Void Linux
Re: Void Linux
Desktop firewall for Void PPC Linux:
/etc/rc.local:
# Default rc.local for void; add your custom commands here.
# This is run by runit in stage 2 before the services are executed
# (see /etc/runit/2).
iptables -t filter -A INPUT -m state --state ESTABLISHED,RELATED -j ACCEPT
iptables -t filter -A OUTPUT -m state --state NEW,ESTABLISHED,RELATED -j ACCEPT
iptables -t filter -A INPUT -i lo -j ACCEPT
iptables -P INPUT DROP
iptables -P OUTPUT DROP
iptables -P FORWARD DROP
gerograph
Re: Void Linux
Post by gerograph »
IMPORTANT: Please connect the USB stick after you have reached the CFE with the f key.
  1. Code: Select all
    CFE> setenv bootargs "root=LABEL=void rootdelay=5"
  2. Code: Select all
    CFE> ramdisk -z -addr=0x24000000 -fatfs usbdisk0:initrd-5.10.img
  3. Code: Select all
    CFE> boot -elf -noints -fatfs usbdisk0:vmlinux-5.15
You can log into this system as amigaone with the password "amigaone".
Installation
You can install Void with the installer (Desktop link) or image the ext4 root partition on the USB stick to a partition on your hard disk with "dd".
For example:
dd if=/dev/sdd2 of=/dev/sdb6 && e2fsck -f /dev/sdb6 && resize2fs /dev/sdb6 && tune2fs -L void /dev/sdb6
how can I use the terminal as Admin/su? If I type su in the terminal an put "amigaone" ass password, I'll get "Authentication failure"?
Re: Void Linux
gerograph wrote: Sat Nov 20, 2021 4:09 pm how can I use the terminal as Admin/su? If I type su in the terminal an put "amigaone" ass password, I'll get "Authentication failure"?
Hi Gerograph,
Please try “sudo su“.
gerograph
Re: Void Linux
Post by gerograph »
Works, thanks!
Next question: I setup void and can boot using either Kernel 5.15 or 5.15.1....as long as I just have one graphic card.
BUT as soon as I put in the second graphic card, I get this:
cfe via one card, Linux output will then be displayed on the other one. BUT just before the login screen should Show up. I will get a Black screen with a flashing cursor....
Anybody an Idea?
Re: Void Linux
gerograph wrote: Sat Nov 20, 2021 11:24 pm BUT as soon as I put in the second graphic card, I get this:
Anybody an Idea?
Please boot with the graphics card you want to use with Void. After that execute lspci and look for the hardware address (BusID) of the graphics card. Then create an xorg.conf with the correct hardware address.
For example for the Radeon FireMV 2250:
Section "Device"
            Identifier "ATI RV516 GL [FireMV 2250]"
            BusID   "PCI:05:00.1"
            Driver "radeon"
EndSection
gerograph
Re: Void Linux
Post by gerograph »
O.k. this doesn't help. I just put my Radeon HD 4650 into my X1000. Booted up sucessfully and pasted the lines above into a textfile an altered it accordingly. See screenshot:
After shutting down, and rebooting - I became a black screen with a flashing cursor once again... I also tried to add my other graphic card (just in case...) but no success either? I had to remove the second card again, boot with an USB Stick and remove xorg.conf from etc/x11. This enabled me at least to boot normaly into void from SSD again... as long as I have only one graphic card installed
Re: Void Linux
With which Void img, did you install Void on the SSD?
gerograph
Re: Void Linux
Post by gerograph »
The one you mentioned above...
viewtopic.php?p=54209#p54209
I tried with the included kernel 5.15 and 5.15.1
viewtopic.php?p=54379#p54379
For installing void, I used the installer...
Re: Void Linux
Maybe Julian's xorg.conf helps you to figure out the correct configuration in your xorg.conf.
I don't use two graphics cards in my AmigaOnes so it is difficult for me to help you.
