Kernel 5.0
Re: Kernel 5.0
Christoph's new patch fixes the problems with the P.A. Semi Ethernet! :-)
Re: Kernel 5.0
Christoph Hellwig wrote: Thanks a lot once again for testing!
Now can you test with this patch and the whole series?
I've updated the powerpc-dma.6 branch to include this fix.
Gitweb: powerpc-dma.6
git clone git://git.infradead.org/users/hch/misc.git -b powerpc-dma.6 a
Re: Kernel 5.0
FYI:
Darren Stevens wrote: Hello Christoph
Finally got to compile a working version from this, not sure what was wrong with my previous builds...
I've tested on my X5000, all working good so far, in fact my Soundblaster live sound card seem to like the changes and works without patching the kernel. (Nice)
Not sure when I'll get chance to test on X1000 though.
Regards
Darren
Update: I found the following in my dmesg, think it points to an of-by-one error in the pfn selection:
Feb 9 19:47:00 Cyrus kernel: [ 0.000000] Top of RAM: 0x200000000, Total RAM: 0x200000000
Feb 9 19:47:00 Cyrus kernel: [ 0.000000] Memory hole size: 0MB
Feb 9 19:47:00 Cyrus kernel: [ 0.000000] Zone ranges:
Feb 9 19:47:00 Cyrus kernel: [ 0.000000] DMA [mem 0x0000000000000000-0x000000007fffefff]
Feb 9 19:47:00 Cyrus kernel: [ 0.000000] Normal [mem 0x000000007ffff000-0x00000001ffffffff]
I had a quick look but couldn't see where though.
Regards
Darren
Darren Stevens wrote: The Cyrus board from Varisys has power-off and reset functions attached
to gpio pins. Add the required device-tree bindings.
Signed-off-by: Darren Stevens <darren@stevens-zone.net>
diff --git a/arch/powerpc/boot/dts/fsl/cyrus_p5020.dts b/arch/powerpc/boot/dts/fsl/cyrus_p5020.dts
index c603390..15e8440 100644
--- a/arch/powerpc/boot/dts/fsl/cyrus_p5020.dts
+++ b/arch/powerpc/boot/dts/fsl/cyrus_p5020.dts
@@ -71,6 +71,17 @@
                reg = <0x6f>;
+       gpio-poweroff {
+           compatible = "gpio-poweroff";
+           gpios = <&gpio0 3 1>;
+       gpio-restart {
+           compatible = "gpio-restart";
+           gpios = <&gpio0 2 1>;
    rio: rapidio@ffe0c0000 {
Darren Stevens wrote: The disk activity LED on the Cyrus board is attached to a gpio pin,
add the required device-tree node for the kernel driver to use.
index 15e8440..348cfdb 100644
@@ -82,6 +82,15 @@
+       leds {
+           compatible = "gpio-leds";
+           hdd {
+               label = "Disk Activity";
+               gpios = <&gpio0 5 0>;
+               linux,default-trigger = "disk-activity";
Link to the thread: use generic DMA mapping code in powerpc V4
Re: Kernel 5.0
I tested Christoph's latest Git kernel in a virtual e5500 QEMU machine [1] today. Unfortunately the kernel crashes.
[   54.624330] BUG: Unable to handle kernel data access at 0xc06c008a0013014a
[   54.625640] Faulting instruction address: 0xc000000000027e7c
[   54.626140] Oops: Kernel access of bad area, sig: 11 [#1]
[   54.626456] BE SMP NR_CPUS=4 QEMU e500
[   54.626876] Modules linked in:
[   54.627284] CPU: 1 PID: 1876 Comm: systemd-journal Not tainted 5.0.0-rc5-DMA_A1-X5000-54581-gda1d065-dirty #1
[   54.627819] NIP:  c000000000027e7c LR: c0000000000b5264 CTR: 0000000000000000
[   54.628173] REGS: c00000007ffeb700 TRAP: 0300   Not tainted  (5.0.0-rc5-DMA_A1-X5000-54581-gda1d065-dirty)
[   54.628607] MSR:  0000000080009000 <EE,ME>  CR: 44008486  XER: 00000000
[   54.629023] DEAR: c06c008a0013014a ESR: 0000000000800000 IRQMASK: 0
[   54.629023] GPR00: 0000000000005254 c00000007ffeb990 c0000000016b2000 c06c008a0013014a
[   54.629023] GPR04: c00000007c54f8c0 0000000000000058 0000000000000006 0000000000000000
[   54.629023] GPR08: 0000000000000000 000000007c54f8c0 006c008a0013014a c00000007c86c000
[   54.629023] GPR12: 0000000028002482 c00000003ffff8c0 0000000000000000 c000000078dfaa70
[   54.629023] GPR16: c000000078366c00 0000000000000000 000000000000005e 0000000000000000
[   54.629023] GPR20: 0000000000000000 c00000007c54f8c0 0000000000000007 c000000078dfa000
[   54.629023] GPR24: 0000000000000000 0000000000000047 0000000000000000 80000000003f6470
[   54.629023] GPR28: c00000007928d470 c000000078801dc0 000000000000005e c000000078dfa7c0
[   54.632572] NIP [c000000000027e7c] .memcpy+0x1fc/0x288
[   54.632886] LR [c0000000000b5264] .swiotlb_tbl_sync_single+0xb0/0xe4
[   54.633221] Call Trace:
[   54.633513] [c00000007ffeb990] [c00000007ffeba70] 0xc00000007ffeba70 (unreliable)
[   54.633988] [c00000007ffeba00] [c0000000000b41e4] .dma_direct_sync_single_for_cpu+0x58/0x6c
[   54.634436] [c00000007ffeba70] [c000000000788da4] .e1000_clean_rx_irq+0x1bc/0x4c8
[   54.634857] [c00000007ffebb90] [c00000000078667c] .e1000_clean+0x714/0x8d4
[   54.635263] [c00000007ffebcc0] [c000000000a3f15c] .net_rx_action+0x11c/0x2a4
[   54.635712] [c00000007ffebdb0] [c000000000c48c20] .__do_softirq+0x150/0x2a8
[   54.636211] [c00000007ffebeb0] [c000000000064184] .irq_exit+0x6c/0xc4
[   54.636533] [c00000007ffebf20] [c000000000004124] .__do_irq+0x80/0x94
[   54.636985] [c00000007ffebf90] [c00000000000eca0] .call_do_irq+0x14/0x24
[   54.637371] [c00000007c86fd80] [c0000000000041c0] .do_IRQ+0x88/0xc4
[   54.637737] [c00000007c86fe20] [c000000000012920] exc_0x500_common+0xd8/0xdc
[   54.638104] Instruction dump:
[   54.638451] e861fff8 4e800020 7cd01120 7ca62850 38e00000 28a50010 409f0010 88040000
[   54.638887] 98030000 38e70001 409e0010 7c07222e <7c071b2e> 38e70002 409d000c 7c07202e
[   54.639594] ---[ end trace a4861de7e4c199f7 ]---
[   54.639873]
[   55.640484] Kernel panic - not syncing: Aiee, killing interrupt handler!
[   55.641556] Rebooting in 180 seconds..
I tested with the following QEMU commands:
./qemu-system-ppc64 -M ppce500 -cpu e5500 -m 2048  -nographic -kernel /home/christian/Downloads/vmlinux-5.0-rc5-2-AmigaOne_X1000_X5000/X5000_and_QEMU_e5500/uImage-5.0 -nic user,model=e1000 -drive format=raw,file=/home/christian/Downloads/MATE_PowerPC_Remix_2017_0.9.img,index=0,if=virtio -append "rw root=/dev/vda" -smp 4
./qemu-system-ppc64 -M ppce500 -cpu e5500 -m 2048 -kernel /home/christian/Downloads/vmlinux-5.0-rc5-2-AmigaOne_X1000_X5000/X5000_and_QEMU_e5500/uImage-5.0 -drive format=raw,file=/home/christian/Downloads/MATE_PowerPC_Remix_2017_0.9.img,index=0,if=virtio -nic user,model=e1000 -append "rw root=/dev/vda" -device virtio-vga -device virtio-mouse-pci -device virtio-keyboard-pci -usb -soundhw es1370 -smp 4
[1] Gitweb: powerpc-dma.6
Re: Kernel 5.0
The kernel developers want to use the generic DMA mapping code for PowerPC machines. They modified the source code for testing. Maybe they want to add it to the kernel 5.1. They have released a kernel with the DMA modifications. We are testing kernels from this Git currently.
Link to the Git: powerpc-dma.6
I have created a kernel from this Git for testing.
Download: vmlinux-5.0-rc5-2-AmigaOne_X1000_X5000.tar.gz
Please test it carefully.
Re: Kernel 5.0
Kernel 5.0 RC5-2 DMA running without any issues on the AmigaOne X5000 :-)
Big Picture http://www.skateman.nl/wp-content/uploa ... 140832.png
As expected the dpaa network issues still remain as shown by the dmesg eth output.
Re: Kernel 5.0
Skateman wrote:Kernel 5.0 RC5-2 DMA running without any issues on the AmigaOne X5000 :-)
— Christian
Re: Kernel 5.0
I released the RC6 of kernel 5.0 today.
Download: linux-image-5.0-rc6-X1000_X5000.tar.gz
Please test all kernels.
Re: Kernel 5.0
[quote="xeno74"]Hi All,
Please test all kernels./quote]
Not sure that anything I do is "careful testing" but I booted with 5.0-rc5-2-... yesterday and rc6 now. No new problems in either fienix or MATE..
Re: Kernel 5.0
Kernel 5.0 RC6 non dpaa patched is running fine on the AmigaOne X5000 :-)
Big picture http://www.skateman.nl/wp-content/uploa ... 221523.png
