Skateman wrote: Mon May 30, 2022 8:26 am Kernel 5.19 Alpha2 up and running on my AmigaOne X5000
Fantastic, that it works with two graphics cards on your X5000. I was a little bit worried because of the updates in the latest 2 alphas but everything is fine. Thanks a lot for testing! :-)
Have a nice week!
The keyboard and mouse issue still exists in the latest git kernel.
Darren wrote: Hi Christian,
Can you send me the full dmesg output from this failed boot? I looked but can't seem to find which component is at fault here
Darren
Rob wrote: Do you have a dmesg log?
The other way to fix is creating a IRQ resource and adding it to the
child device resources.
Rob
Logs:
dmesg_FSL_P5040_Void_PPC.txt
dmesg_FSL_P5040_MintPPC.txt
dmesg_FSL_P5040_Void_PPC_with_Robs_patch.txt
Kernel 5.19 Alpha3 up and running on my AmigaOne X5000
Big picture https://www.skateman.nl/wp-content/uplo ... -30-28.jpg
Skateman wrote: Mon Jun 06, 2022 9:33 pm Kernel 5.19 Alpha3 up and running on my AmigaOne X5000
Kerrnel 5.19 RC1 up and running on my AmigaOne X5000. Also running the latest version of Arctic Fox 39.2
Thanks a lot Christian!
Big picture: https://www.skateman.nl/wp-content/uplo ... -35-03.png
Skateman wrote: Sun Jun 12, 2022 4:41 pm Kerrnel 5.19 RC1 up and running on my AmigaOne X5000. Also running the latest version of Arctic Fox 39.2
The keyboard and mouse issue still exists. We still need our of.patch.
We tried a new patch but without any success.
--- a/drivers/usb/host/fsl-mph-dr-of.c  2022-06-06 02:18:54.000000000 +0200
+++ b/drivers/usb/host/fsl-mph-dr-of.c  2022-06-09 19:31:50.135472793 +0200
@@ -80,8 +80,6 @@ static struct platform_device *fsl_usb2_
                                         const char *name, int id)
         struct platform_device *pdev;
-       const struct resource *res = ofdev->resource;
-       unsigned int num = ofdev->num_resources;
         int retval;
         pdev = platform_device_alloc(name, id);
@@ -105,12 +103,8 @@ static struct platform_device *fsl_usb2_
         retval = platform_device_add_data(pdev, pdata, sizeof(*pdata));
         if (retval)
                 goto error;
-       if (num) {
-               retval = platform_device_add_resources(pdev, res, num);
-               if (retval)
-                       goto error;
+        pdev->dev.of_node = ofdev->dev.of_node;
+        pdev->dev.of_node_reused = true;
         retval = platform_device_add(pdev);
         if (retval)
Link to the thread: [FSL P50x0] Keyboard and mouse don't work anymore after the devicetree updates for 5.19
