Arctic Fox
Roland wrote: Sun Oct 23, 2022 12:38 pm
xeno74 wrote: Sun Oct 23, 2022 12:23 pm Your MintPPC distribution is too old. The Void package of PM needs a Linux distribution with glibc 2.32 and higher. Please update your MintPPC. Both packages work on my MintPPC.
In what package is the glibc 2.3x included? Does it have effect on VLC? I won't do anymore full updates with MintPPC as they broke the functionality of VLC!
Glibc packages: http://ftp.ports.debian.org/debian-ports/pool-powerpc/main/g/glibc/
Please try # apt install libc6.
xeno74 wrote: Sun Oct 23, 2022 1:19 pm Please try # apt install libc6.
Thanks - that worked!
I compiled Arctic Fox 40.0 for Linux PPC64 and then I successfully tested it on Debian PPC64 Bookworm/Sid.
Download: arcticfox-40.0.linux-powerpc64.tar.bz2
For Linux PPC 32-bit (Ubuntu 10.04 and higher): arcticfox-40.0.linux-powerpc.tar.bz2
Screenshot of Arctic Fox 40.0 on Debian PPC64 Bookworm/Sid:
I compiled Arctic Fox 40.0 for Linux PPC64 with AltiVec support and then I successfully tested it on Debian PPC64 Bookworm/Sid.
Download: arcticfox-40.0.linux-powerpc64-altivec.tar.bz2
For Linux PPC 32-bit without AltiVec (Ubuntu 10.04 and higher): arcticfox-40.0.linux-powerpc.tar.bz2
Screenshot of Arctic Fox 40.0 with AltiVec support on Debian PPC64 Bookworm/Sid:
Arctic Fox 40.1 has been released.
New: github.com
Download source code: v40.1.tar.gz
I compiled a non-altivec 32-bit version for Ubuntu 10.04 and higher. It also works on Void PPC, MintPPC (Debian Sid), Fienix etc.
Download: arcticfox-40.1.linux-powerpc.tar.bz2
Running the latest version of Arctic Fox 40.1 on my AmigaOne X5000
Big picture: https://www.skateman.nl/wp-content/uplo ... -45-37.png
Skateman wrote: Mon Jan 02, 2023 9:50 am Running the latest version of Arctic Fox 40.1 on my AmigaOne X5000
Mario Locati wrote: Hi Christian! Happy new year! I noticed that you compiled the new version of arcticfox 40.1, I have prepared a miniguide on how to generate the deb file starting from the tar.gz that is created using "mach package", http://repo.powerprogress.org/temp/arct ... b_file.txt
how_to_generate_arcticfox_deb_file.txt:
get the template folder
> wget http://repo.powerprogress.org/temp/arcticfox/_arcticfox-template.zip
unzip the template folder
> unzip _arcticfox-template.zip
copy the template folder into a new folder that will be used to generate the deb file
> cp -R _arcticfox-template arcticfox-40.0
customize the control file (version, architecture, installed-size, maintener, description)
> nano arcticfox-40.0/DEBIAN/control
extract the content of the tar.gz into the folder "usr/share/arcticfox" so that the arcticfox main executable is placed in this folder
enter the parent folder containg the folder "arcticfox-40.0" and generate the deb file
> dpkg-deb --build arcticfox-40.0
rename the deb file using the following naming scheme
> ren arcticfox-40.0.deb arcticfox-40.0.linux-ppc64-with-altivec.deb
> ren arcticfox-40.0.deb arcticfox-40.0.linux-ppc64-no-altivec.deb
> ren arcticfox-40.0.deb arcticfox-40.0.linux-powerpc-with-altivec.deb
> ren arcticfox-40.0.deb arcticfox-40.0.linux-powerpc-no-altivec.deb
caseycullen
Post by caseycullen »
I'm having issues with the status bar. It never appears. For example, when hovering over a link the status bar usually appears at the bottom of the browser window to show the link address, but it does not any longer. Additionally, the download indicator does not appear when downloading anything. Is anyone else experiencing these issues with the new Arctic Fox version? I tried to play around with the Status bar preferences, but it does not seem to have any effect.
-Casey
