Kernel 5.12
Re: Kernel 5.12
I released the alpha6 of kernel 5.12 for the X1000 and X5000 today.
There are compiling issues but with reverting the bad commit, the kernels compile without any problems. Further information: Latest Git kernel doesn't compile because of the LINUX_VERSION_CODE issue
Download: linux-image-5.12-alpha6-X1000_X5000.tar.gz
In addition, a nice background image for your desktop:
Re: Kernel 5.12
Hi christian
I testet Debian 10 ppc with kernel 5.12_a6
Workning fine.
Have a nice day
Re: Kernel 5.12
musa wrote: Fri Feb 26, 2021 6:26 pm Hi christian
Workning fine.
Have a nice day
Fantastic! :-) Thank you for testing! :-)
Re: Kernel 5.12
The alpha7 of kernel 5.12 has been released for testing.
Download: linux-image-5.12-alpha7-X1000_X5000.tar.gz
Re: Kernel 5.12
Masahiro Yamada has created a patch because of the compiling issue. If you don't have set the values of the variables SUBLEVEL and PATCHLEVEL in the file "a/Makefile" in the latest Git kernels then the compiling fails. This patch solves this issue.
Commit 9b82f13e7ef3 ("kbuild: clamp SUBLEVEL to 255") breaks the build
if SUBLEVEL or PATCHLEVEL is empty.
Commit 78d3bb4483ba ("kbuild: Fix <linux/version.h> for empty SUBLEVEL
or PATCHLEVEL") fixed the issue by prepending a zero.
This time, we cannot take the same approach because we have C code:
  #define LINUX_VERSION_PATCHLEVEL $(PATCHLEVEL)
  #define LINUX_VERSION_SUBLEVEL $(SUBLEVEL)
Replace empty SUBLEVEL or PATCHLEVEL with a zero.
Fixes: 9b82f13e7ef3 ("kbuild: clamp SUBLEVEL to 255")
Signed-off-by: Masahiro Yamada <masahiroy@kernel.org>
 Makefile | 6 ++++--
 1 file changed, 4 insertions(+), 2 deletions(-)
diff --git a/Makefile b/Makefile
index f2dc2f953e23..14c13b09a9e7 100644
--- a/Makefile
+++ b/Makefile
@@ -1283,10 +1283,10 @@ endef
 define filechk_version.h
 	if [ $(SUBLEVEL) -gt 255 ]; then                                 \
 		echo \#define LINUX_VERSION_CODE $(shell                 \
-		expr $(VERSION) \* 65536 + 0$(PATCHLEVEL) \* 256 + 255); \
+		expr $(VERSION) \* 65536 + $(PATCHLEVEL) \* 256 + 255); \
 	else                                                             \
-		expr $(VERSION) \* 65536 + 0$(PATCHLEVEL) \* 256 + $(SUBLEVEL)); \
+		expr $(VERSION) \* 65536 + $(PATCHLEVEL) \* 256 + $(SUBLEVEL)); \
 	fi;                                                              \
 	echo '#define KERNEL_VERSION(a,b,c) (((a) << 16) + ((b) << 8) +  \
 	((c) > 255 ? 255 : (c)))';                                       \
@@ -1295,6 +1295,8 @@ define filechk_version.h
 	echo \#define LINUX_VERSION_SUBLEVEL $(SUBLEVEL)
 endef
+$(version_h): PATCHLEVEL := $(if $(PATCHLEVEL), $(PATCHLEVEL), 0)
+$(version_h): SUBLEVEL := $(if $(SUBLEVEL), $(SUBLEVEL), 0)
 $(version_h): FORCE
 	$(call filechk,version.h)
2.27.0
Re: Kernel 5.12
Hi
Testing kernel 5.12 a7 on Debian/mint 32 . Using FS-UAE
Have a nice day
Re: Kernel 5.12
musa wrote: Sun Feb 28, 2021 12:05 pm Hi
Have a nice day
Hi Musa,
Many thanks for testing the alpha7. You helps me a lot. :-) Thank you for this.
Have a nice day too,
daz
Re: Kernel 5.12
Post by daz »
xeno74 wrote: Fri Feb 26, 2021 3:33 pm Hi All,
Christian,
Please apply the following to your X1000 build and test. I've booted a next kernel with this applied, but my X1000 linux is a little broken at the moment so I can't fully test.
diff --git a/arch/powerpc/platforms/pasemi/pci.c b/arch/powerpc/platforms/pasemi/pci.c
index 8779b10..e6ce4f6 100644
--- a/arch/powerpc/platforms/pasemi/pci.c
+++ b/arch/powerpc/platforms/pasemi/pci.c
@@ -24,6 +24,8 @@
 #define PA_PXP_CFA(bus, devfn, off) (((bus) << 20) | ((devfn) << 12) | (off))
+extern void nemo_init_IRQ(void);
 static inline int pa_pxp_offset_valid(u8 bus, u8 devfn, int offset)
 	/* Device 0 Function 0 is special: It's config space spans function 1 as
@@ -264,6 +266,11 @@ static int __init pas_add_bridge(struct device_node *dev)
 	isa_bridge_find_early(hose);
+	 * ISA brigde is now active, add the i8259 cascade (if needed)
+	nemo_init_IRQ();
 	return 0;
diff --git a/arch/powerpc/platforms/pasemi/setup.c b/arch/powerpc/platforms/pasemi/setup.c
index 376797e..0363853 100644
--- a/arch/powerpc/platforms/pasemi/setup.c
+++ b/arch/powerpc/platforms/pasemi/setup.c
@@ -212,10 +212,12 @@ static void sb600_8259_cascade(struct irq_desc *desc)
 	chip->irq_eoi(&desc->irq_data);
-static void nemo_init_IRQ(struct mpic *mpic)
+void nemo_init_IRQ(void)
 	struct device_node *np;
 	int gpio_virq;
+	struct mpic *mpic;
 	/* Connect the SB600's legacy i8259 controller */
 	np = of_find_node_by_path("/pxp@0,e0000000");
 	i8259_init(np, 0);
@@ -226,6 +228,7 @@ static void nemo_init_IRQ(struct mpic *mpic)
 	irq_set_chained_handler(gpio_virq, sb600_8259_cascade);
 	mpic_unmask_irq(irq_get_irq_data(gpio_virq));
+	mpic = irq_get_chip_data(gpio_virq);
 	irq_set_default_host(mpic->irqhost);
@@ -296,8 +299,6 @@ static __init void pas_init_IRQ(void)
 		mpic_unmask_irq(irq_get_irq_data(nmi_virq));
-	nemo_init_IRQ(mpic);
 	of_node_put(mpic_node);
 	of_node_put(root);
If is OK will submit later this week/next week.
Regards
Darren
Re: Kernel 5.12
daz wrote: Sun Feb 28, 2021 10:58 pm Christian,
Regards
Darren
Hi Darren,
Many thanks for your patch! We will test it.
The Linux 5.12 merge window has been closed. The RC1 of kernel 5.12 is available for the X1000 and X5000.
Download: linux-image-5.12-rc1-X1000_X5000.tar.gz
@Musa
Could you please test this kernel because of Darren's new patch on your X1000?
Re: Kernel 5.12
xeno74 wrote: Mon Mar 01, 2021 7:19 am
@Musa
Yes I can Christian.
Here is kernel 5.12-rc1 on Fienix . I have not put modules in libs but the kernel boot fine.
Have a nice day
