ 6.574659] Loading compiled-in X.509 certificates
Aug 20 19:26:30 X5000LNX kernel: [ 6.579694] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
Aug 20 19:26:30 X5000LNX kernel: [ 6.585070] zswap: loaded using pool lzo/zbud
Aug 20 19:26:30 X5000LNX kernel: [ 6.590792] hub 1-1:1.0: USB hub found
Aug 20 19:26:30 X5000LNX kernel: [ 6.601211] Btrfs loaded, crc32c=crc32c-generic
Aug 20 19:26:30 X5000LNX kernel: [ 6.601278] hub 1-1:1.0: 4 ports detected
Aug 20 19:26:30 X5000LNX kernel: [ 6.612118] ata4.00: failed to get Identify Device Data, Emask 0x1
Aug 20 19:26:30 X5000LNX kernel: [ 6.612125] ata4.00: configured for UDMA/133
Aug 20 19:26:30 X5000LNX kernel: [ 6.617568] mmc0: new high speed SDHC card at address 59b4
Aug 20 19:26:30 X5000LNX kernel: [ 6.623744] mmcblk0: mmc0:59b4 USD 3.75 GiB
Aug 20 19:26:30 X5000LNX kernel: [ 6.623752] Key type encrypted registered
Aug 20 19:26:30 X5000LNX kernel: [ 6.635140] random: fast init done
Aug 20 19:26:30 X5000LNX kernel: [ 6.640482] usb 2-1: New USB device found, idVendor=0424, idProduct=2514, bcdDevice= b.b3
Aug 20 19:26:30 X5000LNX kernel: [ 6.645902] usb 2-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
Aug 20 19:26:30 X5000LNX kernel: [ 6.651291] ata2: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
Aug 20 19:26:30 X5000LNX kernel: [ 6.656782] hub 2-1:1.0: USB hub found
Aug 20 19:26:30 X5000LNX kernel: [ 6.656896] ata2.00: supports DRM functions and may not be fully accessible
Aug 20 19:26:30 X5000LNX kernel: [ 6.667564] hub 2-1:1.0: 4 ports detected
Aug 20 19:26:30 X5000LNX kernel: [ 6.667599] mmcblk0: p1
Aug 20 19:26:30 X5000LNX kernel: [ 6.672915] ata2.00: NCQ Send/Recv Log not supported
Aug 20 19:26:30 X5000LNX kernel: [ 6.683365] rtc-ds1307 9-006f: setting system clock to 2018-08-20 17:26:25 UTC (1534785985)
Aug 20 19:26:30 X5000LNX kernel: [ 6.683595] ALSA device list:
Aug 20 19:26:30 X5000LNX kernel: [ 6.688705] ata2.00: ATA-9: Samsung SSD 850 EVO 250GB, EMT01B6Q, max UDMA/133
Aug 20 19:26:30 X5000LNX kernel: [ 6.688708] ata2.00: 488397168 sectors, multi 1: LBA48 NCQ (depth 32), AA
Aug 20 19:26:30 X5000LNX kernel: [ 6.704873] #0: Virtual MIDI Card 1
Aug 20 19:26:30 X5000LNX kernel: [ 6.710104] #1: HDA ATI HDMI at 0xc10040000 irq 46
Aug 20 19:26:30 X5000LNX kernel: [ 6.715209] #2: M Audio Revolution-5.1 at 0x8000080000022000, irq 19
Aug 20 19:26:30 X5000LNX kernel: [ 6.720452] ata2.00: supports DRM functions and may not be fully accessible
Aug 20 19:26:30 X5000LNX kernel: [ 6.726124] ata2.00: NCQ Send/Recv Log not supported
Aug 20 19:26:30 X5000LNX kernel: [ 6.732180] ata2.00: configured for UDMA/133
Aug 20 19:26:30 X5000LNX kernel: [ 6.737609] scsi 1:0:0:0: Direct-Access ATA Samsung SSD 850 1B6Q PQ: 0 ANSI: 5
Aug 20 19:26:30 X5000LNX kernel: [ 6.743541] sd 1:0:0:0: [sda] 488397168 512-byte logical blocks: (250 GB/233 GiB)
Aug 20 19:26:30 X5000LNX kernel: [ 6.748940] sd 1:0:0:0: [sda] Write Protect is off
Aug 20 19:26:30 X5000LNX kernel: [ 6.749461] sd 1:0:0:0: Attached scsi generic sg0 type 0
Aug 20 19:26:30 X5000LNX kernel: [ 6.754256] sd 1:0:0:0: [sda] Mode Sense: 00 3a 00 00
Aug 20 19:26:30 X5000LNX kernel: [ 6.759684] sd 1:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
Aug 20 19:26:30 X5000LNX kernel: [ 6.760479] scsi 2:0:0:0: CD-ROM ASUS DRW-24D5MT 1.00 PQ: 0 ANSI: 5
Aug 20 19:26:30 X5000LNX kernel: [ 6.765917] sda: RDSK (512) sda1 ((res 2 spb 1) sda2 (SWP^@)(res 2 spb 1)
Aug 20 19:26:30 X5000LNX kernel: [ 6.776776] sd 1:0:0:0: [sda] Attached SCSI disk
Aug 20 19:26:30 X5000LNX kernel: [ 6.790725] sr 2:0:0:0: [sr0] scsi3-mmc drive: 48x/12x writer dvd-ram cd/rw xa/form2 cdda tray
Aug 20 19:26:30 X5000LNX kernel: [ 6.796386] cdrom: Uniform CD-ROM driver Revision: 3.20
Aug 20 19:26:30 X5000LNX kernel: [ 6.802252] sr 2:0:0:0: Attached scsi CD-ROM sr0
Aug 20 19:26:30 X5000LNX kernel: [ 6.802404] sr 2:0:0:0: Attached scsi generic sg1 type 5
Aug 20 19:26:30 X5000LNX kernel: [ 6.808339] scsi 3:0:0:0: Direct-Access ATA SanDisk SDSSDA24 30RL PQ: 0 ANSI: 5
Aug 20 19:26:30 X5000LNX kernel: [ 6.814599] sd 3:0:0:0: [sdb] 468862128 512-byte logical blocks: (240 GB/224 GiB)
Aug 20 19:26:30 X5000LNX kernel: [ 6.816453] sd 3:0:0:0: Attached scsi generic sg2 type 0
Aug 20 19:26:30 X5000LNX kernel: [ 6.820449] sd 3:0:0:0: [sdb] Write Protect is off
Aug 20 19:26:30 X5000LNX kernel: [ 6.831945] sd 3:0:0:0: [sdb] Mode Sense: 00 3a 00 00
Aug 20 19:26:30 X5000LNX kernel: [ 6.831984] sd 3:0:0:0: [sdb] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
Aug 20 19:26:30 X5000LNX kernel: [ 6.838516] sdb: RDSK (512) sdb1 (SFS^B)(res 2 spb 1) sdb2 (SFS^B)(res 2 spb 1)
Aug 20 19:26:30 X5000LNX kernel: [ 6.844895] sd 3:0:0:0: [sdb] Attached SCSI disk
Aug 20 19:26:30 X5000LNX kernel: [ 6.850794] md: Waiting for all devices to be available before autodetect
Aug 20 19:26:30 X5000LNX kernel: [ 6.856789] md: If you don't use raid, use raid=noautodetect
Aug 20 19:26:30 X5000LNX kernel: [ 6.863033] md: Autodetecting RAID arrays.
Aug 20 19:26:30 X5000LNX kernel: [ 6.869010] md: autorun ...
Aug 20 19:26:30 X5000LNX kernel: [ 6.874900] md: ... autorun DONE.
Aug 20 19:26:30 X5000LNX kernel: [ 6.894135] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
Aug 20 19:26:30 X5000LNX kernel: [ 6.900127] VFS: Mounted root (ext4 filesystem) readonly on device 8:1.
Aug 20 19:26:30 X5000LNX kernel: [ 6.907176] devtmpfs: mounted
Aug 20 19:26:30 X5000LNX kernel: [ 6.913289] Freeing unused kernel memory: 416K
Aug 20 19:26:30 X5000LNX kernel: [ 6.919217] This architecture does not have kernel memory protection.
Aug 20 19:26:30 X5000LNX kernel: [ 6.932442] usb 1-1.3: new high-speed USB device number 3 using fsl-ehci
Aug 20 19:26:30 X5000LNX kernel: [ 6.978503] random: systemd: uninitialized urandom read (16 bytes read)
Aug 20 19:26:30 X5000LNX kernel: [ 7.029848] usb 1-1.3: New USB device found, idVendor=05e3, idProduct=0608, bcdDevice=85.36
Aug 20 19:26:30 X5000LNX kernel: [ 7.036086] usb 1-1.3: New USB device strings: Mfr=0, Product=1, SerialNumber=0
Aug 20 19:26:30 X5000LNX kernel: [ 7.037163] random: systemd: uninitialized urandom read (16 bytes read)
Aug 20 19:26:30 X5000LNX kernel: [ 7.042311] usb 1-1.3: Product: USB2.0 Hub
Aug 20 19:26:30 X5000LNX kernel: [ 7.050955] hub 1-1.3:1.0: USB hub found
Aug 20 19:26:30 X5000LNX kernel: [ 7.056837] random: systemd: uninitialized urandom read (16 bytes read)
Aug 20 19:26:30 X5000LNX kernel: [ 7.065485] hub 1-1.3:1.0: 4 ports detected
Aug 20 19:26:30 X5000LNX kernel: [ 7.354474] usb 1-1.3.1: new low-speed USB device number 4 using fsl-ehci
Aug 20 19:26:30 X5000LNX kernel: [ 7.438768] usb 1-1.3.1: New USB device found, idVendor=046d, idProduct=c040, bcdDevice=24.30
Aug 20 19:26:30 X5000LNX kernel: [ 7.438774] usb 1-1.3.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
Aug 20 19:26:30 X5000LNX kernel: [ 7.438777] usb 1-1.3.1: Product: USB-PS/2 Optical Mouse
Aug 20 19:26:30 X5000LNX kernel: [ 7.438779] usb 1-1.3.1: Manufacturer: Logitech
Aug 20 19:26:30 X5000LNX kernel: [ 7.442366] input: Logitech USB-PS/2 Optical Mouse as /devices/platform/ffe000000.soc/ffe210000.usb/fsl-ehci.0/usb1/1-1/1-1.3/1-1.3.1/1-1.3.1:1.0/0003:046D:C040.0001/input/input1
Aug 20 19:26:30 X5000LNX kernel: [ 7.442583] hid-generic 0003:046D:C040.0001: input,hidraw0: USB HID v1.10 Mouse [Logitech USB-PS/2 Optical Mouse] on usb-fsl-ehci.0-1.3.1/input0
Aug 20 19:26:30 X5000LNX kernel: [ 7.507453] usb 1-1.3.3: new low-speed USB device number 5 using fsl-ehci
Aug 20 19:26:30 X5000LNX kernel: [ 7.592884] usb 1-1.3.3: New USB device found, idVendor=046d, idProduct=c312, bcdDevice= 1.01
Aug 20 19:26:30 X5000LNX kernel: [ 7.599121] usb 1-1.3.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
Aug 20 19:26:30 X5000LNX kernel: [ 7.605264] usb 1-1.3.3: Product: USB Multimedia Keyboard
Aug 20 19:26:30 X5000LNX kernel: [ 7.611425] usb 1-1.3.3: Manufacturer: LITEON Technology
Aug 20 19:26:30 X5000LNX kernel: [ 7.623560] input: LITEON Technology USB Multimedia Keyboard as /devices/platform/ffe000000.soc/ffe210000.usb/fsl-ehci.0/usb1/1-1/1-1.3/1-1.3.3/1-1.3.3:1.0/0003:046D:C312.0002/input/input2
Aug 20 19:26:30 X5000LNX kernel: [ 7.681957] hid-generic 0003:046D:C312.0002: input,hidraw1: USB HID v1.10 Keyboard [LITEON Technology USB Multimedia Keyboard] on usb-fsl-ehci.0-1.3.3/input0
Aug 20 19:26:30 X5000LNX kernel: [ 7.747443] usb 1-1.3.4: new high-speed USB device number 6 using fsl-ehci
Aug 20 19:26:30 X5000LNX kernel: [ 7.826848] usb 1-1.3.4: New USB device found, idVendor=05e3, idProduct=0608, bcdDevice=85.36
Aug 20 19:26:30 X5000LNX kernel: [ 7.826853] usb 1-1.3.4: New USB device strings: Mfr=0, Product=1, SerialNumber=0
Aug 20 19:26:30 X5000LNX kernel: [ 7.826855] usb 1-1.3.4: Product: USB2.0 Hub
Aug 20 19:26:30 X5000LNX kernel: [ 7.828682] hub 1-1.3.4:1.0: USB hub found
Aug 20 19:26:30 X5000LNX kernel: [ 7.828982] hub 1-1.3.4:1.0: 4 ports detected
Logs Alpha 11
Aug 24 12:57:53 X5000LNX kernel: [ 5.965128] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
Aug 24 12:57:53 X5000LNX kernel: [ 5.970651] ehci-pci: EHCI PCI platform driver
Aug 24 12:57:53 X5000LNX kernel: [ 5.975986] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
Aug 24 12:57:53 X5000LNX kernel: [ 5.981513] ohci-pci: OHCI PCI platform driver
Aug 24 12:57:53 X5000LNX kernel: [ 5.987535] ehci-fsl: Freescale EHCI Host controller driver
Aug 24 12:57:53 X5000LNX kernel: [ 5.993023] fsl-ehci fsl-ehci.0: Freescale On-Chip EHCI Host Controller
Aug 24 12:57:53 X5000LNX kernel: [ 5.998606] fsl-ehci fsl-ehci.0: new USB bus registered, assigned bus number 1
Aug 24 12:57:53 X5000LNX kernel: [ 6.013859] fsl-ehci fsl-ehci.0: irq 44, io mem 0xffe210000
Aug 24 12:57:53 X5000LNX kernel: [ 6.025503] fsl-ehci fsl-ehci.0: USB 2.0 started, EHCI 1.00
Aug 24 12:57:53 X5000LNX kernel: [ 6.030967] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
Aug 24 12:57:53 X5000LNX kernel: [ 6.036421] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Aug 24 12:57:53 X5000LNX kernel: [ 6.041833] usb usb1: Product: Freescale On-Chip EHCI Host Controller
Aug 24 12:57:53 X5000LNX kernel: [ 6.047223] usb usb1: Manufacturer: Linux 4.19-a11_A-EON_A1-X5000-g33e1787-dirty ehci_hcd
Aug 24 12:57:53 X5000LNX kernel: [ 6.052717] usb usb1: SerialNumber: fsl-ehci.0
Aug 24 12:57:53 X5000LNX kernel: [ 6.058396] hub 1-0:1.0: USB hub found
Aug 24 12:57:53 X5000LNX kernel: [ 6.063853] hub 1-0:1.0: 1 port detected
Aug 24 12:57:53 X5000LNX kernel: [ 6.069410] fsl-ehci fsl-ehci.1: Freescale On-Chip EHCI Host Controller
Aug 24 12:57:53 X5000LNX kernel: [ 6.074910] fsl-ehci fsl-ehci.1: new USB bus registered, assigned bus number 2
Aug 24 12:57:53 X5000LNX kernel: [ 6.089982] fsl-ehci fsl-ehci.1: irq 45, io mem 0xffe211000
Aug 24 12:57:53 X5000LNX kernel: [ 6.101504] fsl-ehci fsl-ehci.1: USB 2.0 started, EHCI 1.00
Aug 24 12:57:53 X5000LNX kernel: [ 6.106962] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
Aug 24 12:57:53 X5000LNX kernel: [ 6.112515] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Aug 24 12:57:53 X5000LNX kernel: [ 6.118027] usb usb2: Product: Freescale On-Chip EHCI Host Controller
Aug 24 12:57:53 X5000LNX kernel: [ 6.123528] usb usb2: Manufacturer: Linux 4.19-a11_A-EON_A1-X5000-g33e1787-dirty ehci_hcd
Aug 24 12:57:53 X5000LNX kernel: [ 6.129123] usb usb2: SerialNumber: fsl-ehci.1
Aug 24 12:57:53 X5000LNX kernel: [ 6.134825] hub 2-0:1.0: USB hub found
Aug 24 12:57:53 X5000LNX kernel: [ 6.140332] hub 2-0:1.0: 1 port detected
Aug 24 12:57:53 X5000LNX kernel: [ 6.145989] usbcore: registered new interface driver usblp
Aug 24 12:57:53 X5000LNX kernel: [ 6.151532] usbcore: registered new interface driver usb-storage
Aug 24 12:57:53 X5000LNX kernel: [ 6.157011] usbcore: registered new interface driver usbserial_generic
Aug 24 12:57:53 X5000LNX kernel: [ 6.158642] ata1: SATA link down (SStatus 0 SControl 300)
Aug 24 12:57:53 X5000LNX kernel: [ 6.162436] usbserial: USB Serial support registered for generic
Aug 24 12:57:53 X5000LNX kernel: [ 6.173567] usbcore: registered new interface driver ftdi_sio
Aug 24 12:57:53 X5000LNX kernel: [ 6.179216] usbserial: USB Serial support registered for FTDI USB Serial Device
Aug 24 12:57:53 X5000LNX kernel: [ 6.185385] mousedev: PS/2 mouse device common for all mice
Aug 24 12:57:53 X5000LNX kernel: [ 6.191290] i2c /dev entries driver
Aug 24 12:57:53 X5000LNX kernel: [ 6.197566] mpc-i2c ffe118100.i2c: timeout 1000000 us
Aug 24 12:57:53 X5000LNX kernel: [ 6.203478] mpc-i2c ffe119100.i2c: timeout 1000000 us
Aug 24 12:57:53 X5000LNX kernel: [ 6.211337] rtc-ds1307 9-006f: registered as rtc0
Aug 24 12:57:53 X5000LNX kernel: [ 6.217222] mpc-i2c ffe118000.i2c: timeout 1000000 us
Aug 24 12:57:53 X5000LNX kernel: [ 6.223033] mpc-i2c ffe119000.i2c: timeout 1000000 us
Aug 24 12:57:53 X5000LNX kernel: [ 6.229058] ptp_qoriq: device tree node missing required elements, try automatic configuration
Aug 24 12:57:53 X5000LNX kernel: [ 6.234658] ptp_qoriq: error reference clock value, or lower than 100MHz
Aug 24 12:57:53 X5000LNX kernel: [ 6.240182] ptp_qoriq: probe of ffe4fe000.ptp-timer failed with error -22
Aug 24 12:57:53 X5000LNX kernel: [ 6.246292] device-mapper: ioctl: 4.39.0-ioctl (2018-04-03) initialised: dm-devel@redhat.com
Aug 24 12:57:53 X5000LNX kernel: [ 6.251990] sdhci: Secure Digital Host Controller Interface driver
Aug 24 12:57:53 X5000LNX kernel: [ 6.257393] sdhci: Copyright(c) Pierre Ossman
Aug 24 12:57:53 X5000LNX kernel: [ 6.262735] sdhci-pltfm: SDHCI platform and OF driver helper
Aug 24 12:57:53 X5000LNX kernel: [ 6.293441] mmc0: SDHCI controller on ffe114000.sdhc [ffe114000.sdhc] using ADMA
Aug 24 12:57:53 X5000LNX kernel: [ 6.299084] ledtrig-cpu: registered to indicate activity on CPUs
Aug 24 12:57:53 X5000LNX kernel: [ 6.304567] hidraw: raw HID events driver (C) Jiri Kosina
Aug 24 12:57:53 X5000LNX kernel: [ 6.310346] usbcore: registered new interface driver usbhid
Aug 24 12:57:53 X5000LNX kernel: [ 6.315762] usbhid: USB HID core driver
Aug 24 12:57:53 X5000LNX kernel: [ 6.321253] Freescale hypervisor management driver
Aug 24 12:57:53 X5000LNX kernel: [ 6.326638] fsl-hv: no hypervisor found
Aug 24 12:57:53 X5000LNX kernel: [ 6.333688] snd_hda_intel 0000:01:00.1: Force to snoop mode by module option
Aug 24 12:57:53 X5000LNX kernel: [ 6.343241] input: HDA ATI HDMI HDMI/DP,pcm=3 as /devices/platform/ffe200000.pcie/pci0000:00/0000:00:00.0/0000:01:00.1/sound/card1/input0
Aug 24 12:57:53 X5000LNX kernel: [ 6.354605] random: fast init done
Aug 24 12:57:53 X5000LNX kernel: [ 6.361503] ata4: Signature Update detected @ 504 msecs
Aug 24 12:57:53 X5000LNX kernel: [ 6.367093] ata3: Signature Update detected @ 509 msecs
Aug 24 12:57:53 X5000LNX kernel: [ 6.385352] usbcore: registered new interface driver snd-usb-audio
Aug 24 12:57:53 X5000LNX kernel: [ 6.390972] usbcore: registered new interface driver snd-ua101
Aug 24 12:57:53 X5000LNX kernel: [ 6.396459] usbcore: registered new interface driver snd-usb-usx2y
Aug 24 12:57:53 X5000LNX kernel: [ 6.401961] ipip: IPv4 and MPLS over IPv4 tunneling driver
Aug 24 12:57:53 X5000LNX kernel: [ 6.407587] IPv4 over IPsec tunneling driver
Aug 24 12:57:53 X5000LNX kernel: [ 6.413148] Initializing XFRM netlink socket
Aug 24 12:57:53 X5000LNX kernel: [ 6.418772] NET: Registered protocol family 10
Aug 24 12:57:53 X5000LNX kernel: [ 6.424311] usb 1-1: new high-speed USB device number 2 using fsl-ehci
Aug 24 12:57:53 X5000LNX kernel: [ 6.426914] Segment Routing with IPv6
Aug 24 12:57:53 X5000LNX kernel: [ 6.431750] mmc0: unrecognised SCR structure version 12
Aug 24 12:57:53 X5000LNX kernel: [ 6.435145] mip6: Mobile IPv6
Aug 24 12:57:53 X5000LNX kernel: [ 6.440525] mmc0: error -22 whilst initialising SD card
Aug 24 12:57:53 X5000LNX kernel: [ 6.451447] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
Aug 24 12:57:53 X5000LNX kernel: [ 6.457188] NET: Registered protocol family 17
Aug 24 12:57:53 X5000LNX kernel: [ 6.462458] NET: Registered protocol family 15
Aug 24 12:57:53 X5000LNX kernel: [ 6.467645] lec:lane_module_init: lec.c: initialized
Aug 24 12:57:53 X5000LNX kernel: [ 6.472827] mpoa:atm_mpoa_init: mpc.c: initialized
Aug 24 12:57:53 X5000LNX kernel: [ 6.478042] l2tp_core: L2TP core driver, V2.0
Aug 24 12:57:53 X5000LNX kernel: [ 6.493819] DCCP: Activated CCID 2 (TCP-like)
Aug 24 12:57:53 X5000LNX kernel: [ 6.495715] mmc0: unrecognised SCR structure version 12
Aug 24 12:57:53 X5000LNX kernel: [ 6.499088] DCCP: Activated CCID 3 (TCP-Friendly Rate Control)
Aug 24 12:57:53 X5000LNX kernel: [ 6.504275] mmc0: error -22 whilst initialising SD card
Aug 24 12:57:53 X5000LNX kernel: [ 6.509839] sctp: Hash tables configured (bind 256/256)
Aug 24 12:57:53 X5000LNX kernel: [ 6.514730] usb 2-1: new high-speed USB device number 2 using fsl-ehci
Aug 24 12:57:53 X5000LNX kernel: [ 6.520565] NET: Registered protocol family 21
Aug 24 12:57:53 X5000LNX kernel: [ 6.530302] ata4: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
Aug 24 12:57:53 X5000LNX kernel: [ 6.530323] ata3: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
Aug 24 12:57:53 X5000LNX kernel: [ 6.531417] ata3.00: failed to IDENTIFY (device reports invalid type, err_mask=0x0)
Aug 24 12:57:53 X5000LNX kernel: [ 6.535731] Registered RDS/tcp transport
Aug 24 12:57:53 X5000LNX kernel: [ 6.540665] ata4.00: failed to IDENTIFY (INIT_DEV_PARAMS failed, err_mask=0x80)
Aug 24 12:57:53 X5000LNX kernel: [ 6.545818] tipc: Activated (version 2.0.0)
Aug 24 12:57:53 X5000LNX kernel: [ 6.545851] NET: Registered protocol family 30
Aug 24 12:57:53 X5000LNX kernel: [ 6.551016] usb 1-1: device descriptor read/64, error -32
Aug 24 12:57:53 X5000LNX kernel: [ 6.556386] tipc: Started in single node mode
Aug 24 12:57:53 X5000LNX kernel: [ 6.577908] Key type dns_resolver registered
Aug 24 12:57:53 X5000LNX kernel: [ 6.583321] batman_adv: B.A.T.M.A.N. advanced 2018.2 (compatibility version 15) loaded
Aug 24 12:57:53 X5000LNX kernel: [ 6.588767] drmem: No dynamic reconfiguration memory found
Aug 24 12:57:53 X5000LNX kernel: [ 6.594301] Loading compiled-in X.509 certificates
Aug 24 12:57:53 X5000LNX kernel: [ 6.599656] zswap: loaded using pool lzo/zbud
Aug 24 12:57:53 X5000LNX kernel: [ 6.605522] Btrfs loaded, crc32c=crc32c-generic
Aug 24 12:57:53 X5000LNX kernel: [ 6.606522] mmc0: unrecognised SCR structure version 12
Aug 24 12:57:53 X5000LNX kernel: [ 6.616280] mmc0: error -22 whilst initialising SD card
Aug 24 12:57:53 X5000LNX kernel: [ 6.621938] Key type encrypted registered
Aug 24 12:57:53 X5000LNX kernel: [ 6.628749] rtc-ds1307 9-006f: setting system clock to 2018-08-24 10:57:32 UTC (1535108252)
Aug 24 12:57:53 X5000LNX kernel: [ 6.634413] ALSA device list:
Aug 24 12:57:53 X5000LNX kernel: [ 6.639790] #0: Virtual MIDI Card 1
Aug 24 12:57:53 X5000LNX kernel: [ 6.645091] #1: HDA ATI HDMI at 0xc10040000 irq 46
Aug 24 12:57:53 X5000LNX kernel: [ 6.645523] ata2: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
Aug 24 12:57:53 X5000LNX kernel: [ 6.650348] #2: M Audio Revolution-5.1 at 0x8000080000022000, irq 19
Aug 24 12:57:53 X5000LNX kernel: [ 6.662556] ata2.00: supports DRM functions and may not be fully accessible
Aug 24 12:57:53 X5000LNX kernel: [ 6.668316] ata2.00: NCQ Send/Recv Log not supported
Aug 24 12:57:53 X5000LNX kernel: [ 6.673590] ata2.00: ATA-9: Samsung SSD 850 EVO 250GB, EMT01B6Q, max UDMA/133
Aug 24 12:57:53 X5000LNX kernel: [ 6.678892] ata2.00: 488397168 sectors, multi 1: LBA48 NCQ (depth 32), AA
Aug 24 12:57:53 X5000LNX kernel: [ 6.684218] usb 2-1: device descriptor read/64, error -32
Aug 24 12:57:53 X5000LNX kernel: [ 6.690441] ata2.00: supports DRM functions and may not be fully accessible
Aug 24 12:57:53 X5000LNX kernel: [ 6.696158] ata2.00: NCQ Send/Recv Log not supported
Aug 24 12:57:53 X5000LNX kernel: [ 6.702329] ata2.00: configured for UDMA/133
Aug 24 12:57:53 X5000LNX kernel: [ 6.707802] scsi 1:0:0:0: Direct-Access ATA Samsung SSD 850 1B6Q PQ: 0 ANSI: 5
Aug 24 12:57:53 X5000LNX kernel: [ 6.713441] sd 1:0:0:0: Attached scsi generic sg0 type 0
Aug 24 12:57:53 X5000LNX kernel: [ 6.713520] sd 1:0:0:0: [sda] 488397168 512-byte logical blocks: (250 GB/233 GiB)
Aug 24 12:57:53 X5000LNX kernel: [ 6.723855] sd 1:0:0:0: [sda] Write Protect is off
Aug 24 12:57:53 X5000LNX kernel: [ 6.729080] sd 1:0:0:0: [sda] Mode Sense: 00 3a 00 00
Aug 24 12:57:53 X5000LNX kernel: [ 6.729138] sd 1:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
Aug 24 12:57:53 X5000LNX kernel: [ 6.735115] sda: RDSK (512) sda1 ((res 2 spb 1) sda2 (SWP^@)(res 2 spb 1)
Aug 24 12:57:53 X5000LNX kernel: [ 6.741050] sd 1:0:0:0: [sda] Attached SCSI disk
Aug 24 12:57:53 X5000LNX kernel: [ 6.774139] mmc0: unrecognised SCR structure version 12
Aug 24 12:57:53 X5000LNX kernel: [ 6.779537] mmc0: error -22 whilst initialising SD card
Aug 24 12:57:53 X5000LNX kernel: [ 6.803501] usb 1-1: device descriptor read/64, error -32
Aug 24 12:57:53 X5000LNX kernel: [ 6.907501] usb 2-1: device descriptor read/64, error -32
Aug 24 12:57:53 X5000LNX kernel: [ 7.027501] usb 1-1: new high-speed USB device number 3 using fsl-ehci
Aug 24 12:57:53 X5000LNX kernel: [ 7.131501] usb 2-1: new high-speed USB device number 3 using fsl-ehci
Aug 24 12:57:53 X5000LNX kernel: [ 7.146500] usb 1-1: device descriptor read/64, error -32
Aug 24 12:57:53 X5000LNX kernel: [ 7.250501] usb 2-1: device descriptor read/64, error -32
Aug 24 12:57:53 X5000LNX kernel: [ 7.371500] usb 1-1: device descriptor read/64, error -32
Aug 24 12:57:53 X5000LNX kernel: [ 7.475501] usb 2-1: device descriptor read/64, error -32
Aug 24 12:57:53 X5000LNX kernel: [ 7.481509] usb usb1-port1: attempt power cycle
Aug 24 12:57:53 X5000LNX kernel: [ 7.585510] usb usb2-port1: attempt power cycle
Aug 24 12:57:53 X5000LNX kernel: [ 8.109500] usb 1-1: new high-speed USB device number 4 using fsl-ehci
Aug 24 12:57:53 X5000LNX kernel: [ 8.213500] usb 2-1: new high-speed USB device number 4 using fsl-ehci
Aug 24 12:57:53 X5000LNX kernel: [ 8.529501] usb 1-1: device not accepting address 4, error -32
Aug 24 12:57:53 X5000LNX kernel: [ 8.633500] usb 2-1: device not accepting address 4, error -32
Aug 24 12:57:53 X5000LNX kernel: [ 8.648500] usb 1-1: new high-speed USB device number 5 using fsl-ehci
Aug 24 12:57:53 X5000LNX kernel: [ 8.752500] usb 2-1: new high-speed USB device number 5 using fsl-ehci
Aug 24 12:57:53 X5000LNX kernel: [ 9.065500] usb 1-1: device not accepting address 5, error -32
Aug 24 12:57:53 X5000LNX kernel: [ 9.070459] usb usb1-port1: unable to enumerate USB device
Aug 24 12:57:53 X5000LNX kernel: [ 9.169501] usb 2-1: device not accepting address 5, error -32
Aug 24 12:57:53 X5000LNX kernel: [ 9.174444] usb usb2-port1: unable to enumerate USB device
Aug 24 12:57:53 X5000LNX kernel: [ 12.249501] ata3: Signature Update detected @ 502 msecs
Aug 24 12:57:53 X5000LNX kernel: [ 12.254400] ata4: Signature Update detected @ 506 msecs
Aug 24 12:57:53 X5000LNX kernel: [ 12.417503] ata4: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
Aug 24 12:57:53 X5000LNX kernel: [ 12.422398] ata3: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
Aug 24 12:57:53 X5000LNX kernel: [ 12.427197] ata4.00: failed to IDENTIFY (INIT_DEV_PARAMS failed, err_mask=0x80)
Aug 24 12:57:53 X5000LNX kernel: [ 12.432000] ata4: limiting SATA link speed to 1.5 Gbps
Aug 24 12:57:53 X5000LNX kernel: [ 12.437167] ata3.00: failed to IDENTIFY (device reports invalid type, err_mask=0x0)
Aug 24 12:57:53 X5000LNX kernel: [ 18.393501] ata3: Signature Update detected @ 502 msecs
Aug 24 12:57:53 X5000LNX kernel: [ 18.398355] ata4: Signature Update detected @ 506 msecs
Aug 24 12:57:53 X5000LNX kernel: [ 18.561504] ata3: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
Aug 24 12:57:53 X5000LNX kernel: [ 18.566344] ata4: SATA link up 1.5 Gbps (SStatus 113 SControl 310)
Aug 24 12:57:53 X5000LNX kernel: [ 18.572504] ata4.00: failed to IDENTIFY (INIT_DEV_PARAMS failed, err_mask=0x80)
Aug 24 12:57:53 X5000LNX kernel: [ 24.537500] ata4: Signature Update detected @ 502 msecs
Aug 24 12:57:53 X5000LNX kernel: [ 24.697502] ata4: SATA link up 1.5 Gbps (SStatus 113 SControl 310)
Aug 24 12:57:53 X5000LNX kernel: [ 24.702298] md: Waiting for all devices to be available before autodetect
Aug 24 12:57:53 X5000LNX kernel: [ 24.707081] md: If you don't use raid, use raid=noautodetect
Aug 24 12:57:53 X5000LNX kernel: [ 24.712096] md: Autodetecting RAID arrays.
Aug 24 12:57:53 X5000LNX kernel: [ 24.717265] md: autorun ...
Aug 24 12:57:53 X5000LNX kernel: [ 24.721972] md: ... autorun DONE.
Aug 24 12:57:53 X5000LNX kernel: [ 24.729982] EXT4-fs (sda1): INFO: recovery required on readonly filesystem
Aug 24 12:57:53 X5000LNX kernel: [ 24.734675] EXT4-fs (sda1): write access will be enabled during recovery
Aug 24 12:57:53 X5000LNX kernel: [ 24.764336] EXT4-fs (sda1): recovery complete
Aug 24 12:57:53 X5000LNX kernel: [ 24.770517] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
Aug 24 12:57:53 X5000LNX kernel: [ 24.775269] VFS: Mounted root (ext4 filesystem) readonly on device 8:1.
Aug 24 12:57:53 X5000LNX kernel: [ 24.781040] devtmpfs: mounted
Aug 24 12:57:53 X5000LNX kernel: [ 24.785898] Freeing unused kernel memory: 412K
Aug 24 12:57:53 X5000LNX kernel: [ 24.790537] This architecture does not have kernel memory protection.
Aug 24 12:57:53 X5000LNX kernel: [ 24.795204] Run /sbin/init as init process
Aug 24 12:57:53 X5000LNX kernel: [ 24.849744] random: systemd: uninitialized urandom read (16 bytes read)
Aug 24 12:57:53 X5000LNX kernel: [ 24.895012] random: systemd: uninitialized urandom read (16 bytes read)
Aug 24 12:57:53 X5000LNX kernel: [ 24.903823] random: systemd-gpt-aut: uninitialized urandom read (16 bytes read)
Aug 24 12:57:53 X5000LNX kernel: [ 25.621456] EXT4-fs (sda1): re-mounted. Opts: errors=remount-ro
Aug 24 12:57:53 X5000LNX kernel: [ 26.460304] r8169 1000:05:00.0 enP4096p5s0: renamed from eth2
Dave
Re: Kernel 4.19
Thank you.
Please post the output of grep -i usb /var/log/syslog and then post the output of grep -i -E 'usb.*error' /var/log/syslog.
Re: Kernel 4.19
skateman@X5000LNX:~$ grep -i usb /var/log/syslog
Aug 24 13:12:50 X5000LNX kernel: [ 0.240601] usbcore: registered new interface driver usbfs
Aug 24 13:12:50 X5000LNX kernel: [ 0.240628] usbcore: registered new interface driver hub
Aug 24 13:12:50 X5000LNX kernel: [ 0.240654] usbcore: registered new device driver usb
Aug 24 13:12:50 X5000LNX kernel: [ 5.951929] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
Aug 24 13:12:50 X5000LNX kernel: [ 5.962750] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
Aug 24 13:12:50 X5000LNX kernel: [ 5.985373] fsl-ehci fsl-ehci.0: new USB bus registered, assigned bus number 1
Aug 24 13:12:50 X5000LNX kernel: [ 6.012156] fsl-ehci fsl-ehci.0: USB 2.0 started, EHCI 1.00
Aug 24 13:12:50 X5000LNX kernel: [ 6.017609] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
Aug 24 13:12:50 X5000LNX kernel: [ 6.023062] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Aug 24 13:12:50 X5000LNX kernel: [ 6.028479] usb usb1: Product: Freescale On-Chip EHCI Host Controller
Aug 24 13:12:50 X5000LNX kernel: [ 6.033870] usb usb1: Manufacturer: Linux 4.19-a11_A-EON_A1-X5000-g33e1787-dirty ehci_hcd
Aug 24 13:12:50 X5000LNX kernel: [ 6.039370] usb usb1: SerialNumber: fsl-ehci.0
Aug 24 13:12:50 X5000LNX kernel: [ 6.045052] hub 1-0:1.0: USB hub found
Aug 24 13:12:50 X5000LNX kernel: [ 6.061565] fsl-ehci fsl-ehci.1: new USB bus registered, assigned bus number 2
Aug 24 13:12:50 X5000LNX kernel: [ 6.088159] fsl-ehci fsl-ehci.1: USB 2.0 started, EHCI 1.00
Aug 24 13:12:50 X5000LNX kernel: [ 6.093624] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
Aug 24 13:12:50 X5000LNX kernel: [ 6.099185] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Aug 24 13:12:50 X5000LNX kernel: [ 6.104704] usb usb2: Product: Freescale On-Chip EHCI Host Controller
Aug 24 13:12:50 X5000LNX kernel: [ 6.110214] usb usb2: Manufacturer: Linux 4.19-a11_A-EON_A1-X5000-g33e1787-dirty ehci_hcd
Aug 24 13:12:50 X5000LNX kernel: [ 6.115818] usb usb2: SerialNumber: fsl-ehci.1
Aug 24 13:12:50 X5000LNX kernel: [ 6.121528] hub 2-0:1.0: USB hub found
Aug 24 13:12:50 X5000LNX kernel: [ 6.132707] usbcore: registered new interface driver usblp
Aug 24 13:12:50 X5000LNX kernel: [ 6.138252] usbcore: registered new interface driver usb-storage
Aug 24 13:12:50 X5000LNX kernel: [ 6.143740] usbcore: registered new interface driver usbserial_generic
Aug 24 13:12:50 X5000LNX kernel: [ 6.154793] usbserial: USB Serial support registered for generic
Aug 24 13:12:50 X5000LNX kernel: [ 6.160446] usbcore: registered new interface driver ftdi_sio
Aug 24 13:12:50 X5000LNX kernel: [ 6.166166] usbserial: USB Serial support registered for FTDI USB Serial Device
Aug 24 13:12:50 X5000LNX kernel: [ 6.298526] usbcore: registered new interface driver usbhid
Aug 24 13:12:50 X5000LNX kernel: [ 6.304007] usbhid: USB HID core driver
Aug 24 13:12:50 X5000LNX kernel: [ 6.377850] usbcore: registered new interface driver snd-usb-audio
Aug 24 13:12:50 X5000LNX kernel: [ 6.383519] usbcore: registered new interface driver snd-ua101
Aug 24 13:12:50 X5000LNX kernel: [ 6.394757] usbcore: registered new interface driver snd-usb-usx2y
Aug 24 13:12:50 X5000LNX kernel: [ 6.429263] usb 1-1: new high-speed USB device number 2 using fsl-ehci
Aug 24 13:12:50 X5000LNX kernel: [ 6.486160] usb 2-1: new high-speed USB device number 2 using fsl-ehci
Aug 24 13:12:50 X5000LNX kernel: [ 6.552303] usb 1-1: device descriptor read/64, error -32
Aug 24 13:12:50 X5000LNX kernel: [ 6.649376] usb 2-1: device descriptor read/64, error -32
Aug 24 13:12:50 X5000LNX kernel: [ 6.794158] usb 1-1: device descriptor read/64, error -32
Aug 24 13:12:50 X5000LNX kernel: [ 6.883156] usb 2-1: device descriptor read/64, error -32
Aug 24 13:12:50 X5000LNX kernel: [ 7.019158] usb 1-1: new high-speed USB device number 3 using fsl-ehci
Aug 24 13:12:50 X5000LNX kernel: [ 7.107157] usb 2-1: new high-speed USB device number 3 using fsl-ehci
Aug 24 13:12:50 X5000LNX kernel: [ 7.139155] usb 1-1: device descriptor read/64, error -32
Aug 24 13:12:50 X5000LNX kernel: [ 7.226156] usb 2-1: device descriptor read/64, error -32
Aug 24 13:12:50 X5000LNX kernel: [ 7.363155] usb 1-1: device descriptor read/64, error -32
Aug 24 13:12:50 X5000LNX kernel: [ 7.451156] usb 2-1: device descriptor read/64, error -32
Aug 24 13:12:50 X5000LNX kernel: [ 7.473167] usb usb1-port1: attempt power cycle
Aug 24 13:12:50 X5000LNX kernel: [ 7.561166] usb usb2-port1: attempt power cycle
Aug 24 13:12:50 X5000LNX kernel: [ 8.101156] usb 1-1: new high-speed USB device number 4 using fsl-ehci
Aug 24 13:12:50 X5000LNX kernel: [ 8.189156] usb 2-1: new high-speed USB device number 4 using fsl-ehci
Aug 24 13:12:50 X5000LNX kernel: [ 8.521156] usb 1-1: device not accepting address 4, error -32
Aug 24 13:12:50 X5000LNX kernel: [ 8.609156] usb 2-1: device not accepting address 4, error -32
Aug 24 13:12:50 X5000LNX kernel: [ 8.640156] usb 1-1: new high-speed USB device number 5 using fsl-ehci
Aug 24 13:12:50 X5000LNX kernel: [ 8.728156] usb 2-1: new high-speed USB device number 5 using fsl-ehci
Aug 24 13:12:50 X5000LNX kernel: [ 9.057155] usb 1-1: device not accepting address 5, error -32
Aug 24 13:12:50 X5000LNX kernel: [ 9.062262] usb usb1-port1: unable to enumerate USB device
Aug 24 13:12:50 X5000LNX kernel: [ 9.145157] usb 2-1: device not accepting address 5, error -32
Aug 24 13:12:50 X5000LNX kernel: [ 9.150250] usb usb2-port1: unable to enumerate USB device
Aug 24 13:15:29 X5000LNX mtp-probe: checking bus 1, device 4: "/sys/devices/platform/ffe000000.soc/ffe210000.usb/fsl-ehci.0/usb1/1-1/1-1.3/1-1.3.1"
Aug 24 13:15:29 X5000LNX mtp-probe: checking bus 1, device 5: "/sys/devices/platform/ffe000000.soc/ffe210000.usb/fsl-ehci.0/usb1/1-1/1-1.3/1-1.3.3"
Aug 24 13:15:29 X5000LNX kernel: [ 0.242426] usbcore: registered new interface driver usbfs
Aug 24 13:15:29 X5000LNX kernel: [ 0.242457] usbcore: registered new interface driver hub
Aug 24 13:15:29 X5000LNX kernel: [ 0.242483] usbcore: registered new device driver usb
Aug 24 13:15:29 X5000LNX kernel: [ 4.744175] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
Aug 24 13:15:29 X5000LNX kernel: [ 4.755271] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
Aug 24 13:15:29 X5000LNX kernel: [ 4.778409] fsl-ehci fsl-ehci.0: new USB bus registered, assigned bus number 1
Aug 24 13:15:29 X5000LNX kernel: [ 4.810155] fsl-ehci fsl-ehci.0: USB 2.0 started, EHCI 1.00
Aug 24 13:15:29 X5000LNX kernel: [ 4.815779] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.18
Aug 24 13:15:29 X5000LNX kernel: [ 4.821424] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Aug 24 13:15:29 X5000LNX kernel: [ 4.827043] usb usb1: Product: Freescale On-Chip EHCI Host Controller
Aug 24 13:15:29 X5000LNX kernel: [ 4.832648] usb usb1: Manufacturer: Linux 4.18.0_A-EON_A1-X5000 ehci_hcd
Aug 24 13:15:29 X5000LNX kernel: [ 4.838252] usb usb1: SerialNumber: fsl-ehci.0
Aug 24 13:15:29 X5000LNX kernel: [ 4.843970] hub 1-0:1.0: USB hub found
Aug 24 13:15:29 X5000LNX kernel: [ 4.860926] fsl-ehci fsl-ehci.1: new USB bus registered, assigned bus number 2
Aug 24 13:15:29 X5000LNX kernel: [ 4.888155] fsl-ehci fsl-ehci.1: USB 2.0 started, EHCI 1.00
Aug 24 13:15:29 X5000LNX kernel: [ 4.893780] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.18
Aug 24 13:15:29 X5000LNX kernel: [ 4.899418] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Aug 24 13:15:29 X5000LNX kernel: [ 4.905035] usb usb2: Product: Freescale On-Chip EHCI Host Controller
Aug 24 13:15:29 X5000LNX kernel: [ 4.910685] usb usb2: Manufacturer: Linux 4.18.0_A-EON_A1-X5000 ehci_hcd
Aug 24 13:15:29 X5000LNX kernel: [ 4.916334] usb usb2: SerialNumber: fsl-ehci.1
Aug 24 13:15:29 X5000LNX kernel: [ 4.922102] hub 2-0:1.0: USB hub found
Aug 24 13:15:29 X5000LNX kernel: [ 4.933456] usbcore: registered new interface driver usblp
Aug 24 13:15:29 X5000LNX kernel: [ 4.944584] usbcore: registered new interface driver usb-storage
Aug 24 13:15:29 X5000LNX kernel: [ 4.950302] usbcore: registered new interface driver usbserial_generic
Aug 24 13:15:29 X5000LNX kernel: [ 4.956020] usbserial: USB Serial support registered for generic
Aug 24 13:15:29 X5000LNX kernel: [ 4.961771] usbcore: registered new interface driver ftdi_sio
Aug 24 13:15:29 X5000LNX kernel: [ 4.967488] usbserial: USB Serial support registered for FTDI USB Serial Device
Aug 24 13:15:29 X5000LNX kernel: [ 5.080757] usbcore: registered new interface driver usbhid
Aug 24 13:15:29 X5000LNX kernel: [ 5.086078] usbhid: USB HID core driver
Aug 24 13:15:29 X5000LNX kernel: [ 5.156020] usbcore: registered new interface driver snd-usb-audio
Aug 24 13:15:29 X5000LNX kernel: [ 5.161601] usbcore: registered new interface driver snd-ua101
Aug 24 13:15:29 X5000LNX kernel: [ 5.167079] usbcore: registered new interface driver snd-usb-usx2y
Aug 24 13:15:29 X5000LNX kernel: [ 5.194156] usb 1-1: new high-speed USB device number 2 using fsl-ehci
Aug 24 13:15:29 X5000LNX kernel: [ 5.258156] usb 2-1: new high-speed USB device number 2 using fsl-ehci
Aug 24 13:15:29 X5000LNX kernel: [ 5.359665] usb 1-1: New USB device found, idVendor=0424, idProduct=2514, bcdDevice= b.b3
Aug 24 13:15:29 X5000LNX kernel: [ 5.365157] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
Aug 24 13:15:29 X5000LNX kernel: [ 5.381854] hub 1-1:1.0: USB hub found
Aug 24 13:15:29 X5000LNX kernel: [ 5.403625] usb 2-1: New USB device found, idVendor=0424, idProduct=2514, bcdDevice= b.b3
Aug 24 13:15:29 X5000LNX kernel: [ 5.409165] usb 2-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
Aug 24 13:15:29 X5000LNX kernel: [ 5.414973] hub 2-1:1.0: USB hub found
Aug 24 13:15:29 X5000LNX kernel: [ 5.776517] usb 1-1.3: new high-speed USB device number 3 using fsl-ehci
Aug 24 13:15:29 X5000LNX kernel: [ 5.884557] usb 1-1.3: New USB device found, idVendor=05e3, idProduct=0608, bcdDevice=85.36
Aug 24 13:15:29 X5000LNX kernel: [ 5.890942] usb 1-1.3: New USB device strings: Mfr=0, Product=1, SerialNumber=0
Aug 24 13:15:29 X5000LNX kernel: [ 5.897266] usb 1-1.3: Product: USB2.0 Hub
Aug 24 13:15:29 X5000LNX kernel: [ 5.904039] hub 1-1.3:1.0: USB hub found
Aug 24 13:15:29 X5000LNX kernel: [ 6.201160] usb 1-1.3.1: new low-speed USB device number 4 using fsl-ehci
Aug 24 13:15:29 X5000LNX kernel: [ 6.285436] usb 1-1.3.1: New USB device found, idVendor=046d, idProduct=c040, bcdDevice=24.30
Aug 24 13:15:29 X5000LNX kernel: [ 6.291468] usb 1-1.3.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
Aug 24 13:15:29 X5000LNX kernel: [ 6.297420] usb 1-1.3.1: Product: USB-PS/2 Optical Mouse
Aug 24 13:15:29 X5000LNX kernel: [ 6.303330] usb 1-1.3.1: Manufacturer: Logitech
Aug 24 13:15:29 X5000LNX kernel: [ 6.351936] input: Logitech USB-PS/2 Optical Mouse as /devices/platform/ffe000000.soc/ffe210000.usb/fsl-ehci.0/usb1/1-1/1-1.3/1-1.3.1/1-1.3.1:1.0/0003:046D:C040.0001/input/input1
Aug 24 13:15:29 X5000LNX kernel: [ 6.368881] hid-generic 0003:046D:C040.0001: input,hidraw0: USB HID v1.10 Mouse [Logitech USB-PS/2 Optical Mouse] on usb-fsl-ehci.0-1.3.1/input0
Aug 24 13:15:29 X5000LNX kernel: [ 6.453157] usb 1-1.3.3: new low-speed USB device number 5 using fsl-ehci
Aug 24 13:15:29 X5000LNX kernel: [ 6.538443] usb 1-1.3.3: New USB device found, idVendor=046d, idProduct=c312, bcdDevice= 1.01
Aug 24 13:15:29 X5000LNX kernel: [ 6.538449] usb 1-1.3.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
Aug 24 13:15:29 X5000LNX kernel: [ 6.538452] usb 1-1.3.3: Product: USB Multimedia Keyboard
Aug 24 13:15:29 X5000LNX kernel: [ 6.538455] usb 1-1.3.3: Manufacturer: LITEON Technology
Aug 24 13:15:29 X5000LNX kernel: [ 6.542931] input: LITEON Technology USB Multimedia Keyboard as /devices/platform/ffe000000.soc/ffe210000.usb/fsl-ehci.0/usb1/1-1/1-1.3/1-1.3.3/1-1.3.3:1.0/0003:046D:C312.0002/input/input2
Aug 24 13:15:29 X5000LNX kernel: [ 6.595132] hid-generic 0003:046D:C312.0002: input,hidraw1: USB HID v1.10 Keyboard [LITEON Technology USB Multimedia Keyboard] on usb-fsl-ehci.0-1.3.3/input0
Aug 24 13:15:29 X5000LNX kernel: [ 6.660166] usb 1-1.3.4: new high-speed USB device number 6 using fsl-ehci
Aug 24 13:15:29 X5000LNX kernel: [ 6.739575] usb 1-1.3.4: New USB device found, idVendor=05e3, idProduct=0608, bcdDevice=85.36
Aug 24 13:15:29 X5000LNX kernel: [ 6.739581] usb 1-1.3.4: New USB device strings: Mfr=0, Product=1, SerialNumber=0
Aug 24 13:15:29 X5000LNX kernel: [ 6.739584] usb 1-1.3.4: Product: USB2.0 Hub
Aug 24 13:15:29 X5000LNX kernel: [ 6.742709] hub 1-1.3.4:1.0: USB hub found
Aug 24 13:25:14 X5000LNX kernel: [ 0.242539] usbcore: registered new interface driver usbfs
Aug 24 13:25:14 X5000LNX kernel: [ 0.242565] usbcore: registered new interface driver hub
Aug 24 13:25:14 X5000LNX kernel: [ 0.242589] usbcore: registered new device driver usb
Aug 24 13:25:14 X5000LNX mtp-probe: checking bus 1, device 5: "/sys/devices/platform/ffe000000.soc/ffe210000.usb/fsl-ehci.0/usb1/1-1/1-1.3/1-1.3.3"
Aug 24 13:25:14 X5000LNX mtp-probe: checking bus 1, device 4: "/sys/devices/platform/ffe000000.soc/ffe210000.usb/fsl-ehci.0/usb1/1-1/1-1.3/1-1.3.1"
Aug 24 13:25:14 X5000LNX kernel: [ 5.970493] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
Aug 24 13:25:14 X5000LNX kernel: [ 5.981581] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
Aug 24 13:25:14 X5000LNX kernel: [ 6.004760] fsl-ehci fsl-ehci.0: new USB bus registered, assigned bus number 1
Aug 24 13:25:14 X5000LNX kernel: [ 6.034042] fsl-ehci fsl-ehci.0: USB 2.0 started, EHCI 1.00
Aug 24 13:25:14 X5000LNX kernel: [ 6.045003] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
Aug 24 13:25:14 X5000LNX kernel: [ 6.050628] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Aug 24 13:25:14 X5000LNX kernel: [ 6.056227] usb usb1: Product: Freescale On-Chip EHCI Host Controller
Aug 24 13:25:14 X5000LNX kernel: [ 6.061808] usb usb1: Manufacturer: Linux 4.19-a9_A-EON_A1-X5000-gad1d697-dirty ehci_hcd
Aug 24 13:25:14 X5000LNX kernel: [ 6.067439] usb usb1: SerialNumber: fsl-ehci.0
Aug 24 13:25:14 X5000LNX kernel: [ 6.073189] hub 1-0:1.0: USB hub found
Aug 24 13:25:14 X5000LNX kernel: [ 6.090218] fsl-ehci fsl-ehci.1: new USB bus registered, assigned bus number 2
Aug 24 13:25:14 X5000LNX kernel: [ 6.118042] fsl-ehci fsl-ehci.1: USB 2.0 started, EHCI 1.00
Aug 24 13:25:14 X5000LNX kernel: [ 6.123692] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
Aug 24 13:25:14 X5000LNX kernel: [ 6.129356] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Aug 24 13:25:14 X5000LNX kernel: [ 6.134997] usb usb2: Product: Freescale On-Chip EHCI Host Controller
Aug 24 13:25:14 X5000LNX kernel: [ 6.140671] usb usb2: Manufacturer: Linux 4.19-a9_A-EON_A1-X5000-gad1d697-dirty ehci_hcd
Aug 24 13:25:14 X5000LNX kernel: [ 6.146396] usb usb2: SerialNumber: fsl-ehci.1
Aug 24 13:25:14 X5000LNX kernel: [ 6.152234] hub 2-0:1.0: USB hub found
Aug 24 13:25:14 X5000LNX kernel: [ 6.163741] usbcore: registered new interface driver usblp
Aug 24 13:25:14 X5000LNX kernel: [ 6.175014] usbcore: registered new interface driver usb-storage
Aug 24 13:25:14 X5000LNX kernel: [ 6.180806] usbcore: registered new interface driver usbserial_generic
Aug 24 13:25:14 X5000LNX kernel: [ 6.186597] usbserial: USB Serial support registered for generic
Aug 24 13:25:14 X5000LNX kernel: [ 6.192430] usbcore: registered new interface driver ftdi_sio
Aug 24 13:25:14 X5000LNX kernel: [ 6.198227] usbserial: USB Serial support registered for FTDI USB Serial Device
Aug 24 13:25:14 X5000LNX kernel: [ 6.329197] usbcore: registered new interface driver usbhid
Aug 24 13:25:14 X5000LNX kernel: [ 6.334638] usbhid: USB HID core driver
Aug 24 13:25:14 X5000LNX kernel: [ 6.407821] usbcore: registered new interface driver snd-usb-audio
Aug 24 13:25:14 X5000LNX kernel: [ 6.413589] usbcore: registered new interface driver snd-ua101
Aug 24 13:25:14 X5000LNX kernel: [ 6.419243] usbcore: registered new interface driver snd-usb-usx2y
Aug 24 13:25:14 X5000LNX kernel: [ 6.447930] usb 1-1: new high-speed USB device number 2 using fsl-ehci
Aug 24 13:25:14 X5000LNX kernel: [ 6.508045] usb 2-1: new high-speed USB device number 2 using fsl-ehci
Aug 24 13:25:14 X5000LNX kernel: [ 6.619367] usb 1-1: New USB device found, idVendor=0424, idProduct=2514, bcdDevice= b.b3
Aug 24 13:25:14 X5000LNX kernel: [ 6.624750] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
Aug 24 13:25:14 X5000LNX kernel: [ 6.630370] hub 1-1:1.0: USB hub found
Aug 24 13:25:14 X5000LNX kernel: [ 6.701977] usb 2-1: New USB device found, idVendor=0424, idProduct=2514, bcdDevice= b.b3
Aug 24 13:25:14 X5000LNX kernel: [ 6.712877] usb 2-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
Aug 24 13:25:14 X5000LNX kernel: [ 6.718604] hub 2-1:1.0: USB hub found
Aug 24 13:25:14 X5000LNX kernel: [ 6.934550] usb 1-1.3: new high-speed USB device number 3 using fsl-ehci
Aug 24 13:25:14 X5000LNX kernel: [ 7.032456] usb 1-1.3: New USB device found, idVendor=05e3, idProduct=0608, bcdDevice=85.36
Aug 24 13:25:14 X5000LNX kernel: [ 7.044709] usb 1-1.3: New USB device strings: Mfr=0, Product=1, SerialNumber=0
Aug 24 13:25:14 X5000LNX kernel: [ 7.044712] usb 1-1.3: Product: USB2.0 Hub
Aug 24 13:25:14 X5000LNX kernel: [ 7.051419] hub 1-1.3:1.0: USB hub found
Aug 24 13:25:14 X5000LNX kernel: [ 7.346067] usb 1-1.3.1: new low-speed USB device number 4 using fsl-ehci
Aug 24 13:25:14 X5000LNX kernel: [ 7.431706] usb 1-1.3.1: New USB device found, idVendor=046d, idProduct=c040, bcdDevice=24.30
Aug 24 13:25:14 X5000LNX kernel: [ 7.431710] usb 1-1.3.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
Aug 24 13:25:14 X5000LNX kernel: [ 7.431713] usb 1-1.3.1: Product: USB-PS/2 Optical Mouse
Aug 24 13:25:14 X5000LNX kernel: [ 7.431715] usb 1-1.3.1: Manufacturer: Logitech
Aug 24 13:25:14 X5000LNX kernel: [ 7.435139] input: Logitech USB-PS/2 Optical Mouse as /devices/platform/ffe000000.soc/ffe210000.usb/fsl-ehci.0/usb1/1-1/1-1.3/1-1.3.1/1-1.3.1:1.0/0003:046D:C040.0001/input/input1
Aug 24 13:25:14 X5000LNX kernel: [ 7.435344] hid-generic 0003:046D:C040.0001: input,hidraw0: USB HID v1.10 Mouse [Logitech USB-PS/2 Optical Mouse] on usb-fsl-ehci.0-1.3.1/input0
Aug 24 13:25:14 X5000LNX kernel: [ 7.513047] usb 1-1.3.3: new low-speed USB device number 5 using fsl-ehci
Aug 24 13:25:14 X5000LNX kernel: [ 7.598242] usb 1-1.3.3: New USB device found, idVendor=046d, idProduct=c312, bcdDevice= 1.01
Aug 24 13:25:14 X5000LNX kernel: [ 7.604200] usb 1-1.3.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
Aug 24 13:25:14 X5000LNX kernel: [ 7.610075] usb 1-1.3.3: Product: USB Multimedia Keyboard
Aug 24 13:25:14 X5000LNX kernel: [ 7.615963] usb 1-1.3.3: Manufacturer: LITEON Technology
Aug 24 13:25:14 X5000LNX kernel: [ 7.625717] input: LITEON Technology USB Multimedia Keyboard as /devices/platform/ffe000000.soc/ffe210000.usb/fsl-ehci.0/usb1/1-1/1-1.3/1-1.3.3/1-1.3.3:1.0/0003:046D:C312.0002/input/input2
Aug 24 13:25:14 X5000LNX kernel: [ 7.677499] hid-generic 0003:046D:C312.0002: input,hidraw1: USB HID v1.10 Keyboard [LITEON Technology USB Multimedia Keyboard] on usb-fsl-ehci.0-1.3.3/input0
Aug 24 13:25:14 X5000LNX kernel: [ 7.742055] usb 1-1.3.4: new high-speed USB device number 6 using fsl-ehci
Aug 24 13:25:14 X5000LNX kernel: [ 7.821429] usb 1-1.3.4: New USB device found, idVendor=05e3, idProduct=0608, bcdDevice=85.36
Aug 24 13:25:14 X5000LNX kernel: [ 7.821435] usb 1-1.3.4: New USB device strings: Mfr=0, Product=1, SerialNumber=0
Aug 24 13:25:14 X5000LNX kernel: [ 7.821438] usb 1-1.3.4: Product: USB2.0 Hub
Aug 24 13:25:14 X5000LNX kernel: [ 7.822401] hub 1-1.3.4:1.0: USB hub found
Aug 24 13:58:06 X5000LNX mtp-probe: checking bus 1, device 5: "/sys/devices/platform/ffe000000.soc/ffe210000.usb/fsl-ehci.0/usb1/1-1/1-1.3/1-1.3.3"
Aug 24 13:58:06 X5000LNX mtp-probe: checking bus 1, device 4: "/sys/devices/platform/ffe000000.soc/ffe210000.usb/fsl-ehci.0/usb1/1-1/1-1.3/1-1.3.1"
Aug 24 13:58:06 X5000LNX kernel: [ 0.239974] usbcore: registered new interface driver usbfs
Aug 24 13:58:06 X5000LNX kernel: [ 0.240003] usbcore: registered new interface driver hub
Aug 24 13:58:06 X5000LNX kernel: [ 0.240029] usbcore: registered new device driver usb
Aug 24 13:58:06 X5000LNX kernel: [ 5.967849] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
Aug 24 13:58:06 X5000LNX kernel: [ 5.978915] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
Aug 24 13:58:06 X5000LNX kernel: [ 6.002032] fsl-ehci fsl-ehci.0: new USB bus registered, assigned bus number 1
Aug 24 13:58:06 X5000LNX kernel: [ 6.032481] fsl-ehci fsl-ehci.0: USB 2.0 started, EHCI 1.00
Aug 24 13:58:06 X5000LNX kernel: [ 6.038096] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
Aug 24 13:58:06 X5000LNX kernel: [ 6.043737] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Aug 24 13:58:06 X5000LNX kernel: [ 6.049349] usb usb1: Product: Freescale On-Chip EHCI Host Controller
Aug 24 13:58:06 X5000LNX kernel: [ 6.054953] usb usb1: Manufacturer: Linux 4.19-a9_A-EON_A1-X5000-gad1d697-dirty ehci_hcd
Aug 24 13:58:06 X5000LNX kernel: [ 6.060607] usb usb1: SerialNumber: fsl-ehci.0
Aug 24 13:58:06 X5000LNX kernel: [ 6.066372] hub 1-0:1.0: USB hub found
Aug 24 13:58:06 X5000LNX kernel: [ 6.083479] fsl-ehci fsl-ehci.1: new USB bus registered, assigned bus number 2
Aug 24 13:58:06 X5000LNX kernel: [ 6.110481] fsl-ehci fsl-ehci.1: USB 2.0 started, EHCI 1.00
Aug 24 13:58:06 X5000LNX kernel: [ 6.116164] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
Aug 24 13:58:06 X5000LNX kernel: [ 6.121854] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Aug 24 13:58:06 X5000LNX kernel: [ 6.127521] usb usb2: Product: Freescale On-Chip EHCI Host Controller
Aug 24 13:58:06 X5000LNX kernel: [ 6.133217] usb usb2: Manufacturer: Linux 4.19-a9_A-EON_A1-X5000-gad1d697-dirty ehci_hcd
Aug 24 13:58:06 X5000LNX kernel: [ 6.138966] usb usb2: SerialNumber: fsl-ehci.1
Aug 24 13:58:06 X5000LNX kernel: [ 6.144824] hub 2-0:1.0: USB hub found
Aug 24 13:58:06 X5000LNX kernel: [ 6.162151] usbcore: registered new interface driver usblp
Aug 24 13:58:06 X5000LNX kernel: [ 6.167983] usbcore: registered new interface driver usb-storage
Aug 24 13:58:06 X5000LNX kernel: [ 6.173836] usbcore: registered new interface driver usbserial_generic
Aug 24 13:58:06 X5000LNX kernel: [ 6.179688] usbserial: USB Serial support registered for generic
Aug 24 13:58:06 X5000LNX kernel: [ 6.185577] usbcore: registered new interface driver ftdi_sio
Aug 24 13:58:06 X5000LNX kernel: [ 6.191433] usbserial: USB Serial support registered for FTDI USB Serial Device
Aug 24 13:58:06 X5000LNX kernel: [ 6.321704] usbcore: registered new interface driver usbhid
Aug 24 13:58:06 X5000LNX kernel: [ 6.327196] usbhid: USB HID core driver
Aug 24 13:58:06 X5000LNX kernel: [ 6.398341] usbcore: registered new interface driver snd-usb-audio
Aug 24 13:58:06 X5000LNX kernel: [ 6.404149] usbcore: registered new interface driver snd-ua101
Aug 24 13:58:06 X5000LNX kernel: [ 6.409850] usbcore: registered new interface driver snd-usb-usx2y
Aug 24 13:58:06 X5000LNX kernel: [ 6.438736] usb 1-1: new high-speed USB device number 2 using fsl-ehci
Aug 24 13:58:06 X5000LNX kernel: [ 6.518489] usb 2-1: new high-speed USB device number 2 using fsl-ehci
Aug 24 13:58:06 X5000LNX kernel: [ 6.604921] usb 1-1: New USB device found, idVendor=0424, idProduct=2514, bcdDevice= b.b3
Aug 24 13:58:06 X5000LNX kernel: [ 6.610394] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
Aug 24 13:58:06 X5000LNX kernel: [ 6.621624] hub 1-1:1.0: USB hub found
Aug 24 13:58:06 X5000LNX kernel: [ 6.705473] usb 2-1: New USB device found, idVendor=0424, idProduct=2514, bcdDevice= b.b3
Aug 24 13:58:06 X5000LNX kernel: [ 6.711012] usb 2-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
Aug 24 13:58:06 X5000LNX kernel: [ 6.716783] hub 2-1:1.0: USB hub found
Aug 24 13:58:06 X5000LNX kernel: [ 6.957489] usb 1-1.3: new high-speed USB device number 3 using fsl-ehci
Aug 24 13:58:06 X5000LNX kernel: [ 7.065828] usb 1-1.3: New USB device found, idVendor=05e3, idProduct=0608, bcdDevice=85.36
Aug 24 13:58:06 X5000LNX kernel: [ 7.072259] usb 1-1.3: New USB device strings: Mfr=0, Product=1, SerialNumber=0
Aug 24 13:58:06 X5000LNX kernel: [ 7.078578] usb 1-1.3: Product: USB2.0 Hub
Aug 24 13:58:06 X5000LNX kernel: [ 7.085287] hub 1-1.3:1.0: USB hub found
Aug 24 13:58:06 X5000LNX kernel: [ 7.381487] usb 1-1.3.1: new low-speed USB device number 4 using fsl-ehci
Aug 24 13:58:06 X5000LNX kernel: [ 7.472844] usb 1-1.3.1: New USB device found, idVendor=046d, idProduct=c040, bcdDevice=24.30
Aug 24 13:58:06 X5000LNX kernel: [ 7.478679] usb 1-1.3.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
Aug 24 13:58:06 X5000LNX kernel: [ 7.484510] usb 1-1.3.1: Product: USB-PS/2 Optical Mouse
Aug 24 13:58:06 X5000LNX kernel: [ 7.490289] usb 1-1.3.1: Manufacturer: Logitech
Aug 24 13:58:06 X5000LNX kernel: [ 7.511783] input: Logitech USB-PS/2 Optical Mouse as /devices/platform/ffe000000.soc/ffe210000.usb/fsl-ehci.0/usb1/1-1/1-1.3/1-1.3.1/1-1.3.1:1.0/0003:046D:C040.0001/input/input1
Aug 24 13:58:06 X5000LNX kernel: [ 7.515063] hid-generic 0003:046D:C040.0001: input,hidraw0: USB HID v1.10 Mouse [Logitech USB-PS/2 Optical Mouse] on usb-fsl-ehci.0-1.3.1/input0
Aug 24 13:58:06 X5000LNX kernel: [ 7.587504] usb 1-1.3.3: new low-speed USB device number 5 using fsl-ehci
Aug 24 13:58:06 X5000LNX kernel: [ 7.679739] usb 1-1.3.3: New USB device found, idVendor=046d, idProduct=c312, bcdDevice= 1.01
Aug 24 13:58:06 X5000LNX kernel: [ 7.679745] usb 1-1.3.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
Aug 24 13:58:06 X5000LNX kernel: [ 7.679747] usb 1-1.3.3: Product: USB Multimedia Keyboard
Aug 24 13:58:06 X5000LNX kernel: [ 7.679750] usb 1-1.3.3: Manufacturer: LITEON Technology
Aug 24 13:58:06 X5000LNX kernel: [ 7.683227] input: LITEON Technology USB Multimedia Keyboard as /devices/platform/ffe000000.soc/ffe210000.usb/fsl-ehci.0/usb1/1-1/1-1.3/1-1.3.3/1-1.3.3:1.0/0003:046D:C312.0002/input/input2
Aug 24 13:58:06 X5000LNX kernel: [ 7.735387] hid-generic 0003:046D:C312.0002: input,hidraw1: USB HID v1.10 Keyboard [LITEON Technology USB Multimedia Keyboard] on usb-fsl-ehci.0-1.3.3/input0
Aug 24 13:58:06 X5000LNX kernel: [ 7.802488] usb 1-1.3.4: new high-speed USB device number 6 using fsl-ehci
Aug 24 13:58:06 X5000LNX kernel: [ 7.881866] usb 1-1.3.4: New USB device found, idVendor=05e3, idProduct=0608, bcdDevice=85.36
Aug 24 13:58:06 X5000LNX kernel: [ 7.881872] usb 1-1.3.4: New USB device strings: Mfr=0, Product=1, SerialNumber=0
Aug 24 13:58:06 X5000LNX kernel: [ 7.881874] usb 1-1.3.4: Product: USB2.0 Hub
Aug 24 13:58:06 X5000LNX kernel: [ 7.882840] hub 1-1.3.4:1.0: USB hub found
skateman@X5000LNX:~$ grep -i -E 'usb.*error' /var/log/syslog
Re: Kernel 4.19
Please add mem=3500M to the boot arguments and test USB again.
