Problems installing Gorky 17
Zenzizenzizenzic
Post by Zenzizenzizenzic »
Just received Gorky 17, to install on the X1000, and am getting the followng series of "ELF Library" errors on install. I have 4.1 FE installed.
Failed to load shared object libz.so.1 | Required Object is missing
Failed to load shared object linpython25.so | Required Object is missing
The Grim Reaper
Guru Meditation: 80000003
Task 0x60a51800 ("WBL")
generated an error of type DSI (Data Storage Interrupt)
on address 0x021896a0
Redzone was not damaged
Stackpointer is inside bounds
Any suggestions on getting this to work/what is wrong?
Thank you
Zenzizenzizenzic
Re: Problems installing Gorky 17
I was able to install it on my XE, and then transfer it over to the X1000. However, I also getting an error "Please insert volume tbimages:" whenI launch the config. I've also gotten this error whenever I launch unarc.
davebraco
Post by davebraco »
About the error which asks tbimages: could you try to install Aiss and try again please?
http://os4depot.net/index.php?function= ... s/aiss.lha
(or use the "extra's" installer from your AmigaOS 4.1 FE CD, but the one from os4depot is an updated version)
Zenzizenzizenzic
I had installed aiss prior, and the error messages still came. I just reinstalled to double check, and the same issues.
amig_os
Post by amig_os »
Zenzizenzizenzic wrote:I was able to install it on my XE, and then transfer it over to the X1000. However, I also getting an error "Please insert volume tbimages:" whenI launch the config. I've also gotten this error whenever I launch unarc.
Please ADD command in Sys:S/User-Startup
assign tbimages: Sys:Prefs/Presets/tbimages
ZeroG
Post by ZeroG »
Zenzizenzizenzic wrote: Failed to load shared object libz.so.1 | Required Object is missing
Broken / missing links in SOBJS: maybe. see http://forum.hyperion-entertainment.biz ... =14&t=3303
