Anoying "Network Log Output"
Steff
Post by Steff »
I have recently reinstalled my entire Workbench (with great help by "Roland". However, trying to configure my network (which isn't the easiest thing in the world), i now keep getting this EVERYTHIME i reboot:
Is there anyway of getting rid of this offending article?????
Thanks in advance.
smf
Re: Anoying "Network Log Output"
Post by smf »
Hi
Maybe you have multiple netinterfaces in devs:netinterfaces?
If not i dont know but i would delete everything in the netinterface drawer and start over again.
Just launch sys:prefs/internet and add a new interface, if you have dhcp on your network it's not much you need to do, iirc just add a new interface and select your network driver and save it. Maybe also click in to use dhcp and add a hostname.
Steff
Post by Steff »
Hello smf.
Thanks for your reply.
The annoying article was indeed in devs:netinterfaces.
I have since removed it and now all is good.
Many thanks.
