SliTaz PPC Linux
Re: SliTaz PPC Linux
Snapshot 18 ;-) We have a graphical user interface on SliTaz!!!!!!
You can start it with:
Xfbdev -retro -mouse mouse,device=/dev/input/mice -keybd evdev,,device=/dev/input/event0 | exec jwm
- added mkfontdir-1.0.7 (X11R7.7)
- added mkfontscale-1.1.0 (X11R7.7)
- added glproto-1.4.15 (X11R7.7)
- added recordproto-1.14.2 (X11R7.7)
- added libXfont-1.4.5 (X11R7.7)
- added xorg-server-1.12.2 (X11R7.7)
- added xf86-video-vesa-2.3.1 (X11R7.7)
- added xf86-video-ati-6.14.4 (X11R7.7)
- added xf86-input-mouse-1.7.2 (X11R7.7)
- added xf86-input-keyboard-1.6.1 (X11R7.7)
- added xf86-input-evdev-2.7.0 (X11R7.7)
- added xf86-input-joystick-1.6.1 (X11R7.7)
- added font-xfree86-type1-1.0.4 (X11R7.7)
- added font-adobe-75dpi-1.0.3 (X11R7.7)
- added encodings-1.0.4 (X11R7.7)
- added font-adobe-100dpi-1.0.3 (X11R7.7)
- added font-bitstream-75dpi-1.0.3 (X11R7.7)
- added xkeyboard-config-2.6 (X11R7.7)
- added xcb-proto-1.7.1 (X11R7.7)
- added libxcb-1.8.1 (X11R7.7)
- added xkbcomp-1.2.4 (X11R7.7)
- added KDrive Tiny X Server-1.12.2 (X11R7.7)
- added CMatrix-1.2a-4 screensaver for the terminal
- added xterm-300 - Terminal Emulator
- added libpng-1.6.8 - PNG Libraries
- added jwm-2.2.0 - Window manager
Download: slitaz18.gz
For the development:
Set PKG config path for the X server:
export PKG_CONFIG_PATH=/home/christian/distro/rootfs/usr/lib/pkgconfig
Configure command for a tiny X server (KDrive):
./configure --prefix=/usr --sysconfdir=/etc --mandir=/usr/share/man --localstatedir=/var --build=powerpc-linux-gnu --host=powerpc-linux-gnu --disable-static --disable-aiglx --disable-config-dbus --disable-config-hal --disable-dbe --disable-dga --disable-dpms --disable-dri --disable-glx --disable-glx-tls --disable-int10-module --disable-ipv6 --disable-screensaver --disable-secure-rpc --disable-tcp-transport --disable-vbe --disable-vgahw --disable-xdm-auth-1 --disable-xinerama --disable-xwin --disable-xaa --disable-xace --disable-xdmcp --disable-xf86vidmode --disable-xfree86-utils --disable-xnest --disable-xvmc --disable-libdrm --enable-config-udev --enable-dri2 --enable-record --enable-unit-tests --enable-visibility --enable-xorg --enable-kdrive --enable-kdrive-kbd --enable-kdrive-mouse --enable-kdrive-evdev
My special "make" command:
make DESTDIR=$PWD/_pkg install
Here is a screenshot of the SliTaz GUI:
(2.24 MiB) Downloaded 487 times
The first graphical web browser on SliTaz:
(2.04 MiB) Downloaded 452 times
Snapshot 19 is here. ;-)
- added Dillo 3.0.3 graphical web browser
- added startx script - This script is an easy way to start an X session.
Download: slitaz19.gz
Snapshot 20 is coming.
(858.64 KiB) Downloaded 419 times
Snapshot 20 is available:
- added cairo-1.12.16 - 2D graphics library
- added glib-2.36.4 - C routines
- added pango-1.3.6 - Library for layout and rendering of text
- added atk-2.11.5 - Accessibility toolkit
- added gtk+-3.8.6 - The GIMP Toolkit
- added l3afpad-0.8.18.1.10 - Simple text editor
- added mtpaint-3.40 - Image creation and processing
- added startx2 script - Script for another configuration of X session.
Download: slitaz20.gz
Script startx2:
Xfbdev -retro -mouse evdev,,device=/dev/input/event0 -keybd evdev,,device=/dev/input/event2 | exec jwm
Snapshot 21 - A small update. :-)
- replaced l3afpad with NEdit 5.6 (Simple text editor)
Download: slitaz21.gz
Snapshot 22 with AmiWM 0.20.48 ;-)
AmiWM is an X window manager that tries to make your display look and feel like an Amiga Workbench screen. It is fully functional and can do all the usual window manager stuff, like moving and resizing windows. You can start AmiWM with the script "startamiwm".
The script "startamiwm" contains the following command:
Xfbdev -retro -mouse mouse,device=/dev/input/mice -keybd evdev,,device=/dev/input/event0 | xterm -e amiwm
Screenshot:
Download: slitaz22.gz
Have a lot of fun with SliTaz. :-)
zappa2009
Post by zappa2009 »
Add XBMC ;) That would be very cool
*** Snapshot 23 with Worker, the DOpus clone for Linux *** :-)
Download: slitaz23.gz
I suggest to download SliTaz with a right click on the link and then with the menu point "Save target as" or something like this.
