could not load ide0.0:amigaboo.of: File not found
Flipper
Post by Flipper »
This is what I get after installing AmigaOS4.1 FE on a SanDisk 128GB SSD.Went through the complete install and removed the FE cd and the X1000 rebooted.
This is what showed on the CFE screen.
Loader :elf Filesys:amigafs Dev:ide0.0 File:amigaboo.of Options: (null)
Loading : Failed
Could not load ide0.0:amigaboo.of : File no found
The above amigaboo.of is not a typo error. This is what showed on cfe.
Does this mean my cfe is screwed up or errors on my AmigaOS 4.1 FE cd?
Has anyone else had this problem? I did swap sata ports.
Amiga A1000 thru A4000,Sam440,Sam440flex.An Amigan since 11/1985.Homer,Ak;halibut fishing capitol of the world.
MichaelMerkel
Re: could not load ide0.0:amigaboo.of: File not found
Post by MichaelMerkel »
Flipper wrote:This is what I get after installing AmigaOS4.1 FE on a SanDisk 128GB SSD.Went through the complete install and removed the FE cd and the X1000 rebooted.
Loading : Failed
does it really show "amigaboo.of" without the "t"?
if yes then your CFE variable is faultily.
try to fix that.
maybe have a look here
regards
michael
Michael Merkel :lol:
