Fienix - New PowerPC Distro
Tijatjj
Post by Tijatjj »
Hi, trying to install the dvd package and here’s the printout?dont know what is going wrong or how to finish install thanks,also how do you install something from repository and run it
caseycullen
Post by caseycullen »
Thanks I'll look into it.
-Casey
xeno74 wrote:Hi Casey,
FYI:
musa wrote:Hi Christian
Gramps has been added to the Fienix software repository.
When install gramp I got a error on loading the osmgps modules.
I try to install the missing dependencies I got this.
Everything else in Gramp works as far as I can see.
Tijatjj wrote:Hi, trying to install the dvd package and here’s the printout?dont know what is going wrong or how to finish install thanks,also how do you install something from repository and run it
It looks good so far. Could you please test a DVD with the VLC? If you want to install something from the repository then use Synaptic. (Click on Menu, Administration, Synaptic)
Tijatjj
Post by Tijatjj »
Ok starts this play but screen jumps to different sizes.its a Radeon sff7750 .i have a r7 240 if that would be better thank you you’ve
Tijatjj wrote:Ok starts this play but screen jumps to different sizes.its a Radeon sff7750 .i have a r7 240 if that would be better thank you you’ve
Hi Tijatjj,
Unfortunately you can’t use hardware acceleration with your graphics card. You need a Radeon HD 6xxx or lower.
Tijatjj
Post by Tijatjj »
Thank you,any particular chipset to look for.is that what is hanging up the dvd playing . I am guessing there’s no way to shutdown the hardware acceleration.
caseycullen wrote:It looks like several people on several OSes have experienced this issue. Several people have been able to resolve the issue by doing the following:
1) Start LibreOffice
2)
The five steps listed here had no obvious effect, but the second of the next batch was very revealing.
If this does not work, please advise of the following:
1) The manufacturer of your printer
2) The output when you enter "lpstat -t" in MATE Terminal
fienix@Fienix:~$ lpstat -t
scheduler is running
no system default destination
device for HP_Fax_4_raspberrypi: ///dev/null
device for HP_HP_OfficeJet_Pro_8710_raspberrypi: ///dev/null
device for HP_OfficeJet_Pro_8710_01DACB_: ipps://HPEC8EB501DACB.local:443/ipp/print
HP_Fax_4_raspberrypi not accepting requests since Mon 06 May 2019 09:02:50 AM PDT -
	reason unknown
HP_HP_OfficeJet_Pro_8710_raspberrypi not accepting requests since Mon 06 May 2019 09:02:45 AM PDT -
	reason unknown
HP_OfficeJet_Pro_8710_01DACB_ accepting requests since Sun 12 May 2019 01:57:17 PM PDT
printer HP_Fax_4_raspberrypi disabled since Mon 06 May 2019 09:02:50 AM PDT -
	reason unknown
printer HP_HP_OfficeJet_Pro_8710_raspberrypi disabled since Mon 06 May 2019 09:02:45 AM PDT -
	reason unknown
printer HP_OfficeJet_Pro_8710_01DACB_ is idle.  enabled since Sun 12 May 2019 01:57:17 PM PDT
For reasons that I don't recall, I found it necessary to connect my printer through my Raspberry Pi. When I click a "Print" I normally get "HP_OfficeJet_Pro_8710" and "HP_OfficeJet_Pro_8710_raspberrypi" in the PRINT window, and I habitually choose the latter. When I try to print from LibreOffice today, that is marked "Paused; Rejecting Jobs." But the other one has "raspberrypi" under Location, and if I choose that, it prints fine. "HP_OfficeJet_Pro_8710_01DACB" is also listed, with an ink low warning, and it too prints. Weird, but problem solved.
Just in case there might be a clue to the weirdness, here is what came up for uname and lsusb:
fienix@Fienix:~$ uname -a
Linux Fienix 5.1.0_A-EON_X5000 #1 SMP Mon May 6 11:04:35 CEST 2019 ppc64 GNU/Linux
fienix@Fienix:~$ lsusb
Bus 002 Device 004: ID 0781:556c SanDisk Corp. Ultra
Bus 002 Device 003: ID 0d8c:013c C-Media Electronics, Inc. CM108 Audio Controller
Bus 002 Device 002: ID 0424:2514 Standard Microsystems Corp. USB 2.0 Hub
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 001 Device 006: ID 0a12:0001 Cambridge Silicon Radio, Ltd Bluetooth Dongle (HCI mode)
Bus 001 Device 005: ID 0781:5530 SanDisk Corp. Cruzer
Bus 001 Device 004: ID 056e:00fb Elecom Co., Ltd
Bus 001 Device 003: ID 046d:c52b Logitech, Inc. Unifying Receiver
Bus 001 Device 002: ID 0424:2514 Standard Microsystems Corp. USB 2.0 Hub
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Tijatjj
Post by Tijatjj »
Hi , fienix file system for usb 64 gig would be fat32 or ext 4.also for 1 terabyte HD’s thanks
Tijatjj wrote:Hi , fienix file system for usb 64 gig would be fat32 or ext 4.also for 1 terabyte HD’s thanks
Please use ext4 for the Fienix root file system.
Hi Casey,
Musa can‘t upgrade Arctic Fox to the version 27.9.17.
Link to the thread
