Linux on Sams -Screenshots-
Firefox 30 on Lubuntu 14.04 on a Sam440ep-Flex .
Debian Jessie on Sam440ep-Flex.
Lubuntu 15.04 Alpha
Firefox 34 on Lubuntu 15.04 Alpha
Spectre660 wrote:Firefox 34 on Lubuntu 15.04 Alpha
Impressive :-)
Psensor monitoring RadeonHD temp
Interrogative
Post by Interrogative »
Might psensor be included in the SAM460 live CD, or do I have to do a full install?
Motherboard: SAM460ex lite @1017 MHz 2 GB DDR2 SOLD
PCIe 4x: XFX Radeon HD 7750 Core Edition 1 GB SOLD
PCI: SYBA SY-SA3512-2R 2 Port SATA SOLD
PCIe 1x: Vantec UGT-S110 7.1 Audio SOLD
OS: AmigaOS 4.1 FE SOLD
If you boot the live cd and start a terminal you may be able to get the info by using the command sensors.
the output is like this
$ sensors
radeon-pci-18100
Adapter: PCI adapter
temp1: +46.0°C (crit = +0.0°C, hyst = +0.0°C)
You would have to do a full install of Linux to install the psensor program. The psensor programs is not installed by default so would not be on the live cd .
Note the current versions use a newer net install iso. The Live CD is outdated.
Read the notes for installation here to see what is required .
http://forum.hyperion-entertainment.biz ... 094#p25094
If you want to try installing I suggest Lubuntu 14.04LTS for your first installation . Install iso download link below .
http://www.xenosoft.de/Sam_Lubuntu_14.0 ... tall-2.iso
PS: Thanks for the Idea of riser cables.
http://forum.hyperion-entertainment.biz ... 649#p30113
Interrogative wrote:Might psensor be included in the SAM460 live CD, or do I have to do a full install?
Interrogative
Thank you for the information on the LiveCD and the link for Lubuntu. You are welcome for the riser card idea. I have used the ARC1-152-C7 riser card for a few years now with no problems. Since I am now using the HR-03 GT wrap around heatsink on the 4850, I have freed up the PCI slot. If I get a newer graphics card at some point, and most newer cards are dual slot, I may put that riser card to use once again.
Debian Jessie - Mate .
This seems to be giving the best Linux 2D performance for me on a Sam460ex.
