Amiga Fast File System (AFFS or FFS)
sailorMH
Re: Amiga Fast File System (AFFS or FFS)
Post by sailorMH »
xeno74 wrote: Fri May 15, 2020 7:33 am Is BDH0 always the first partition on the first hard drive or can it be on the second hard drive as a second partition?
No, not allways. AmigaOS (ans MorphOS) device names are entitely on your decision.
By default the partitions are named:
DH0: first partition (i.e. device, on which usually System: volume), DH1: second
BDH0: first on second disk, etc..
but you can during the creation and anytime later change this name to your favorite name ( for example KONG1: ;-)).
I have on my Pegasos2:
bi0: ( FFS volume for booting images), DH0: (System:, SFS volume of MorphOS), DH1: (Work:, SFS volume of MorphOS) DH2: (Backup:, Ext2 volume)
ADH0: (AOSSystem:, SFS volume of AmigaOS), DH1: (AOSWork:, SFS volume of MorphOS), SWAP (AmigaOS swap), etc..
OK, I think I have it.
parted -l | grep BDH0 -B 11 | grep ' BDH0\|sd'
Output:
Disk /dev/sda: 2000GB
 1      1057kB  123MB   122MB   affs3        BDH0  hidden
This command can find BDH0, DH1 till DH7.
What do you think?
device_id=`parted -l | grep BDH0 -B 11 | grep ' BDH0\|sd' | head -n 1 | cut -f 2 -d ' ' | sed 's/://'`
echo $device_id
Output: /dev/sda
partition_id=`parted -l | grep BDH0 -B 11 | grep ' BDH0\|sd' | tail -n 1 | cut -f 2 -d ' '`
echo $partition_id
Output: 1
mount -t affs $device_id$partition_id /media/fienix/BDH0
mount | tail -n 1
Output: /dev/sda1 on /media/fienix/BDH0 type affs (rw,relatime,bs=1024,volume=:)
Hypex
Post by Hypex »
xeno74 wrote: Fri May 15, 2020 1:51 pm What do you think?
Good one.
What I found myself, which was annoying, is that parted separates the device from the partitions. So you need to grep for Disk and then separate each device listed. Then iterate through the list and send it to parted to give a partition list for that. Take the result and grep it for affs. Combine the device and part and you have a list of AFFS volumes. Using amiga-fdisk may actually help here. I also just checked and parted on x64 has different output. Thought Linux was portable. :-)
Hi
I do not know if it can be used for anything but I use this method and it works fine for me.
mkdir /media/dh0
sudo mount -t affs /dev/sdb3 /media/dh0 (sdb3 is my amiga partion)
sudo chmod -R 777 /media/dh0
sudo chown -R musa:musa /media/dh0
Now you should be able to browse the directory as normal user.
When finished:
umount /media/dh0
Have a nice day
Hypex
Post by Hypex »
musa wrote: Thu Jan 28, 2021 7:02 pm Hi
Thanks musa. I got stuck on this recently. It would mount fine but then files couldn't be written. Generally 777 is not recommended as it's a security risk. However for Amiga files, that can generally be written by any user, this should be acceptable. I've seen 0755 recommended in place but it blocks writing. I found 707 also works. And 666 could be used if executables aren't needed, though it looks evil. :)
Also, to avoid changing file mode settings, it can be done from the mount. Simply specify the mode from options like so:
mount -t affs -o mode=0777 /dev/sdb3 /media/dh0
