No Ethernet with... Sound Blaster card ?
Amiguy
Re: No Ethernet with... Sound Blaster card ?
Post by Amiguy »
Here is my fienix boot variable:
fienix=setenv bootargs root=/dev/sda2 ; load sata 0:1 1000000 uImage-5.12 ; load sata 0:1 2000000 cyrus-p5020.dtb ; bootm 1000000 - 2000000 ; mem=3500M
Is this right ?
This is what the 'cat/proc/asound/cards' command displays:
 0 [VirMIDI        ]: VirMIDI - VirMIDI
                      Virtual MIDI Card 1
 1 [HDMI           ]: HDA-Intel - HDA ATI HDMI
                      HDA ATI HDMI at 0xc10040000 irq 43
Amiguy wrote: Sat Jul 24, 2021 9:16 am Here is my fienix boot variable:
Is this right ?
No, it isn’t. This is correct:
fienix=setenv bootargs “root=/dev/sda2 mem=3500M“ ; load sata 0:1 1000000 uImage-5.12 ; load sata 0:1 2000000 cyrus-p5020.dtb ; bootm 1000000 - 2000000
Amiguy
Post by Amiguy »
The mem=3500M argument has no effect on the sound.
Please post the output of lsmod. I would like to see if the kernel module for the ALC898 chip is loaded.
Amiguy
Post by Amiguy »
The output for lsmod :
Module              Size  Used by
uio_pdrv_genirq     7243  0
uio                19689  1 uio_pdrv_genirq
Amiguy wrote: Sat Jul 24, 2021 1:04 pm The output for lsmod :
Module Size Used by
OK, I don't see any modules for sound cards. OK, I have it ...
You don't have a Sound Blaster Audigy FX 5.1 SBX. You have a Sound Blaster Recon3D.
Your output of lspci:
1000:05:00.0 Audio device: Creative Labs Sound Core3D [Sound Blaster Recon3D / Z-Series] (rev 01)
Further information: Sound Blaster Recon3D Finally Seeing Better Linux Support
Our kernels have support for Sound Blaster Recon3D sound cards:
CONFIG_SND_HDA_CODEC_CA0132: Build Creative CA0132 codec support
Please try the command "modprobe snd-hda-codec-ca0132" as root. You can also test it with modprobe "snd-hda-codec-realtek" but this kernel module is only for Audigy cards.
I have found a Linux thread about your Sound Blaster Recon3D:
[Solved] No sound out of Sound Blaster Z-series/Recon3D/Core3D card...
Maybe bad news:
Phoronix wrote:But now thanks to an independent contributor to the ALSA drivers, Connor McAdams, proper Recon3D support appears long at last -- well, at least for the sound cards having the 0x0013 device ID. (The Creative Recon3Di was already supported by Linux and there appears to be other Recon3D sound cards with different device IDs, which haven't yet been added as quirks to the driver.)
Please post the output of "dmesg | grep -i ca0132". I want to make sure, that we are really talking about the right sound card.
Amiguy
Post by Amiguy »
My dear friend,
Thank you for your insistence, but I have bad news.
The modprobe and dmesg commands do not display anything and this is quite logical since my card is indeed a Sound Blaster Audigy. That's precisely my card : https://www.amazon.fr/Creative-Blaster- ... 569&sr=8-3
I bought this card especially for my AmigaOne X5000 thanks to its excellent operation based on a recent and functional driver. But on Fienix, nothing works :(
Amiguy
Post by Amiguy »
It's still curious that the lspci command shows a card (Recon3D) that has nothing to do...
Amiguy
Post by Amiguy »
Christian,
When I run the pacmd list-sources command, I get the information: 'No PulseAudio daemon running, or not running as session daemon.'
Is this daemon necessary and if so, how to activate it?
