Linux PowerPC Server Software
Re: Linux PowerPC Server Software
Desktop firewall for Void PPC Linux:
/etc/rc.local:
# Default rc.local for void; add your custom commands here.
# This is run by runit in stage 2 before the services are executed
# (see /etc/runit/2).
iptables -t filter -A INPUT -m state --state ESTABLISHED,RELATED -j ACCEPT
iptables -t filter -A OUTPUT -m state --state NEW,ESTABLISHED,RELATED -j ACCEPT
iptables -t filter -A INPUT -i lo -j ACCEPT
iptables -P INPUT DROP
iptables -P OUTPUT DROP
iptables -P FORWARD DROP
freeIPA:
Integrated security information management solution combining Linux (Fedora), 389 Directory Server, MIT Kerberos, NTP, DNS, Dogtag certificate system, SSSD and others.
Image Image Image
freeIPA: ipa user-add:
freeIPA authentication on Void PPC:
freeIPA client installation in a docker container:
docker run --name freeipa-server2 --sysctl net.ipv6.conf.all.disable_ipv6=0 --hostname freeipa-server2.a-eon.tld --dns=192.168.178.21 -p 53:53/udp -p 53:53 -p 80:80 -p 443:443 -p 389:389 -p 636:636 -p 88:88 -p 464:464 -p 88:88/udp -p 464:464/udp -p 123:123/udp -v /Users/christian/freeipa-server-container-data:/data:Z freeipa/freeipa-server:centos-8
ipa-client-install --no-ntp --no-nis --domain=a-eon.tld --realm=A-EON.TLD
ipa-replica-install --setup-ca --setup-dns --no-forwarders
SSH login via IPA user:
Manual network interface configuration on Fedora PPC64:
vi /etc/sysconfig/network-scripts/ifcfg-<network interface>
For example: vi /etc/sysconfig/network-scripts/ifcfg-ens33
DEVICE=ens33
BOOTPROTO=none
ONBOOT=yes
PREFIX=24
IPADDR=192.168.178.102
GATEWAY=192.168.178.1
DNS1=192.168.178.21
DNS2=192.168.178.1
If you want to disable ipv6 then add the following line to "/etc/sysctl.conf".
net.ipv6.conf.ens33.disable_ipv6 = 1
freeIPA replication:
freeIPA replication part2:
freeIPA client installation in a Rocky Linux docker container:
  1. Create a container from the Rocky Linux image (deploy):
    docker run -it --name freeipa-server-rocky2 --sysctl net.ipv6.conf.all.disable_ipv6=0 --hostname freeipa-server-rocky2.a-eon.tld --dns=192.168.178.21 -p 53:53/udp -p 53:53 -p 80:80 -p 443:443 -p 389:389 -p 636:636 -p 88:88 -p 464:464 -p 88:88/udp -p 464:464/udp -p 123:123/udp -v /Users/christian/freeipa-server-container-data:/data:Z -d rockylinux/rockylinux
  2. Access to the container:
    docker exec -it --user root freeipa-server-rocky2 /bin/bash
  3. Code: Select all
    dnf module info idm:DL1
  4. Code: Select all
    yum module enable idm:DL1
  5. Code: Select all
    yum distro-sync
  6. Code: Select all
    yum module install idm:DL1/client
  7. Code: Select all
Stop the container: docker ps -a and docker stop ID (For example: docker stop 4333350fd351)
Start the container again:
  1. Code: Select all
    docker start 4333350fd351
  2. Code: Select all
