They modified the CFLAGS in the Makefile from power5 and power4 to only power4. I reverted it.
a/arch/powerpc/Makefile
+CFLAGS-$(CONFIG_GENERIC_CPU) += $(call cc-option,-mcpu=power5,-mcpu=power4)
-CFLAGS-$(CONFIG_GENERIC_CPU) += -mcpu=power4
But it doesn't solve this issue.
I bisected today because Void is recovering after a reboot. Memory space is released again.
About bisecting:
Git bisect is like a little wizard that walks you through recent commits, asks you if they are good or bad, and narrows down the broken commit.
Git bisect starts with the midpoint commit. The midpoint commit is between the initial good commit and the initial bad commit.
If the midpoint commit was good, you know the commit that introduced the change is between your midpoint and the initial bad commit.
If the midpoint commit was bad, you know the commit that introduced the change is between your midpoint and the initial good commit.
After that git bisect selects a new midpoint in the area where the commit was bad. And this is repeated over and over again till the bad commit has been found.
  1. Code: Select all
    git clone git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux.git a
    or
    git clone --depth=1 git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux.git a
  2. Code: Select all
    git bisect start
  3. Code: Select all
    git bisect good 4fe89d07dcc2804c8b562f6c7896a45643d34b2f
    (Good: Linux 6.0)
  4. Code: Select all
    git bisect bad 9abf2313adc1ca1b6180c508c25f22f9395cc780
    (Bad: Linux 6.1-rc1
    Output:
    Bisecting: 6125 revisions left to test after this (roughly 13 steps)
    [18fd049731e67651009f316195da9281b756f2cf] Merge tag 'arm64-upstream' of git://git.kernel.org/pub/scm/linux/kernel/git/arm64/linux
  5. git bisect good
    Output:
    Bisecting: 3062 revisions left to test after this (roughly 12 steps)
    [ab0c23b535f3f9d8345d8ad4c18c0a8594459d55] MAINTAINERS: add RISC-V's patchwork
  6. git bisect good
    Output:
    Bisecting: 1527 revisions left to test after this (roughly 11 steps)
    [27bc50fc90647bbf7b734c3fc306a5e61350da53] Merge tag 'mm-stable-2022-10-08' of git://git.kernel.org/pub/scm/linux/kernel/git/akpm/mm
  7. git bisect bad
    Output:
    Bisecting: 766 revisions left to test after this (roughly 10 steps)
    [ada3bfb6492a6d0d3eca50f3b61315fe032efc72] Merge tag 'tpmdd-next-v6.1-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/jarkko/linux-tpmdd
  8. git bisect bad
    Output:
    Bisecting: 379 revisions left to test after this (roughly 9 steps)
    [7f6dcffb44ad246e3211c6aeaba8a625e2766836] Merge tag 'sched-rt-2022-10-05' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip
  9. git bisect bad
    Output:
    Bisecting: 193 revisions left to test after this (roughly 8 steps)
    [9511b5a033e99070ae1f54cd3c0aa3d10eae7c26] Merge branch 'topic/ppc-kvm' into next
  10. git bisect bad
    Output:
    Bisecting: 96 revisions left to test after this (roughly 7 steps)
    [b997b2f57cae396448bb62c428efa4b112dd90ed] powerpc/mm: Reduce redundancy in pgtable.h
  11. git bisect good
    Output:
    Bisecting: 48 revisions left to test after this (roughly 6 steps)
    [b19448fe846baad689ff51a991ebfc74b4b5e0a8] powerpc: Add support for early debugging via Serial 16550 console
  12. git bisect bad
    Output:
    Bisecting: 23 revisions left to test after this (roughly 5 steps)
    [6556fd1a1e9fcd180348c4368d2387bdc6a17613] powerpc: Cleanup idle for e500
  13. git bisect good
    Output:
    Bisecting: 11 revisions left to test after this (roughly 4 steps)
    [c2e7a19827eec443a7cbe85e8d959052412d6dc3] powerpc: Use generic fallocate compatibility syscall
  14. git bisect bad
    Output:
    Bisecting: 5 revisions left to test after this (roughly 3 steps)
    [2b1dac4b5f97ea88fb01dfcab7fc24500b5dea95] powerpc/64s: Use {ZEROIZE,SAVE,REST}_GPRS macros in sc, scv 0 handlers
  15. git bisect good
    Output:
    Bisecting: 2 revisions left to test after this (roughly 2 steps)
    [620f5c59c8617d623428c03414a022fca4e9eea2] powerpc/64s: Fix comment on interrupt handler prologue
  16. git bisect good
    Output:
    Bisecting: 0 revisions left to test after this (roughly 1 step)
    [43d5de2b67d7f4a8478820005152f7f689608f2f] asm-generic: compat: Support BE for long long args in 32-bit ABIs
  17. git bisect good
    Output:
    c2e7a19827eec443a7cbe85e8d959052412d6dc3 is the first bad commit
    commit c2e7a19827eec443a7cbe85e8d959052412d6dc3
    Author: Rohan McLure <rmclure@linux.ibm.com>
    Date:   Wed Sep 21 16:55:50 2022 +1000
        The powerpc fallocate compat syscall handler is identical to the
        generic implementation provided by commit 59c10c52f573f ("riscv:
        compat: syscall: Add compat_sys_call_table implementation"), and as
        such can be removed in favour of the generic implementation.
        A future patch series will replace more architecture-defined syscall
        handlers with generic implementations, dependent on introducing generic
        implementations that are compatible with powerpc and arm's parameter
        reorderings.
        Reported-by: Arnd Bergmann <arnd@arndb.de>
        Signed-off-by: Rohan McLure <rmclure@linux.ibm.com>
        Reviewed-by: Arnd Bergmann <arnd@arndb.de>
        Link: https://lore.kernel.org/r/20220921065605.1051927-11-rmclure@linux.ibm.com
     arch/powerpc/include/asm/syscalls.h | 2 --
     arch/powerpc/include/asm/unistd.h   | 1 +
     arch/powerpc/kernel/sys_ppc32.c     | 7 -------
     3 files changed, 1 insertion(+), 9 deletions(-)
Result: c2e7a19827eec443a7cbe85e8d959052412d6dc3 (powerpc: Use generic fallocate compatibility syscall) is the first bad commit.
Unfortunately I wasn't able to revert the first bad commit.
git revert c2e7a19827eec443a7cbe85e8d959052412d6dc3
But I was able to create a patch for reverting the bad commit.
diff -rupN a b > syscall.patch
syscall.patch:
diff -rupN a/arch/powerpc/include/asm/syscalls.h b/arch/powerpc/include/asm/syscalls.h
--- a/arch/powerpc/include/asm/syscalls.h       2022-10-30 13:53:28.956001116 +0100
+++ b/arch/powerpc/include/asm/syscalls.h       2022-10-30 13:55:39.166300756 +0100
@@ -15,6 +15,7 @@
 #include <asm/unistd.h>
 #include <asm/ucontext.h>
+long compat_sys_fallocate(int fd, int mode, u32 offset1, u32 offset2, u32 len1, u32 len2);
 #ifndef CONFIG_ARCH_HAS_SYSCALL_WRAPPER
 long sys_ni_syscall(void);
 #else
diff -rupN a/arch/powerpc/include/asm/unistd.h b/arch/powerpc/include/asm/unistd.h
--- a/arch/powerpc/include/asm/unistd.h 2022-10-30 13:53:28.957001103 +0100
+++ b/arch/powerpc/include/asm/unistd.h 2022-10-30 13:56:44.851441888 +0100
@@ -45,7 +45,6 @@
 #define __ARCH_WANT_SYS_UTIME
 #define __ARCH_WANT_SYS_NEWFSTATAT
 #define __ARCH_WANT_COMPAT_STAT
-#define __ARCH_WANT_COMPAT_FALLOCATE
 #define __ARCH_WANT_COMPAT_SYS_SENDFILE
 #endif
 #define __ARCH_WANT_SYS_FORK
diff -rupN a/arch/powerpc/kernel/sys_ppc32.c b/arch/powerpc/kernel/sys_ppc32.c
--- a/arch/powerpc/kernel/sys_ppc32.c   2022-10-30 13:53:28.967000972 +0100
+++ b/arch/powerpc/kernel/sys_ppc32.c   2022-10-30 13:58:28.993078689 +0100
@@ -97,6 +97,13 @@ PPC32_SYSCALL_DEFINE4(ppc_truncate64,
        return ksys_truncate(path, merge_64(len1, len2));
+                                    u32 len1, u32 len2)
+       return ksys_fallocate(fd, mode, merge_64(offset1, offset2),
+                            merge_64(len1, len2));
 PPC32_SYSCALL_DEFINE4(ppc_ftruncate64,
                       unsigned int, fd, u32, reg4,
                       unsigned long, len1, unsigned long, len2)
I compiled the kernel with this patch. After that the kernel works without any problems.
I reported this issue to the Linuxppc-dev mailing list today.
Link: Issues with the first PowerPC updates for the kernel 6.1
Here is the RC2 of kernel 6.1 for testing.
Download: linux-image-6.1-rc2-X1000_X5000.tar.gz
I released the RC3 of kernel 6.1 for the X1000 and X5000 today.
We still need the syscall patch because of the issue with filling the file system to 100%.
Download: linux-image-6.1-rc3-X1000_X5000.tar.gz
Please test,
Maybe the issues with syscalls (The root partition is filling up) is fixed. ;-)
Links:
PowerPC fixes 6.1-4
[GIT PULL] Please pull powerpc/linux.git powerpc-6.1-4 tag
Hi Just boot my Debian Bookworms/sid 64 with linux-6.1_rc3 .
Have a nice day
musa wrote: Sat Nov 05, 2022 3:45 pm Hi Just boot my Debian Bookworms/sid 64 with linux-6.1_rc3 .
Have a nice day
Have a nice day too.
I released the RC3-2 of kernel 6.1 for testing today.
Download: linux-image-6.1-rc3-2-X1000_X5000.tar.gz
Hi all
Debian/bookworm 64 bit run on kernel vmlinux-6.1.0-rc3_2.
simultaneously testing fs.uae with a wb3.1. the yellow color must be a bug, because it is not there if I choose a screnmode that does not use uae graphics card.
Have a nice day
Peter
musa wrote: Mon Nov 07, 2022 9:02 pm Hi all
Have a nice day
Peter
Hi Peter,
Thanks a lot for testing the RC3-2. :-) I compiled FS-UAE for Linux PPC 32-bit 8 years ago. Link to the thread: FS-UAE. The UAE graphics card had no color issues.
