No Ethernet with... Sound Blaster card ?
Re: No Ethernet with... Sound Blaster card ?
Could you please post the output of "dmesg | grep -i ca0132"? I want to make sure, that we are really talking about the right sound card. OK, I have seen, that you have no output of this command. Maybe "dmesg | grep -i realtek" displays something.
Amiguy
Post by Amiguy »
There are no results under root for these commands.
What about "dmesg | grep -i realtek"?
Amiguy
Post by Amiguy »
Same, no result
Amiguy
Post by Amiguy »
When I run the lsmod command again, I now have new results :
Module                  Size  Used by
snd_hda_codec_realtek   128287  0
snd_hda_codec_generic    80306  1 snd_hda_codec_realtek
ledtrig_audio           2730  1 snd_hda_codec_generic
snd_hda_codec_ca0132    82410  0
uio_pdrv_genirq         7243  0
uio                    19689  1 uio_pdrv_genirq
Amiguy wrote: Sat Jul 24, 2021 8:02 pm When I run the lsmod command again, I now have new results :
Module Size Used by
Great! Please post the output of cat /proc/asound/cards again.
Amiguy
Post by Amiguy »
Excuse me, I was unable to continue my investigations yesterday night.
Getting back to my X5000 this morning, I see that the lsmod command no longer generates the lines from yesterday night. This means in my opinion that the sound card is recognized only on a one-off and momentary basis :
Module                  Size  Used by
And of course the cards file doesn't change since I haven't changed anything :
0 [VirMIDI        ]: VirMIDI - VirMIDI
                      Virtual MIDI Card 1
 1 [HDMI           ]: HDA-Intel - HDA ATI HDMI
                      HDA ATI HDMI at 0xc10040000 irq 43
Besides, I did not intervene on any file whatsoever to display the new lines of the lsmod command. I don't know what could have changed the appearance of the lsmod lines. I restarted the X5000 several times by switching back to Fienix, then switching back to the Amiga (which makes the sound card work well), then again switching back to Fienix. I can't go back over the result of last night's lsmod.
When I run the command dmes | grep -i snd, I get the following output:
[    5.680529] snd_hda_intel 0000:01:00.1: Force to snoop mode by module option
[    5.685643] snd_hda_intel 1000:05:00.0: Disabling MSI
[    5.690577] snd_hda_intel 1000:05:00.0: Force to snoop mode by module option
[    5.696445] usbcore: registered new interface driver snd-usb-audio
[    5.701643] usbcore: registered new interface driver snd-ua101
[    5.706818] usbcore: registered new interface driver snd-usb-usx2y
[   15.059852] snd_hda_intel 0000:01:00.1: IRQ timing workaround is activated for card #1. Suggest a bigger bdl_pos_adj.
Is there possibly something in this thread which could help to solve this problem:
https://www.linuxquestions.org/question ... 175505881/
Amiguy
Post by Amiguy »
Thank you Roland for your link. The solution of recompiling alsa-firmware seems interesting (post from nortin), but we already have a higher version (v1.2.2-1) which is the latest available.
The comment from bolt.0 is also interesting. I don't have any of the configuration files described in the post. But when I display the /etc/pulse/daemon.conf file, it is filled in and all the lines are commented out (;). Maybe setting this file would help make the card work :
# This file is part of PulseAudio.
# PulseAudio is free software; you can redistribute it and/or modify
# it under the terms of the GNU Lesser General Public License as published by
# the Free Software Foundation; either version 2 of the License, or
# (at your option) any later version.
# PulseAudio is distributed in the hope that it will be useful, but
# WITHOUT ANY WARRANTY; without even the implied warranty of
# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
# General Public License for more details.
# You should have received a copy of the GNU Lesser General Public License
# along with PulseAudio; if not, see <http://www.gnu.org/licenses/>.
## Configuration file for the PulseAudio daemon. See pulse-daemon.conf(5) for
## more information. Default values are commented out.  Use either ; or # for
## commenting.
; daemonize = no
; fail = yes
; allow-module-loading = yes
; allow-exit = yes
; use-pid-file = yes
; system-instance = no
; local-server-type = user
; enable-shm = yes
; enable-memfd = yes
; shm-size-bytes = 0 # setting this 0 will use the system-default, usually 64 MiB
; lock-memory = no
; cpu-limit = no
; high-priority = yes
; nice-level = -11
; realtime-scheduling = yes
; realtime-priority = 5
; exit-idle-time = 20
; scache-idle-time = 20
; dl-search-path = (depends on architecture)
; load-default-script-file = yes
; default-script-file = /etc/pulse/default.pa
; log-target = auto
; log-level = notice
; log-meta = no
; log-time = no
; log-backtrace = 0
; resample-method = speex-float-1
; avoid-resampling = false
; enable-remixing = yes
; remixing-use-all-sink-channels = yes
; enable-lfe-remixing = no
; lfe-crossover-freq = 0
; flat-volumes = no
; rlimit-fsize = -1
; rlimit-data = -1
; rlimit-stack = -1
; rlimit-core = -1
; rlimit-as = -1
; rlimit-rss = -1
; rlimit-nproc = -1
; rlimit-nofile = 256
; rlimit-memlock = -1
; rlimit-locks = -1
; rlimit-sigpending = -1
; rlimit-msgqueue = -1
; rlimit-nice = 31
; rlimit-rtprio = 9
; rlimit-rttime = 200000
; default-sample-format = s16le
; default-sample-rate = 44100
; alternate-sample-rate = 48000
; default-sample-channels = 2
; default-channel-map = front-left,front-right
; default-fragments = 4
; default-fragment-size-msec = 25
; enable-deferred-volume = yes
; deferred-volume-safety-margin-usec = 8000
; deferred-volume-extra-delay-usec = 0
Then, the post of janKdebian looks very promising to me. I do have an /etc/initramfs-tools/modules file, but what exactly should I enter there? "Realtek"?
Amiguy
Post by Amiguy »
When I run the lspci -v command, I get the sound card details. It is well identified as a Sound Blaster Audigy Fx subsystem of a Recon3D type device:
1000:05:00.0 Audio device: Creative Labs Sound Core3D [Sound Blaster Recon3D / Z-Series] (rev 01)
	Subsystem: Creative Labs SB1570 SB Audigy Fx
	Flags: fast devsel, IRQ 19
	Memory at c20100000 (64-bit, non-prefetchable) [size=16K]
	Memory at c20104000 (64-bit, non-prefetchable) [size=16K]
	Capabilities: <access denied>
	Kernel driver in use: snd_hda_intel
