Kernel 6.0 RC6 is running fine on my AmigaOne X5000
Big picture: https://www.skateman.nl/wp-content/uplo ... -39-41.png
Skateman wrote: Thu Sep 22, 2022 9:42 pm Kernel 6.0 RC6 is running fine on my AmigaOne X5000
There is a bug in the VirtIO GPU driver since the RC7 of kernel 6.0.
QEMU command:
qemu-system-ppc64 -M ppce500 -cpu e5500 -m 1024 -kernel uImage-6.0 -drive format=raw,file=void-live-powerpc-20220129.img,index=0,if=virtio -netdev user,id=mynet0 -device virtio-net,netdev=mynet0 -append "rw root=/dev/vda2" -device virtio-gpu -device virtio-mouse-pci -device virtio-keyboard-pci -device pci-ohci,id=newusb -audiodev id=sndbe,driver=pa,server=/run/user/1000/pulse/native -device usb-audio,bus=newusb.0 -enable-kvm -smp 4 -fsdev local,security_model=passthrough,id=fsdev0,path=/home/amigaone/Music -device virtio-9p-pci,id=fs0,fsdev=fsdev0,mount_tag=hostshare
dmesg with error messages:
Activating Kernel Userspace Execution Prevention
MMU: Supported page sizes
         4 KB as direct
      4096 KB as direct
     16384 KB as direct
     65536 KB as direct
    262144 KB as direct
   1048576 KB as direct
MMU: Book3E HW tablewalk not supported
Linux version 6.0.0-rc7_A-EON_X5000 (christian@ubuntu_22.04) (powerpc-linux-gnu-gcc (Ubuntu 11.2.0-17ubuntu1) 11.2.0, GNU ld (GNU Binutils for Ubuntu) 2.38) #1 SMP Mon Sep 26 04:51:18 CEST 2022
Using QEMU e500 machine description
printk: bootconsole [udbg0] enabled
CPU maps initialized for 1 thread per core
phys_mem_size     = 0x40000000
dcache_bsize      = 0x40
icache_bsize      = 0x40
cpu_features      = 0x0000000300800194
  possible        = 0x0000000300900394
  always          = 0x0000000300800394
cpu_user_features = 0xcc008000 0x08000000
mmu_features      = 0x000a0010
firmware_features = 0x0000000000000000
qemu_e500_setup_arch()
barrier-nospec: using isync; sync as speculation barrier
Zone ranges:
  DMA      [mem 0x0000000000000000-0x000000003fffffff]
  Normal   empty
Movable zone start for each node
Early memory node ranges
  node   0: [mem 0x0000000000000000-0x000000003fffffff]
Initmem setup node 0 [mem 0x0000000000000000-0x000000003fffffff]
MMU: Allocated 2112 bytes of context maps for 255 contexts
percpu: Embedded 17 pages/cpu s30800 r0 d38832 u262144
Built 1 zonelists, mobility grouping on.  Total pages: 258560
Kernel command line: rw root=/dev/vda2
Dentry cache hash table entries: 131072 (order: 8, 1048576 bytes, linear)
Inode-cache hash table entries: 65536 (order: 7, 524288 bytes, linear)
mem auto-init: stack:off, heap alloc:off, heap free:off
Memory: 1002724K/1048576K available (14460K kernel code, 1372K rwdata, 9724K rodata, 436K init, 697K bss, 45852K reserved, 0K cma-reserved)
SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
rcu: Hierarchical RCU implementation.
rcu: RCU calculated value of scheduler-enlistment delay is 100 jiffies.
NR_IRQS: 512, nr_irqs: 512, preallocated irqs: 16
mpic: Setting up MPIC " OpenPIC  " version 1.2 at fe0040000, max 4 CPUs
mpic: ISU size: 256, shift: 8, mask: ff
mpic: Initializing for 256 sources
rcu: srcu_init: Setting srcu_struct sizes based on contention.
clocksource: timebase: mask: 0xffffffffffffffff max_cycles: 0xb8812736b, max_idle_ns: 440795202655 ns
clocksource: timebase mult[14000000] shift[24] registered
Console: colour dummy device 80x25
pid_max: default: 32768 minimum: 301
Mount-cache hash table entries: 2048 (order: 2, 16384 bytes, linear)
Mountpoint-cache hash table entries: 2048 (order: 2, 16384 bytes, linear)
e500 family performance monitor hardware support registered
rcu: Hierarchical SRCU implementation.
rcu: 	Max phase no-delay instances is 400.
smp: Bringing up secondary CPUs ...
smp: Brought up 1 node, 4 CPUs
devtmpfs: initialized
clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275000 ns
futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
Machine: QEMU ppce500
SoC family: QorIQ
SoC ID: svr:0x00000000, Revision: 0.0
NET: Registered PF_NETLINK/PF_ROUTE protocol family
thermal_sys: Registered thermal governor 'step_wise'
cpuidle: using governor ladder
cpuidle: using governor menu
Found FSL PCI host bridge at 0x0000000fe0008000. Firmware bus number: 0->255
PCI host bridge /pci@fe0008000 (primary) ranges:
 MEM 0x0000000c00000000..0x0000000c1fffffff -> 0x00000000e0000000
  IO 0x0000000fe1000000..0x0000000fe100ffff -> 0x0000000000000000
/pci@fe0008000: PCICSRBAR @ 0xdff00000
setup_pci_atmu: end of DRAM 40000000
PCI: Probing PCI hardware
fsl-pci fe0008000.pci: PCI host bridge to bus 0000:00
pci_bus 0000:00: root bus resource [io  0xc000180000010000-0xc00018000001ffff] (bus address [0x0000-0xffff])
pci_bus 0000:00: root bus resource [mem 0xc00000000-0xc1fffffff] (bus address [0xe0000000-0xffffffff])
pci_bus 0000:00: root bus resource [bus 00-ff]
pci_bus 0000:00: busn_res: [bus 00-ff] end is updated to ff
pci 0000:00:00.0: [1957:0030] type 00 class 0x0b2000
pci 0000:00:00.0: reg 0x10: [mem 0xdff00000-0xdfffffff]
pci 0000:00:01.0: [1af4:1000] type 00 class 0x020000
pci 0000:00:01.0: reg 0x10: [io  0xc000180000010000-0xc00018000001001f]
pci 0000:00:01.0: reg 0x14: [mem 0x00000000-0x00000fff]
pci 0000:00:01.0: reg 0x20: [mem 0x00000000-0x00003fff 64bit pref]
pci 0000:00:01.0: reg 0x30: [mem 0x00000000-0x0003ffff pref]
pci 0000:00:02.0: [1af4:1050] type 00 class 0x038000
pci 0000:00:02.0: reg 0x14: [mem 0x00000000-0x00000fff]
pci 0000:00:02.0: reg 0x20: [mem 0x00000000-0x00003fff 64bit pref]
pci 0000:00:03.0: [1af4:1052] type 00 class 0x090200
pci 0000:00:03.0: reg 0x14: [mem 0x00000000-0x00000fff]
pci 0000:00:03.0: reg 0x20: [mem 0x00000000-0x00003fff 64bit pref]
pci 0000:00:04.0: [1af4:1052] type 00 class 0x090000
pci 0000:00:04.0: reg 0x14: [mem 0x00000000-0x00000fff]
pci 0000:00:04.0: reg 0x20: [mem 0x00000000-0x00003fff 64bit pref]
pci 0000:00:05.0: [106b:003f] type 00 class 0x0c0310
pci 0000:00:05.0: reg 0x10: [mem 0x00000000-0x000000ff]
pci 0000:00:06.0: [1af4:1009] type 00 class 0x000200
pci 0000:00:06.0: reg 0x10: [io  0xc000180000010000-0xc00018000001003f]
pci 0000:00:06.0: reg 0x14: [mem 0x00000000-0x00000fff]
pci 0000:00:06.0: reg 0x20: [mem 0x00000000-0x00003fff 64bit pref]
pci 0000:00:07.0: [1af4:1001] type 00 class 0x010000
pci 0000:00:07.0: reg 0x10: [io  0xc000180000010000-0xc00018000001007f]
pci 0000:00:07.0: reg 0x14: [mem 0x00000000-0x00000fff]
pci 0000:00:07.0: reg 0x20: [mem 0x00000000-0x00003fff 64bit pref]
pci_bus 0000:00: busn_res: [bus 00-ff] end is updated to 00
pci 0000:00:01.0: BAR 6: assigned [mem 0xc00000000-0xc0003ffff pref]
pci 0000:00:01.0: BAR 4: assigned [mem 0xc00040000-0xc00043fff 64bit pref]
pci 0000:00:02.0: BAR 4: assigned [mem 0xc00044000-0xc00047fff 64bit pref]
pci 0000:00:03.0: BAR 4: assigned [mem 0xc00048000-0xc0004bfff 64bit pref]
pci 0000:00:04.0: BAR 4: assigned [mem 0xc0004c000-0xc0004ffff 64bit pref]
pci 0000:00:06.0: BAR 4: assigned [mem 0xc00050000-0xc00053fff 64bit pref]
pci 0000:00:07.0: BAR 4: assigned [mem 0xc00054000-0xc00057fff 64bit pref]
pci 0000:00:01.0: BAR 1: assigned [mem 0xc00058000-0xc00058fff]
pci 0000:00:02.0: BAR 1: assigned [mem 0xc00059000-0xc00059fff]
pci 0000:00:03.0: BAR 1: assigned [mem 0xc0005a000-0xc0005afff]
pci 0000:00:04.0: BAR 1: assigned [mem 0xc0005b000-0xc0005bfff]
pci 0000:00:06.0: BAR 1: assigned [mem 0xc0005c000-0xc0005cfff]
pci 0000:00:07.0: BAR 1: assigned [mem 0xc0005d000-0xc0005dfff]
pci 0000:00:05.0: BAR 0: assigned [mem 0xc0005e000-0xc0005e0ff]
pci 0000:00:07.0: BAR 0: assigned [io  0xc000180000010000-0xc00018000001007f]
pci 0000:00:06.0: BAR 0: assigned [io  0xc000180000010080-0xc0001800000100bf]
pci 0000:00:01.0: BAR 0: assigned [io  0xc0001800000100c0-0xc0001800000100df]
pci_bus 0000:00: resource 4 [io  0xc000180000010000-0xc00018000001ffff]
pci_bus 0000:00: resource 5 [mem 0xc00000000-0xc1fffffff]
raid6: int64x8  gen()  1040 MB/s
raid6: int64x4  gen()  1224 MB/s
raid6: int64x2  gen()  1971 MB/s
raid6: int64x1  gen()  1456 MB/s
raid6: using algorithm int64x2 gen() 1971 MB/s
raid6: .... xor() 986 MB/s, rmw enabled
raid6: using intx1 recovery algorithm
Freescale Elo series DMA driver
SCSI subsystem initialized
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
pps_core: LinuxPPS API ver. 1 registered
pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
PTP clock support registered
EDAC MC: Ver: 3.0.0
Advanced Linux Sound Architecture Driver Initialized.
NET: Registered PF_ATMPVC protocol family
NET: Registered PF_ATMSVC protocol family
vgaarb: loaded
clocksource: Switched to clocksource timebase
VFS: Disk quotas dquot_6.6.0
VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
FS-Cache: Loaded
CacheFiles: Loaded
NET: Registered PF_INET protocol family
IP idents hash table entries: 16384 (order: 5, 131072 bytes, linear)
tcp_listen_portaddr_hash hash table entries: 512 (order: 1, 8192 bytes, linear)
Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
TCP established hash table entries: 8192 (order: 4, 65536 bytes, linear)
TCP bind hash table entries: 8192 (order: 5, 131072 bytes, linear)
TCP: Hash tables configured (established 8192 bind 8192)
UDP hash table entries: 512 (order: 2, 16384 bytes, linear)
UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear)
NET: Registered PF_UNIX/PF_LOCAL protocol family
RPC: Registered named UNIX socket transport module.
RPC: Registered udp transport module.
RPC: Registered tcp transport module.
RPC: Registered tcp NFSv4.1 backchannel transport module.
pci 0000:00:05.0: enabling device (0000 -> 0002)
PCI: CLS 0 bytes, default 64
Initialise system trusted keyrings
workingset: timestamp_bits=62 max_order=18 bucket_order=0
zbud: loaded
squashfs: version 4.0 (2009/01/31) Phillip Lougher
NFS: Registering the id_resolver key type
Key type id_resolver registered
Key type id_legacy registered
nfs4filelayout_init: NFSv4 File Layout Driver Registering...
nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
Key type cifs.idmap registered
ntfs: driver 2.1.32 [Flags: R/W].
ntfs3: Max link count 4000
ntfs3: Read-only LZX/Xpress compression included
jffs2: version 2.2. (NAND) (SUMMARY)  © 2001-2006 Red Hat, Inc.
fuse: init (API version 7.36)
SGI XFS with ACLs, security attributes, realtime, scrub, repair, quota, no debug enabled
9p: Installing v9fs 9p2000 file system support
NET: Registered PF_ALG protocol family
xor: measuring software checksum speed
   8regs           :  4770 MB/sec
   8regs_prefetch  :  3865 MB/sec
   32regs          :  4957 MB/sec
   32regs_prefetch :  3986 MB/sec
xor: using function: 32regs (4957 MB/sec)
Key type asymmetric registered
Asymmetric key parser 'x509' registered
Block layer SCSI generic (bsg) driver version 0.4 loaded (major 248)
io scheduler mq-deadline registered
io scheduler kyber registered
crc32: CRC_LE_BITS = 64, CRC_BE BITS = 64
crc32: self tests passed, processed 225944 bytes in 404840 nsec
crc32c: CRC_LE_BITS = 64
crc32c: self tests passed, processed 112972 bytes in 202780 nsec
crc32_combine: 8373 self tests passed
crc32c_combine: 8373 self tests passed
virtio-pci 0000:00:01.0: enabling device (0000 -> 0003)
virtio-pci 0000:00:02.0: enabling device (0000 -> 0002)
virtio-pci 0000:00:03.0: enabling device (0000 -> 0002)
virtio-pci 0000:00:04.0: enabling device (0000 -> 0002)
virtio-pci 0000:00:06.0: enabling device (0000 -> 0003)
virtio-pci 0000:00:07.0: enabling device (0000 -> 0003)
input: QEMU Virtio Mouse as /devices/platform/fe0008000.pci/pci0000:00/0000:00:03.0/virtio2/input/input0
input: QEMU Virtio Keyboard as /devices/platform/fe0008000.pci/pci0000:00/0000:00:04.0/virtio3/input/input1
Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
printk: console [ttyS0] disabled
serial8250.0: ttyS0 at MMIO 0xfe0004500 (irq = 42, base_baud = 25000000) is a 16550A
printk: console [ttyS0] enabled
printk: bootconsole [udbg0] disabled
ePAPR hypervisor byte channel driver
[drm] radeon kernel modesetting enabled.
[drm] pci: virtio-gpu-pci detected at 0000:00:02.0
[drm] features: -virgl +edid -resource_blob -host_visible
[drm] features: -context_init
[drm] number of scanouts: 1
[drm] number of cap sets: 0
[drm] Initialized virtio_gpu 0.1.0 0 for virtio1 on minor 0
BUG: Kernel NULL pointer dereference on read at 0x00000000
Faulting instruction address: 0xc0000000000c9934
BE PAGE_SIZE=4K SMP NR_CPUS=4 QEMU e500
Modules linked in:
CPU: 1 PID: 1 Comm: swapper/0 Not tainted 6.0.0-rc7_A-EON_X5000 #1
NIP:  c0000000000c9934 LR: c0000000000c9f58 CTR: 0000000000000000
REGS: c00000000208ab20 TRAP: 0300   Not tainted  (6.0.0-rc7_A-EON_X5000)
MSR:  0000000090029002 <CE,EE,ME>  CR: 84008242  XER: 00000000
DEAR: 0000000000000000 ESR: 0000000000000000 IRQMASK: 0
GPR00: c0000000006f0060 c00000000208adc0 c000000001ac3500 c0000000025f0010
GPR04: 0000000000000000 0000000000000000 0000000000000000 c0000000019908b0
GPR08: 0000000000000105 0000000000000000 0000000000000000 0000000000000180
GPR12: 0000000024008242 c00000003fff9500 c000000000001384 0000000000000000
GPR16: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
GPR20: 0000000000000000 0000000000000000 c00000000169021f c00000000208b088
GPR24: 0000000000000000 c000000002336800 0000000000000000 0000000000000000
GPR28: c000000002a48000 c000000002336800 0000000000000000 c0000000025f0010
NIP [c0000000000c9934] .dma_map_direct+0x8/0x10
LR [c0000000000c9f58] .dma_max_mapping_size+0x24/0x78
Call Trace:
[c00000000208adc0] [c00000000208ae80] 0xc00000000208ae80 (unreliable)
[c00000000208ae40] [c0000000006f0060] .drm_prime_pages_to_sg+0xa0/0xb8
[c00000000208aed0] [c00000000070f96c] .drm_gem_shmem_get_sg_table+0x28/0x3c
[c00000000208af40] [c000000000808c8c] .virtio_gpu_object_create+0x134/0x3a8
[c00000000208b010] [c000000000804c34] .virtio_gpu_mode_dumb_create+0xe4/0x15c
[c00000000208b110] [c0000000006ff7f4] .drm_mode_create_dumb+0xcc/0xec
[c00000000208b180] [c000000000707748] .drm_client_framebuffer_create+0x98/0x1f0
[c00000000208b260] [c00000000071fb6c] .drm_fb_helper_generic_probe+0x78/0x1a0
[c00000000208b320] [c00000000071ef08] .__drm_fb_helper_initial_config_and_unlock+0x428/0x54c
[c00000000208b410] [c00000000071f9dc] .drm_fbdev_client_hotplug+0xec/0x128
[c00000000208b4a0] [c00000000071fdec] .drm_fbdev_generic_setup+0x158/0x198
[c00000000208b530] [c000000000803dc4] .virtio_gpu_probe+0x1ac/0x1e0
[c00000000208b5f0] [c00000000069e11c] .virtio_dev_probe+0x2d0/0x3d4
[c00000000208b690] [c000000000815f34] .really_probe+0x1a0/0x344
[c00000000208b720] [c0000000008161c8] .__driver_probe_device+0xf0/0x100
[c00000000208b7b0] [c00000000081620c] .driver_probe_device+0x34/0xac
[c00000000208b840] [c000000000816774] .__driver_attach+0x124/0x134
[c00000000208b8d0] [c000000000813974] .bus_for_each_dev+0x8c/0xd0
[c00000000208b980] [c0000000008154a4] .driver_attach+0x24/0x38
[c00000000208b9f0] [c000000000814dd4] .bus_add_driver+0xd8/0x210
[c00000000208baa0] [c000000000816fd4] .driver_register+0xe0/0x134
[c00000000208bb20] [c00000000069d8a8] .register_virtio_driver+0x40/0x54
hrtimer: interrupt took 4631040 ns
[c00000000208bb90] [c000000001954444] .virtio_gpu_driver_init+0x18/0x2c
[c00000000208bc00] [c000000000001044] .do_one_initcall+0x7c/0x1c0
[c00000000208bce0] [c000000001925710] .kernel_init_freeable+0x23c/0x240
[c00000000208bd90] [c0000000000013ac] .kernel_init+0x28/0x14c
[c00000000208be10] [c0000000000005a0] .ret_from_kernel_thread+0x58/0x60
Instruction dump:
39200001 7c23f840 38210080 7d20485e 792307e0 48d551d8 7c9f2378 4bffffdc
792307e0 4e800020 e92301f8 7c852378 <e8890000> 4bffff7c 7c0802a6 28060003
---[ end trace 0000000000000000 ]---
Kernel panic - not syncing: Attempted to kill init! exitcode=0x0000000b
Rebooting in 180 seconds..
Link: Bug in the VirtIO GPU driver since the RC7 of kernel 6.0
I released the RC7 of kernel 6.0 for testing today.
Download: linux-image-6.0-rc7-X1000_X5000.tar.gz
Issue: There are some issues with KVM (HV + PR) if you use the kernels compiled with GCC 11.2.0 so I compiled the kernels with GCC 9.4.0 again.
Please also use them if you have other issues with the GCC 11.2.0 compiled kernels.
I will compile the final kernel 6.0 with GCC 9.4.0.
Downloads:
Kernel 6.0 RC7 up and running on my AmigaOne X5000
Big picture https://www.skateman.nl/wp-content/uplo ... -51-00.png
Skateman wrote: Thu Sep 29, 2022 7:55 pm Kernel 6.0 RC7 up and running on my AmigaOne X5000
I changed the GCC to version 9.4.0 because of the issues with KVM on Linux PPC today. (Cross compiling environment on Ubuntu 22.04.1)
  1. Code: Select all
    sudo apt install gcc-9-powerpc-linux-gnu
  2. Code: Select all
    sudo apt install g++-9-powerpc-linux-gnu
  3. Code: Select all
    sudo update-alternatives --install /usr/bin/powerpc-linux-gnu-gcc powerpc-linux-gnu-gcc /usr/bin/powerpc-linux-gnu-gcc-9 10
  4. Code: Select all
    sudo update-alternatives --install /usr/bin/powerpc-linux-gnu-g++ powerpc-linux-gnu-g++ /usr/bin/powerpc-linux-gnu-g++-9 10
Results:
christian@cc-build-machine:~/Kernels$ powerpc-linux-gnu-gcc --version
powerpc-linux-gnu-gcc (Ubuntu 9.4.0-5ubuntu1) 9.4.0
Copyright (C) 2019 Free Software Foundation, Inc.
This is free software; see the source for copying conditions.  There is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
christian@cc-build-machine:~/Kernels$ powerpc-linux-gnu-g++ --version
powerpc-linux-gnu-g++ (Ubuntu 9.4.0-5ubuntu1) 9.4.0
# Automatically generated file; DO NOT EDIT.
# Linux/powerpc 6.0.0-rc7 Kernel Configuration
CONFIG_CC_VERSION_TEXT="powerpc-linux-gnu-gcc (Ubuntu 9.4.0-5ubuntu1) 9.4.0"
