Arctic Fox
xeno74 wrote: Mon Oct 17, 2022 6:59 pm
Wicknix wrote: Hey -
I was able to fix PM 31.2 for ppc64. However i no longer have my old ubuntu 12 dev environment to attempt 32bit builds for debian/ubuntu compatible systems.
If you'd like to give it a shot the source is here:
pale-moon-31-ppc-fix.tar.bz2
Wicknix wrote: PM build instructions here: https://developer.palemoon.org/build/linux/
Don't worry about the git section. I already have the submodules and everything in place.
However after it builds, you'll need to swap the LE/BE icu.dat files around again after packaging. I included one in the archive.
ubuntu MATE 16.04.7: ERROR: Only GCC 7.1 or newer is supported (found version 5.4.0)
MintPPC: OK, compiling works but linking not.
It linked 40 minutes and after that I got the following error message again and again:
error: relocation overflow
I tried it again with GCC9 but linking doesn’t work either. (error: relocation overflow)
Maybe cross compiling is a solution: .mozconfig
Oh dear, I have it. It was really strenuous and time-consuming ....
Pale Moon 31.2.0 works on Linux PPC (32-bit)! :-)
The gold linker was the problem. I had to change to the bfd version of ld with deleting the symbolic link /usr/bin/ld.gold.
Then there was an issue with a header file. I have to edit the file /home/mintppc/Downloads/pale_moon_src/pale-moon/platform/extensions/spellcheck/src/mozSpellChecker.h
- #include "RemoteSpellCheckEngineChild.h"
+ #include "/home/mintppc/Downloads/pale_moon_src/pale-moon/obj-powerpc-linux-gnu/dist/include/mozilla/RemoteSpellCheckEngineChild.h"
Additionally I had to use the following LDFLAGS:
export LDFLAGS="-Wl,--no-keep-memory -Wl,--no-map-whole-files -Wl,--reduce-memory-overheads"
And not to forget to copy the icudt58b.dat to pale-moon/obj-powerpc-linux-gnu/dist/bin before "mach run" and "mach package" and then extract the xz package and copy the icudt58b.dat again to the palemoon folder.
Download (not tested): palemoon-31.2.0.linux-powerpc-gtk2.tar.gz
xeno74 wrote: Sat Oct 22, 2022 12:09 pm Download (not tested): palemoon-31.2.0.linux-powerpc-gtk2.tar.gz
It only works on new MintPPC and Debian Sid distributions. It doesn't work on Void PPC and Fienix so I compiled Pale Moon 31.2.0 on Void PPC.
I had to add -latomic to the LDFLAGS and deactivated ac_add_options --with-pthreads in the .mozconfig.
export LDFLAGS="-Wl,--no-keep-memory -Wl,--no-map-whole-files -Wl,--reduce-memory-overheads -latomic"
.mozconfig:
export CC="gcc -m32"
export CXX="g++ -m32"
mk_add_options PYTHON=/usr/bin/python2
mk_add_options AUTOCONF=/usr/bin/autoconf-2.13
# Set GTK Version to 2 or 3
_GTK_VERSION=2
# Standard build options for Pale Moon
ac_add_options --enable-application=palemoon
ac_add_options --enable-default-toolkit=cairo-gtk$_GTK_VERSION
ac_add_options --enable-strip
#ac_add_options --enable-devtools
#ac_add_options --enable-av1
ac_add_options --disable-eme
ac_add_options --disable-gconf
#ac_add_options --with-pthreads
#ac_add_options --with-system-icu
#ac_add_options --with-system-nspr
#ac_add_options --with-system-nss
ac_add_options --enable-system-ffi
ac_add_options --target=powerpc-linux-gnu
ac_add_options --host=powerpc-linux-gnu
# Please see https://www.palemoon.org/redist.shtml for restrictions when using the official branding.
#ac_add_options --enable-official-branding
#export MOZILLA_OFFICIAL=1
# Processor architecture specific build options
if [ -n "$_BUILD_64" ]; then
  ac_add_options --x-libraries=/usr/lib64
else
fi
export MOZ_PKG_SPECIAL=gtk$_GTK_VERSION
This version was compiled with GCC 10.2.1 on Void PPC.
Download (not tested): palemoon-31.2.0.linux-powerpc-gtk2.void.tar.gz
xeno74 wrote: Sun Oct 23, 2022 12:11 am Download (not tested): [url=http://www.xenosoft.de/palemoon-31.2.0. ... oid.tar.gz]palemoon-31.2.0.linux-powerpc
I cannot get either of these palemoon-31 versions running... Only a text editor is opened if I double click the "palemoon" or "palemoon.bin" icon!
Roland wrote: Sun Oct 23, 2022 10:29 am
Please try ./palemoon in a terminal.
xeno74 wrote: Sun Oct 23, 2022 11:34 am [Please try ./palemoon in a terminal.
I got these errors when tried (with MintPPC) the first version:
$ ./palemoon
./palemoon: /lib/powerpc-linux-gnu/libc.so.6: version `GLIBC_2.33' not found (required by ./palemoon)
./palemoon: /lib/powerpc-linux-gnu/libc.so.6: version `GLIBC_2.34' not found (required by ./palemoon)
And this when I tried the 'void' version:
$ ./palemoon
XPCOMGlueLoad error for file /media/Linux/palemoon/libxul.so:
/lib/powerpc-linux-gnu/libc.so.6: version `GLIBC_2.32' not found (required by /media/Linux/palemoon/libxul.so)
Roland wrote: Sun Oct 23, 2022 12:18 pm
$ ./palemoon
$ ./palemoon
Your MintPPC distribution is too old. The Void package of PM needs a Linux distribution with glibc 2.32 and higher. Please update your MintPPC. Both packages work on my MintPPC.
xeno74 wrote: Sun Oct 23, 2022 12:23 pm Your MintPPC distribution is too old. The Void package of PM needs a Linux distribution with glibc 2.32 and higher. Please update your MintPPC. Both packages work on my MintPPC.
In what package is the glibc 2.3x included? Does it have effect on VLC? I won't do anymore full updates with MintPPC as they broke the functionality of VLC!
