Case Ventilation and Temp Improvement
jdupuis
Post by jdupuis »
Hello!
I have the newer Fractal Define R4 case. Just wanted to pass along a notable improvement to Temperatures after having the side open all this time to keep Temps down. I snapped in a new R2 Series Fractal Fan in front (same direction as original) using the spare case fan connection. I screwed in an R2 Series fan in top rear (exhaust direction) and connected to fan connector on the top of Nemo. Paneled up the side with sound proof. I now am maintaining very low CPU and Case Temps. House Ambient Temp: 29 degrees C
BEFORE
Local: 35 - 36
Remote 1: 54 - 55
Remote 2: 57 - 58
Remote 3: 47 -48
AFTER (Stable)
Local: 33
Remote 1: 52
Remote 2: 53
Remote 3: 45
I read prior topics on this and decided to give two extra fans a try and, I think, got positive results with little money. Just thought I would pass this on in case someone is having Temp issues. I also bought a magnetic 140mm fan filter to cover up the top fan when my X1000 is off. I just move it away when it's on. The fine mesh filter blocks exhaust enough to not allow good air flow but blocks stuff from falling in when powered down. Just sharing!
Cheers!!
Re: Case Ventilation and Temp Improvement
People are dying.
How dare you!
– Greta Thunberg
