Alfkill : Sorry for offtopic
Raziel : Therefore, the problem should be on my system... but where ? Thank for the confirmation.
For RMB on my dockies, just click once on the docky to close his info window and after the RMB works good.
Various requests
Re: Various requests
I'd try to backup your AmiDock Prefs file and set up a new AmiDock, fresh, clean, constisting of nothing but CPUDock and X1TempDock.zzd10h wrote:Alfkill : Sorry for offtopic
If you still get the crash there really seems to be something intervening in your system.
If not, add your dockies one by one and always try the RMB, you'll get the one that breaks it eventually
Thanks for the hint with the one-click
Thank you Raziel,
I followed your advice and
Found !
It was a beta version of KeymapSwitcher Docky.
Tried the OS4Depot version make all working.
CPUDock + x1ktemp + RMB = OK
Found !
Updated classes seems to have solved random crashes in BananaBar.
Now, another related request: What is the standard method (if any) of figuring out, what gfx chipset a certain screen/view is running on?
