SliTaz PPC Linux
aperezbios
Re: SliTaz PPC Linux
Post by aperezbios »
I can confirm that this works on my PASemi Electra reference board, with the most recent Electra-specific kernel you built. In my case, I loaded the payloads via tftp:
CFE> ramdisk -tftp 1.2.3.4:slitaz23.gz
CFE> boot -elf -tftp 192.168.2.246:vmlinux-3.14
Loader:elf Filesys:tftp Dev:eth0 File:1.2.3.4:PPC/vmlinux-3.14 Options:(null)
Loading: 0x0000000000000000/13282688 0x0000000000CAAD80/594140 Entry at 0x0000000000000000
Closing network.
Starting program at 0x0000000000000000
[RUN!]console is uart0
OF stdout device is: /pxp@0,80000000/serial@1d
Preparing to boot Linux version 3.14.0 (christian@AmigaoneX1000) (gcc version 4.6.4 (Debian 4.6.4-5) ) #1 SMP M
on Mar 31 13:41:15 CEST 2014
Detected machine type: 0000000000000500
aperezbios wrote:Christian
Closing network.
Woowwwwww! Amazing :-) Impressive :-) Thank you for testing!
Snapshot 24 is available. :-)
- added Xpdf version 3.03
Download: slitaz24.gz
If you got this message (Busybox : Using fallback suid method) when you login as a user, then execute the following command:
chmod u+s /bin/busybox
Just for info: What is BusyBox and passwords + users on SliTaz:
User "amigaone" with password "amigaone"
User "root" with password "amigaone"
What is BusyBox?
BusyBox provides several stripped-down Unix tools in a single executable file. It is beside the Linux kernel the most important part of SliTaz.
Have a lot of fun with SliTaz PPC Linux. :-)
And here is the next snapshot. :D
  1. Set SUID bit for the BusyBox binary
  2. Added Xosview - X based system monitor
  3. Added xeyes - a follow the mouse X demo
  4. Added xclock - analog / digital clock for X
Download: slitaz25.gz
You can boot it with following commands:
CFE> ramdisk -z -addr=0x24000000 -fatfs cf0:slitaz25.gz
CFE> boot -elf -noints -fatfs cf0:vmlinux-3.13.14
SliTaz login via SSH:
The graphical user interface of SliTaz is AmiWM. It tries to make your display look and feel like an Amiga Workbench screen. It is fully functional and can do all the usual window manager stuff, like moving and resizing windows. You can start AmiWM with the script "startamiwm".
The script startamiwm contains the following command:
Xfbdev -retro -mouse mouse,device=/dev/input/mice -keybd evdev,,device=/dev/input/event0 | xterm -e amiwm
Sometimes, the keyboard isn't connected to the device file event0. Please try event1 instead.
Xfbdev -retro -mouse mouse,device=/dev/input/mice -keybd evdev,,device=/dev/input/event1 | xterm -e amiwm
SliTaz PPC Linux with the final kernel 4.9:
Hi Cristian
How do you write the CFE MENU command line to SliTaz? It is the statement of the RAM disk I can not figure out.
musa wrote:Hi Cristian
Here is my CFE entry for SliTaz:
MENU_4_LABEL=SliTaz Snapshot 25 Kernel 4.9
MENU_4_COMMAND=set pmu -astate=A4 ; ramdisk -z -addr=0x24000000 -fatfs cf0:slitaz25.gz ; boot -elf -noints -fatfs cf0:vmlinux-4.9
Instructions for creating:
CFE> setenv -p MENU_4_LABEL "SliTaz Snapshot 25 Kernel 4.9"
CFE> setenv -p MENU_4_COMMAND 'set pmu -astate=A4 ; ramdisk -z -addr=0x24000000 -fatfs cf0:slitaz25.gz ; boot -elf -noints -fatfs cf0:vmlinux-4.9'
