Linux on Sams -Screenshots-
Setting up an NTFS partition that can be accessed by both AmigaOS 4.1 and Linux.
You can create an NTFS partition for transfer between AMIGAOS 4.1 and Linux.
The NTFileSystem3G plugin in AMIGOS 4.1 works very well.
Create the partition under AmigaOS 4.1 and format it as NTFS under Linux.
Create the DOSdriver for AmigaOS using giggledisk.
the partition with dostype 0x4E544653 is the NTFS partition in the giggledisk created mountlist .
You will need to edit the FileSystem line to
FileSystem = L:NTFileSystem3G
Testing QEMU.
Slow but works .
Testing E-UAE.
Spectre660 wrote:Testing E-UAE.
Impressive!!!!
Thank you.
I was pushed by Mike Blackburn........
The Jit speed is slow for some reason though .
Impressive!!!!
RadeonHD 7750 "kind of working" on Sam460ex with Kernel 3.19 under Ununtu 15.04 and Debian Jessie.
Something not quite right with the microcode loading and HDMI audio not working .
PCIex1 sii3132 SATA II esata controller card working in Sam460ex. (Booting not supported in Uboot)
Card compliments of ACube. Thanks guys :D .
AQemu Qemu front end .
Kernel 4.1
Lubuntu 15.10 with the new Xorg server 2:1.17.2-1. The colours are correct on the Sam460ex now. :-)
