Debian Buster/Sid PPC64
Re: Debian Buster/Sid PPC64
The Power Progress Community has released the Firefox ESR 52.8.0 (64 bit) recompiled with gcc 7.3.0 and patched for Debian Sid ppc64. Packages are available in their repository.
Repository: https://repo.powerprogress.org/debian
FYI;
Adrian wrote: Hello!
Since powerpc is now part of Debian Ports, everyone who is running
Debian on powerpc needs to update their /etc/apt/sources.list to
be able to continue tracking unstable.
The new sources.list should look like:
# binary default
deb http://ftp.ports.debian.org/debian-ports/ unstable main
deb http://ftp.ports.debian.org/debian-ports/ unreleased main
# source
deb-src http://ftp.debian.org/debian/ unstable main
If you want to include packages which were just built on the buildds,
use:
# binary default
deb http://incoming.ports.debian.org/buildd/ unstable main
# source
deb-src http://incoming.debian.org/debian-buildd/ buildd-unstable main
And if you use experimental, use without incoming:
# binary default
# source
deb-src http://ftp.debian.org/debian/ experimental main
And experimental with incoming:
# binary default
deb http://ftp.ports.debian.org/debian-ports/ experimental main
# source
deb-src http://incoming.debian.org/debian-buildd/ buildd-experimental main
You may have to add these lines to your /etc/apt/preferences to
avoid packages from experimental getting installed automatically:
root@sompek:~# cat /etc/apt/preferences
Package: *
Pin: release a=experimental
Pin-Priority: 1
root@sompek:~#
Let me know if you have any issues. I will update the debian-installer
images for powerpc (and all other architectures) in the following
days.
Adrian
FYI:
Adrian wrote: Unfortunately, Debian Ports currently does not build any packages
from the non-free repository. This means, if you need a package
from non-free and it's not an arch-all package (_all.deb suffix),
you will have to build that package yourself.
We might build contrib and non-free packages for Debian Ports
in the future, but I am not sure whether that's possible from
the legal point of view.
Adrian
FYI:
Adrian wrote: I forgot to mention. You need to install the package "debian-ports-archive-keyring":
# apt install debian-ports-archive-keyring
In case you are prompted to install from an untrusted source, say "Y".
Then run "apt update" again.
Adrian
There was a plenty of updates available for Debian Buster PP64... I selected them all and started the update process. Download went ok, but there were some problems in the installation step... After I rebooted Debian, it was not anymore able to open the desktop (no error messages, just blinking cursor on black backround screen).
I was able to open a terminal window with F2 and log in, but 'Startx' was not succesful, the server gave up trying to open a desktop. 'llightdm' was an unknown command to the terminal.
What steps should I use to get the distro again 'on it's feet'?
xeno74 wrote: Mon Oct 16, 2017 11:18 pm Hi All,
I created a small image of Debian Buster/Sid PPC64 today. I recommend to use it if you have any problems with Adrian's ISOs. Please increase the partition with GParted after you copied the image to an empty partition. I had to decrease the partition a little bit and after that I was able to increase the partition.
Download: debian-9.0-ppc64.img
root (password "amigaone")
First steps
  1. Configure your network device with dhclient
  2. Check the network device with ip a
  3. Update the package index with apt-get update
  4. Install Xorg with apt-get install xorg
  5. After that you could install the MATE desktop with apt-get install mate-desktop-environment-extras
  6. Then you could install a display manager for example "lightdm" with apt-get install lightdm
  7. Afterwards reboot your AmigaOne
I was able to upgrade the Debian img above to version 11 (bullseye) today.
  1. I updated /etc/apt/sources.list
    deb [allow-insecure=yes] http://ftp.ports.debian.org/debian-ports unstable main
    deb-src [allow-insecure=yes] http://ftp.ports.debian.org/debian-ports unstable main
  2. Code: Select all
    apt-get dist-upgrade
  3. Code: Select all
  4. Code: Select all
  5. Code: Select all
    apt-get install network-manager-gnome
  6. Code: Select all
  7. I updated /etc/apt/sources.list
    deb http://ftp.ports.debian.org/debian-ports unstable main
    deb-src http://ftp.ports.debian.org/debian-ports unstable main
  8. Code: Select all
    apt-get update
  9. Code: Select all
    apt install lightdm
xeno74 wrote: Mon Aug 16, 2021 11:12 am Debian 11 "Bullseye" has been released. :-)
Great! If you just have time, could you please put a partition image of it available at your site...?
PS. Is there a fresh Firefox version available for it?
Roland wrote: Mon Aug 16, 2021 2:44 pm Great! If you just have time, could you please put a partition image of it available at your site...?
Yes, I will create a partition image. The Firefox versions 86.0.1 and 78.12.0esr are available on Debian 11 PPC64 and work but all images in these Firefox versions itself and on the websites have wrong colors.
