X5000 MCU Led Blinking - Not Booting
seventhwonder
Post by seventhwonder »
Dear all
After 5 years, this morning my X5000 suddenly stopped working. I was doing the daily OS4 beta-testing..After a reboot it stopped working.
After pressing the power button, CPU fan starts to spin 1/2 seconds and stops. After some seconds , MCU Error Led starts to blink.
Here is the video (4 seconds)
https://youtu.be/Olkg7Fmr21o
I tried:
Re-seated MicroSD card
Re-flashed, changed MicroSD. Tried 3 different SD Cards
Removed all PCI cards, memory
Replaced battery with a new one.
Tried with 3 different PSUs
Anyone had a similar problem ? Is this repairable ?
Looking forward to hearing from you.
AmigaOS4 Beta-Tester
Re: X5000 MCU Led Blinking - Not Booting
seventhwonder wrote: Fri Dec 11, 2020 3:42 pm After 5 years, this morning my X5000 suddenly stopped working. I was doing the daily OS4 beta-testing..After a reboot it stopped working.
Did you find a solution to that issue, or is your machine still unfunctional...?
seventhwonder
Unfortunately it is not functional..
I have sent it to AmigaKit back in Jan 2021..
Unfortunately after receiving it, AmigaKit Technical Support ceased answering my e-mails.
I guess X5000 boards are not easily repairable..
