The final kernel 6.3 has been released. After solving the issue with the detection of the number of CPUs (cores) and testing the new NVMe support, we have a stable final kernel 6.3. Many thanks to Gordini21, Skateman, Roland, and Peter (Musa) for testing the alphas and release candidates. :-)
Download: linux-image-6.3-X1000_X5000.tar.gz
X5000 users: Please Note: If you use an uInitrd for example for booting with a LABEL, then load the dtb file to the address 1d00000. The kernel has grown in recent months so the address 1c00000 is used by the uImage. Before we have loaded the dtb to the address 1c00000.
X5000> bootm 1000000 2000000 1d00000
Hi
Kernel vmlinux-6.3 boot Debian 64 bookworm.
I can't boot Fienix. Same error as before .
Ends with kernel panic. There is no error on other systems on that harddisk
and Fienix works with my standard kernel
Have a nice day
musa wrote: Mon Apr 24, 2023 2:55 pm Hi
Have a nice day
Thanks a lot for testing! :-) Have you used set pmu -state=A4 for Fienix?
xeno74 wrote: Mon Apr 24, 2023 3:30 pm
yes but it only worked for rc6 not for this and rc7.
It is very strange
musa wrote: Mon Apr 24, 2023 4:39 pm yes but it only worked for rc6 not for this and rc7.
It is very strange
I think you have to check the boot arguments.
xeno74 wrote: Mon Apr 24, 2023 4:54 pm
It is very strange
Theý are the same as I use in cfe menu
set pmu -state=A4
setenv bootargs "root=/dev/sdc?"
boot -elf -noints -fatfs usbdisk0:vmlinux-?.?
I start ubuntu 16.04, ubuntu 17 remix , Fienix , Debian 64 , Debian 32, void and Adelie with this commands and it works.
Peter,
Strange. Unfortunately I don’t have a solution for this issue. The kernel finds the sdc if you boot with other distributions. With Fienix, it doesn’t find it.
Sorry,
The alpha1 of kernel 6.4 doesn't build.
Error messages:
drivers/gpu/drm/ttm/ttm_pool.c:73:29: error: variably modified 'global_write_combined' at file scope
   73 | static struct ttm_pool_type global_write_combined[TTM_DIM_ORDER];
drivers/gpu/drm/ttm/ttm_pool.c:74:29: error: variably modified 'global_uncached' at file scope
   74 | static struct ttm_pool_type global_uncached[TTM_DIM_ORDER];
drivers/gpu/drm/ttm/ttm_pool.c:76:29: error: variably modified 'global_dma32_write_combined' at file scope
   76 | static struct ttm_pool_type global_dma32_write_combined[TTM_DIM_ORDER];
drivers/gpu/drm/ttm/ttm_pool.c:77:29: error: variably modified 'global_dma32_uncached' at file scope
   77 | static struct ttm_pool_type global_dma32_uncached[TTM_DIM_ORDER];
make[5]: *** [scripts/Makefile.build:252: drivers/gpu/drm/ttm/ttm_pool.o] Error 1
make[4]: *** [scripts/Makefile.build:494: drivers/gpu/drm/ttm] Error 2
make[3]: *** [scripts/Makefile.build:494: drivers/gpu/drm] Error 2
make[2]: *** [scripts/Makefile.build:494: drivers/gpu] Error 2
make[1]: *** [scripts/Makefile.build:494: drivers] Error 2
make[1]: *** Waiting for unfinished jobs....
There is a discussion about this issue:
drm/ttm: Reduce the number of used allocation orders for TTM pages
There is a patch:
diff --git a/drivers/gpu/drm/ttm/ttm_pool.c b/drivers/gpu/drm/ttm/ttm_pool.c
index 18c342a919a2..dfce896c4bae 100644
--- a/drivers/gpu/drm/ttm/ttm_pool.c
+++ b/drivers/gpu/drm/ttm/ttm_pool.c
@@ -47,11 +47,6 @@
 #include "ttm_module.h"
-#define TTM_MAX_ORDER (PMD_SHIFT - PAGE_SHIFT)
-#define __TTM_DIM_ORDER (TTM_MAX_ORDER + 1)
-/* Some architectures have a weird PMD_SHIFT */
-#define TTM_DIM_ORDER (__TTM_DIM_ORDER <= MAX_ORDER ? __TTM_DIM_ORDER : MAX_ORDER)
  * struct ttm_pool_dma - Helper object for coherent DMA mappings
@@ -70,11 +65,11 @@ module_param(page_pool_size, ulong, 0644);
 static atomic_long_t allocated_pages;
-static struct ttm_pool_type global_write_combined[TTM_DIM_ORDER];
-static struct ttm_pool_type global_uncached[TTM_DIM_ORDER];
+static struct ttm_pool_type global_write_combined[MAX_ORDER];
+static struct ttm_pool_type global_uncached[MAX_ORDER];
-static struct ttm_pool_type global_dma32_write_combined[TTM_DIM_ORDER];
-static struct ttm_pool_type global_dma32_uncached[TTM_DIM_ORDER];
+static struct ttm_pool_type global_dma32_write_combined[MAX_ORDER];
+static struct ttm_pool_type global_dma32_uncached[MAX_ORDER];
 static spinlock_t shrinker_lock;
 static struct list_head shrinker_list;
@@ -449,7 +444,7 @@ int ttm_pool_alloc(struct ttm_pool *pool, struct ttm_tt *tt,
 	else
 		gfp_flags |= GFP_HIGHUSER;
-	for (order = min_t(unsigned int, TTM_MAX_ORDER, __fls(num_pages));
+	for (order = min_t(unsigned int, MAX_ORDER - 1, __fls(num_pages));
 	     num_pages;
 	     order = min_t(unsigned int, order, __fls(num_pages))) {
 		struct ttm_pool_type *pt;
@@ -568,7 +563,7 @@ void ttm_pool_init(struct ttm_pool *pool, struct device *dev,
 	if (use_dma_alloc) {
 		for (i = 0; i < TTM_NUM_CACHING_TYPES; ++i)
-			for (j = 0; j < TTM_DIM_ORDER; ++j)
+			for (j = 0; j < MAX_ORDER; ++j)
 				ttm_pool_type_init(&pool->caching[i].orders[j],
 						   pool, i, j);
@@ -588,7 +583,7 @@ void ttm_pool_fini(struct ttm_pool *pool)
 	if (pool->use_dma_alloc) {
 				ttm_pool_type_fini(&pool->caching[i].orders[j]);
@@ -642,7 +637,7 @@ static void ttm_pool_debugfs_header(struct seq_file *m)
 	unsigned int i;
 	seq_puts(m, "\t ");
-	for (i = 0; i < TTM_DIM_ORDER; ++i)
+	for (i = 0; i < MAX_ORDER; ++i)
 		seq_printf(m, " ---%2u---", i);
 	seq_puts(m, "\n");
@@ -653,7 +648,7 @@ static void ttm_pool_debugfs_orders(struct ttm_pool_type *pt,
 	unsigned int i;
 		seq_printf(m, " %8u", ttm_pool_type_count(&pt[i]));
 	seq_puts(m, "\n");
@@ -756,16 +751,13 @@ int ttm_pool_mgr_init(unsigned long num_pages)
 	unsigned int i;
-	BUILD_BUG_ON(TTM_DIM_ORDER > MAX_ORDER);
-	BUILD_BUG_ON(TTM_DIM_ORDER < 1);
 	if (!page_pool_size)
 		page_pool_size = num_pages;
 	spin_lock_init(&shrinker_lock);
 	INIT_LIST_HEAD(&shrinker_list);
-	for (i = 0; i < TTM_DIM_ORDER; ++i) {
+	for (i = 0; i < MAX_ORDER; ++i) {
 		ttm_pool_type_init(&global_write_combined[i], NULL,
 				   ttm_write_combined, i);
 		ttm_pool_type_init(&global_uncached[i], NULL, ttm_uncached, i);
@@ -798,7 +790,7 @@ void ttm_pool_mgr_fini(void)
 	unsigned int i;
 		ttm_pool_type_fini(&global_write_combined[i]);
 		ttm_pool_type_fini(&global_uncached[i]);
Link: drm/ttm: revert "Reduce the number of used allocation orders for TTM pages"
Kernel 6.4:
Hans Verkuil has dropped the overlay support for BTTV TV cards. That means, that tvtime doesn't work anymore.
Hans Verkuil wrote: Destructive overlay support (i.e. where the video frame is DMA-ed
straight into a framebuffer) is effectively dead. It was a
necessary evil in the early days when computers were not fast enough
to copy SDTV video frames around, but today that's no longer a problem.
It requires access to the framebuffer memory, which is a bad idea and
very hard to do safely. In addition, in drm it is today almost
impossible to get hold of the framebuffer address.
So drop support for this.
bttv: drop overlay support
Link: [BTTV] [FSL P50x0] [PASEMI] TV Time doesn't work anymore after dropping the overlay support -- lore.kernel.org/linux-media
I created a patch for adding overlay support again. Additionally, I created the bttv kernel modules with this patch for the alpha1 of kernel 6.4.
Download: bttv_modules_with_overlay_support_6.4-alpha1.tar.gz
Installation instructions for example for the X5000:
  1. Code: Select all
    # rm -rf /lib/modules/6.4.0-a1_A-EON_X5000-g0cfd8703e7da-dirty/kernel/drivers/media/pci/bt8xx
  2. Code: Select all
    # cp -R bttv_modules_with_overlay_support_6.4-alpha1/X5000/bt8xx /lib/modules/6.4.0-a1_A-EON_X5000-g0cfd8703e7da-dirty/kernel/drivers/media/pci/
  3. Code: Select all
    reboot
