Linux PowerPC Server Software
Re: Linux PowerPC Server Software
Samba: rpcclient:
Samba: samba-tool domain join with Samba 4.13.4 on MintPPC:
Samba: Directory Replication Service (DRS):
samba-tool domain join a-eon.tld DC --realm=a-eon.tld -Uadministrator
INFO 2021-03-10 14:15:51,669 pid:22316 /usr/lib/python3/dist-packages/samba/join.py #107: Finding a writeable DC for domain 'a-eon.tld'
INFO 2021-03-10 14:15:51,740 pid:22316 /usr/lib/python3/dist-packages/samba/join.py #109: Found DC dc1fl2008r2.a-eon.tld
Password for [WORKGROUP\administrator]:
INFO 2021-03-10 14:18:19,183 pid:22316 /usr/lib/python3/dist-packages/samba/join.py #1542: workgroup is A-EON
INFO 2021-03-10 14:18:19,184 pid:22316 /usr/lib/python3/dist-packages/samba/join.py #1545: realm is a-eon.tld
Adding CN=MINTPPC,OU=Domain Controllers,DC=a-eon,DC=tld
Adding CN=MINTPPC,CN=Servers,CN=Default-First-Site-Name,CN=Sites,CN=Configuration,DC=a-eon,DC=tld
Adding CN=NTDS Settings,CN=MINTPPC,CN=Servers,CN=Default-First-Site-Name,CN=Sites,CN=Configuration,DC=a-eon,DC=tld
Adding SPNs to CN=MINTPPC,OU=Domain Controllers,DC=a-eon,DC=tld
Setting account password for MINTPPC$
Enabling account
Calling bare provision
INFO 2021-03-10 14:18:20,423 pid:22316 /usr/lib/python3/dist-packages/samba/provision/__init__.py #2122: Looking up IPv4 addresses
INFO 2021-03-10 14:18:20,424 pid:22316 /usr/lib/python3/dist-packages/samba/provision/__init__.py #2139: Looking up IPv6 addresses
WARNING 2021-03-10 14:18:20,424 pid:22316 /usr/lib/python3/dist-packages/samba/provision/__init__.py #2146: No IPv6 address will be assigned
INFO 2021-03-10 14:18:21,191 pid:22316 /usr/lib/python3/dist-packages/samba/provision/__init__.py #2290: Setting up share.ldb
INFO 2021-03-10 14:18:21,231 pid:22316 /usr/lib/python3/dist-packages/samba/provision/__init__.py #2294: Setting up secrets.ldb
INFO 2021-03-10 14:18:21,257 pid:22316 /usr/lib/python3/dist-packages/samba/provision/__init__.py #2299: Setting up the registry
INFO 2021-03-10 14:18:21,367 pid:22316 /usr/lib/python3/dist-packages/samba/provision/__init__.py #2302: Setting up the privileges database
INFO 2021-03-10 14:18:21,416 pid:22316 /usr/lib/python3/dist-packages/samba/provision/__init__.py #2305: Setting up idmap db
INFO 2021-03-10 14:18:21,471 pid:22316 /usr/lib/python3/dist-packages/samba/provision/__init__.py #2312: Setting up SAM db
INFO 2021-03-10 14:18:21,479 pid:22316 /usr/lib/python3/dist-packages/samba/provision/__init__.py #897: Setting up sam.ldb partitions and settings
INFO 2021-03-10 14:18:21,481 pid:22316 /usr/lib/python3/dist-packages/samba/provision/__init__.py #909: Setting up sam.ldb rootDSE
INFO 2021-03-10 14:18:21,488 pid:22316 /usr/lib/python3/dist-packages/samba/provision/__init__.py #1322: Pre-loading the Samba 4 and AD schema
Unable to determine the DomainSID, can not enforce uniqueness constraint on local domainSIDs
INFO 2021-03-10 14:18:21,554 pid:22316 /usr/lib/python3/dist-packages/samba/provision/__init__.py #2364: A Kerberos configuration suitable for Samba AD has been generated at /var/lib/samba/private/krb5.conf
INFO 2021-03-10 14:18:21,554 pid:22316 /usr/lib/python3/dist-packages/samba/provision/__init__.py #2366: Merge the contents of this file with your system krb5.conf or replace it with this one. Do not create a symlink!
Provision OK for domain DN DC=a-eon,DC=tld
Starting replication
Schema-DN[CN=Schema,CN=Configuration,DC=a-eon,DC=tld] objects[402/2004] linked_values[0/0]
Schema-DN[CN=Schema,CN=Configuration,DC=a-eon,DC=tld] objects[804/2004] linked_values[0/0]
Schema-DN[CN=Schema,CN=Configuration,DC=a-eon,DC=tld] objects[1206/2004] linked_values[0/0]
Schema-DN[CN=Schema,CN=Configuration,DC=a-eon,DC=tld] objects[1608/2004] linked_values[0/0]
Schema-DN[CN=Schema,CN=Configuration,DC=a-eon,DC=tld] objects[1773/2004] linked_values[0/0]
Analyze and apply schema objects
Partition[CN=Configuration,DC=a-eon,DC=tld] objects[402/3621] linked_values[0/24]
Partition[CN=Configuration,DC=a-eon,DC=tld] objects[804/3621] linked_values[0/24]
Partition[CN=Configuration,DC=a-eon,DC=tld] objects[1206/3621] linked_values[0/24]
Partition[CN=Configuration,DC=a-eon,DC=tld] objects[1608/3621] linked_values[0/24]
Partition[CN=Configuration,DC=a-eon,DC=tld] objects[1902/3621] linked_values[24/24]
dsdb_replicated_objects_convert: Ignoring object outside partition ec2ed4bd-ff53-4271-8a3c-7e3c998242f0 CN=Schema,CN=Configuration,DC=a-eon,DC=tld: WERR_DS_ADD_REPLICA_INHIBITED
Replicating critical objects from the base DN of the domain
Partition[DC=a-eon,DC=tld] objects[114/115] linked_values[32/44]
Partition[DC=a-eon,DC=tld] objects[293/2279] linked_values[44/44]
dsdb_replicated_objects_convert: Ignoring object outside partition ecbab645-0d7d-4992-b6a8-b034d83dc54e CN=Configuration,DC=a-eon,DC=tld: WERR_DS_ADD_REPLICA_INHIBITED
dsdb_replicated_objects_convert: Ignoring object outside partition 0b35ad6c-5306-4710-8e40-669b61d6615d DC=DomainDnsZones,DC=a-eon,DC=tld: WERR_DS_ADD_REPLICA_INHIBITED
dsdb_replicated_objects_convert: Ignoring object outside partition 2065971b-a028-4711-bb94-afcf94e0c185 DC=ForestDnsZones,DC=a-eon,DC=tld: WERR_DS_ADD_REPLICA_INHIBITED
Done with always replicated NC (base, config, schema)
Replicating DC=DomainDnsZones,DC=a-eon,DC=tld
Partition[DC=DomainDnsZones,DC=a-eon,DC=tld] objects[45/45] linked_values[0/0]
Replicating DC=ForestDnsZones,DC=a-eon,DC=tld
Partition[DC=ForestDnsZones,DC=a-eon,DC=tld] objects[20/20] linked_values[0/0]
Exop on[CN=RID Manager$,CN=System,DC=a-eon,DC=tld] objects[3] linked_values[0]
Committing SAM database
Repacking database from v1 to v2 format (first record CN=MSMQ-Site-ID,CN=Schema,CN=Configuration,DC=a-eon,DC=tld)
Repack: re-packed 10000 records so far
Repacking database from v1 to v2 format (first record CN=remoteStorageServicePoint-Display,CN=40E,CN=DisplaySpecifiers,CN=Configuration,DC=a-eon,DC=tld)
Repacking database from v1 to v2 format (first record DC=a.root-servers.net,DC=RootDNSServers,CN=MicrosoftDNS,DC=DomainDnsZones,DC=a-eon,DC=tld)
Repacking database from v1 to v2 format (first record CN=NTDS Quotas,DC=ForestDnsZones,DC=a-eon,DC=tld)
Repacking database from v1 to v2 format (first record CN=6bcd5678-8314-11d6-977b-00c04f613221,CN=Operations,CN=DomainUpdates,CN=System,DC=a-eon,DC=tld)
INFO 2021-03-10 14:19:23,602 pid:22316 /usr/lib/python3/dist-packages/samba/join.py #1115: Adding 1 remote DNS records for MINTPPC.a-eon.tld
INFO 2021-03-10 14:19:23,765 pid:22316 /usr/lib/python3/dist-packages/samba/join.py #1178: Adding DNS A record MINTPPC.a-eon.tld for IPv4 IP: 192.168.178.52
INFO 2021-03-10 14:19:23,781 pid:22316 /usr/lib/python3/dist-packages/samba/join.py #1206: Adding DNS CNAME record d88a0f18-262f-48c4-b3b9-246d562fb2df._msdcs.a-eon.tld for MINTPPC.a-eon.tld
INFO 2021-03-10 14:19:23,799 pid:22316 /usr/lib/python3/dist-packages/samba/join.py #1231: All other DNS records (like _ldap SRV records) will be created samba_dnsupdate on first startup
INFO 2021-03-10 14:19:23,800 pid:22316 /usr/lib/python3/dist-packages/samba/join.py #1237: Replicating new DNS records in DC=DomainDnsZones,DC=a-eon,DC=tld
Partition[DC=DomainDnsZones,DC=a-eon,DC=tld] objects[2/45] linked_values[0/0]
INFO 2021-03-10 14:19:23,840 pid:22316 /usr/lib/python3/dist-packages/samba/join.py #1237: Replicating new DNS records in DC=ForestDnsZones,DC=a-eon,DC=tld
Partition[DC=ForestDnsZones,DC=a-eon,DC=tld] objects[1/20] linked_values[0/0]
INFO 2021-03-10 14:19:23,877 pid:22316 /usr/lib/python3/dist-packages/samba/join.py #1252: Sending DsReplicaUpdateRefs for all the replicated partitions
INFO 2021-03-10 14:19:23,897 pid:22316 /usr/lib/python3/dist-packages/samba/join.py #1282: Setting isSynchronized and dsServiceName
INFO 2021-03-10 14:19:23,920 pid:22316 /usr/lib/python3/dist-packages/samba/join.py #1297: Setting up secrets database
INFO 2021-03-10 14:19:24,047 pid:22316 /usr/lib/python3/dist-packages/samba/join.py #1559: Joined domain A-EON (SID S-1-5-21-3013380877-1782985227-1992217183) as a DC
Windows Server 2019 AD-DC in a Samba AD domain:
The bind9-host package provides the “host” command.
The package bind9-dnsutils provides the command "dig" and “nslookup”. You need also the packages "bind9-libs" and "libjson-c5" as dependencies.
whois is in the package “whois”.
Windows 2000 in a Samba NT4 domain:
Winbind: idmap:
Winbind: idmap tests:
Winbind: idmap tests part2:
Access to an AD LDAP server without a join:
