Kernel 5.5
Re: Kernel 5.5
Could you please post the output of lsmod? Could you also please post the output of ls -ltr /lib/modules?
Hi Christian
ls mod give nothing
Re: Kernel 5.5
musa wrote: Hi Christian
ls mod give nothing
Hi Musa,
Please run depmod as root. After that run lsmod again.
Re: Kernel 5.5
ls mod give nothing
Hi Musa,
Hi Christian
Nothing but if I use modprobe (module name) saa7146 I can see it with lsmod . I know I don*t use this module.
This is first time I see a loadet module.
Re: Kernel 5.5
I understand. You don’t have a hardware which needs a kernel module so there aren’t any modules loaded.
Please load the kvm-pr kernel module with modprobe kvm-pr. After that run lsmod.
I use the kvm-pr module for improving the performance of Mac OS X in PowerPC QEMU machines.
Screenshot of Mac OS X 10.5.8 Leopard PowerPC in a virtual QEMU/KVM-PR machine on an AmigaOne X1000:
Re: Kernel 5.5
xeno74 wrote:[
Hi Christian
Here is the output in debian 10
module size Used by
kvm_pr 108219 0
kvm 196391 1 kvm_pr
Re: Kernel 5.5
module size Used by
kvm_pr 108219 0
kvm 196391 1 kvm_pr
It works! :-) Normally there aren't any modules loaded because you don’t have a hardware which needs kernel modules.
Re: Kernel 5.5
xeno74 wrote:[
Thanks for your help.
Re: Kernel 5.5
Hi Musa,
Does the RC1 of kernel 5.5 work on your X1000?
Re: Kernel 5.5
xeno74 wrote:Hi Musa,
Hi Christian
I got kernel panic with DEBIAN sid 32bit
But I just install Debian sid 64 bit og try the kernel 5.5 rc1 and it work perfect
